well no announcement that it has been permanently axed has been given so who knows. But it is certainly an easy one to cut as as off peak only went to Kentish Town so effectively had no impact on the Northern Side of Thameslink. It's the only Thameslink all day service that hasn't been restored.Obviously wasn't lucrative enough to maintain that frequency in these more challenging times.
How about simplify the number of cross-workings such that trains always go to the same branches?insufficient platform capacity in peak times
insufficient capacity at all times (as you have doubled the Wimbledon loop)
No, and no.
But it will be extended. For most St Albans commuters, by 30-50%, for example.
Catford Loop was always the 'red-headed step-child' - even more so than the Victoria-Dartford of old, which used to end at 19:38 or so. Basically when Camberwell and Peckham became desirable, those services increased. But Catford and co aren't there yet.well no announcement that it has been permanently axed has been given so who knows. But it is certainly an easy one to cut as as off peak only went to Kentish Town so effectively had no impact on the Northern Side of Thameslink. It's the only Thameslink all day service that hasn't been restored.
How are you going to path the additional Sutton services over the South Eastern Main Line at Herne Hill?So my revised idea now is:
Welwyn - Sutton (8 cars, 4 tph)
Stevenage - Gatwick (2 tph)
Letchworth - Sevenoaks (2 tph)
St Albans - Sutton (8 cars, 4 tph)
Luton - Horsham (2 tph)
Luton - Rainham (2 tph)
The reason of running 4 tph on Sutton loop is that it is the expected service standard of a London metro service.
How are you going to stop 12 car trains at New Barnet, Potters Bar and Welwyn Garden City?New calling patterns:
Brighton to Cambridge 2tph (...Finsbury Park, New Barnet, Potters Bar, Hatfield, Welwyn GC, Stevenage, Hitchin, Letchworth, Baldock, Royston)
Kings Cross to Cambridge 2tph (Finsbury Park, Welwyn GC, Welwyn North, Knebworth, Stevenage, Hitchin, Letchworth, Baldock, Ashwell & Morden, Royston, Meldreth, Shepreth, Foxton)
This means the Thameslink service pretty much becomes a "skip stopping" service, serving all of the well used stops all the way along, and the Kings Cross to Cambridge slow service becomes a fast to Welwyn and a slow from there.
This is such a bad idea that it hasn't been done since the Cambridge Buffet Expresses stopped calling at Welwyn Garden City 50 years ago. It eats into capacity on the fast lines.The Kings Cross to Cambridge service will run on the fast lines, loop onto the slows to call at Welwyn and then stay on the slow lines after the 2 track section
I did wonder whether the Catford loop required a 15 minute off peak service, and whether it could be done with both Sevenoaks and Orpington trains running to/from the GN. That might require terminating/starting at Finsbury Park with ecs reversals via Hornsey flyover or Bowes Park reversing siding. It is a shame that the Hertford loop is unsuitable for 8 car trains: how about rebuilding Gordon Hill with 8 car platforms, through roads on the outside and 2 bays in the middle?You'd also need the Orpington Service on the Catford Loop for the same reason. Pre pandemic it was an all day service but currently only running in the peaks
EMR: a complete rehaul of the intercity / connect timetable as follows:
intercity: 1 fast train to each of Sheffield / Nottingham per hour, non-stop to Leicester, and 1 slow train to each of Sheffield / Nottingham per hour, calling at Luton Airport Parkway, Luton, Bedford, Kettering, then the usual stations onwards
Milton Keynes is 80 km from London Euston, the same distance as Bedford from London St Pancras. Some trains also call at Watford Junction as well, and these two places are good places to transfer to a local train.One problem at the moment is the time differential between the “fast” and “slow” Sheffield services (given the stops at Loughborough / East Midlands Parkway/ Long Eaton…)
Adding in another four stops to the slow service would make it take… roughly fifteen minutes longer than it already does (?), at which point you might as well scrap it north of Derby since it’ll be getting overtaken by the “fast” or have to be so carefully pathed (leaving St Pancras two minutes after the “fast” has departed and hoping it’ll get to Sheffield two minutes before the next “fast”) that it’ll be useless for any long distance passengers
Nobody seriously suggests that the London - Liverpool/ Manchester service stops four times South of Milton Keynes, so I don’t know why Sheffield is expected to have its service downgraded to satisfy local passengers in Bedfordshire
There is quite a few services on the ECML and WCML that don't stop until way further than that, for example the ones that run York or Crewe to london non-stop. Many trains skip both Milton Keynes and watford junction, for example.In contrast, 80 km from London will take you from Waterloo to Basingstoke (77 km), from Paddington to Didcot Parkway (86 km), from Euston to Milton Keynes (80 km), from Kings Cross to St Neots (83 km), from Liverpool Street to Colchester (83 km), by then most long distance intercity trains have already made the first call out of London (Woking, Reading, Watford Junction / Milton Keynes, Stevenage, Shenfield / Colchester) where passengers from local trains can transfer onto.
Well the Cambridge Slow comes into Finsbury Park 15 apart from the Welwyn to Sevenoaks Service and is restricted to 8 Car too so that could work from that perspective (setting aside reservations about sending anything more down the core all ready expressed)I did wonder whether the Catford loop required a 15 minute off peak service, and whether it could be done with both Sevenoaks and Orpington trains running to/from the GN. That might require terminating/starting at Finsbury Park with ecs reversals via Hornsey flyover or Bowes Park reversing siding. It is a shame that the Hertford loop is unsuitable for 8 car trains: how about rebuilding Gordon Hill with 8 car platforms, through roads on the outside and 2 bays in the middle?
Yes i'd agree 4 tph to a London Terminal should really be min really...Catford Loop was always the 'red-headed step-child' - even more so than the Victoria-Dartford of old, which used to end at 19:38 or so. Basically when Camberwell and Peckham became desirable, those services increased. But Catford and co aren't there yet.
Any route like that in South London (SE especially, with no meaningful tubes) - should be running an even 4tph to a same London 'terminus'. Catford Loop, Vic-Lewisham, Vic-Shortlands slow, Blackfriars to Wimbledon/Sutton each way. Wimbledon of course is way better served but the rest of the loop seems like an opportunity for way more service (and intensification).
Not all places are equal. Reading is a far busier and more strategic interchange (and destination, employment place etc) than Watford, Stevenage or Milton Keynes.In contrast, 80 km from London will take you from Waterloo to Basingstoke (77 km), from Paddington to Didcot Parkway (86 km), from Euston to Milton Keynes (80 km), from Kings Cross to St Neots (83 km), from Liverpool Street to Colchester (83 km), by then most long distance intercity trains have already made the first call out of London (Woking, Reading, Watford Junction / Milton Keynes, Stevenage, Shenfield / Colchester) where passengers from local trains can transfer onto.
The first stop on the current Sheffield trains is Leicester, 159 km from London St Pancras, nearly double the distance to Bedford.
Take 159 km into context on other lines, which is about the distance of a non-stop run from London Paddington to between Swindon (124 km) and Bristol Parkway (180 km), or from London Kings Cross to Grantham (170 km), or from London Waterloo to New Milton (158 km), or from London Euston to Nuneaton (156 km).
It's the same as Heathrow Express not running into the Crossrail core, and Hayes & Harlington will see their trains full of Heathrow passengers going to the City in the future.
I'm just copying this model over as now Elizabeth line (former TfL Rail) is the most punctual train company in the whole of Great Britain.
It doesn't work.For me- if it works, leave it.
Potentially fewer LNER trains could be stopped there, to ensure full use is made of the 12 cars.Ideally 12 cars is more suited to Peterborough, though not really needed off-peak.
The core will never consistently run on time, or at least it will never be an assumption worth gambling the ECML on.What is essential is that no matter where they go, the timetable is robust enough to ensure they don’t rack up delay minutes.
TfL has already said it wouldn't be able to run a reliable service if there are so many long branches out of London.
It seems as though your only objection to the Peterborough services running through the core is a desire for TfL to take over Thameslink. But why should TfL take it over?The major problem now is where to send the 12-car trains from Peterborough / Cambridge if we want to keep them out of the core if Kings Cross is at capacity.
Because TfL has a track record in improving train services, including punctuality. TfL Rail / Elizabeth line was the most punctual operator in the latest report.It seems as though your only objection to the Peterborough services running through the core is a desire for TfL to take over Thameslink. But why should TfL take it over?
I'm not suggesting that it does work, though I imagine some parts work more consistently well (or badly) than others? Is it clear (and widely?) accepted what it is that 'does not work'?It doesn't work.
It doesn't work.
I don't think no trains to the core (which connect well with intercity services eg St Pancras, Kings X for EMR and LNER/Lumo) will go down very well for us (Redhill) and you are also asking passengers to change at an extremely stressful station onto a train that will probably have no seats (as it is from far beyond and passes though large settlements) for 20+ minutes? It wouldn't work but I appreciate that you've at least tried unlike myself...Perhaps a simplification of off-peak Thameslink mainline services would be for all 8tph to run via the Quarry Line and be the only services from Keymer Junction to Brighton/Hove. An 8tph turn up and go service for the major stations from St Pancras to at least Haywards Heath would seem pretty convenient. Perhaps:
No Gatwick Express. All services via Redhill, Horsham or Lewes run to/from Victoria. A 6tph via Redhill service would be an easy connection to the 8tph Thameslink service at East Croydon.
- 4tph Bedford-Brighton
- 2tph Cambridge-Brighton
- 2tph Peterborough-Littlehampton
Just an idea.
You could also catch the 6tph service to Victoria and hop on the Victoria line if you want a route to the North.I don't think no trains to the core (which connect well with intercity services eg St Pancras, Kings X for EMR and LNER/Lumo) will go down very well for us (Redhill) and you are also asking passengers to change at an extremely stressful station onto a train that will probably have no seats (as it is from far beyond and passes though large settlements) for 20+ minutes? It wouldn't work but I appreciate that you've at least tried unlike myself...
Is that 6tph to Victoria?
Alas another change that most of are able to to but it just adds inconvenience if passengers know that there can be /was a train to St Pancras yet they are asked to get on the stuffy tube to get elsewhere.You could also catch the 6tph service to Victoria and hop on the Victoria line if you want a route to the North.
I would think that when they have a wait for a Redhill service in Central London, they might wish that there was a station in London (other than East Croydon) with a 6tph service to Redhill.Alas another change that most of are able to to but it just adds inconvenience if passengers know that there can be /was a train to St Pancras yet they are asked to get on the stuffy tube to get elsewhere.
Not really consistent with how East Croydon and Windmill Bridge is laid out though. It would be more straightforward to put all London Bridge services via the slow lines at East Croydon and all Victoria trains via the Quarry, but totally undesirable.All services via Redhill, Horsham or Lewes run to/from Victoria.
Yes exactly. The core.I would think that when they have a wait for a Redhill service in Central London, they might wish that there was a station in London (other than East Croydon) with a 6tph service to Redhill.
Thameslink's issues are in my view mostly because they did not design the network to allow for contingency when something goes wrong. So, when there is a problem it stops almost everything.
Evidence suggests, I think, that folk are prepared to change trains etc if they have reasonable certainty that 'it works'
Portsmouth / Southampton services should not run via Redhill.If we are really theorising how these Thameslink services could be altered, I think if Thameslink were to withdraw from Redhill completely there needs to be an increase in Southern services to the south coast eg that Portsmouth Harbour & Bognor train should run via Redhill all the time like before 2018. (Does anyone recall the reason why it was removed). Creating such services via Redhill removes the necessity of changing at Gatwick Airport and now with the decrease in capacity if there was a withdrawal in Thameslink services is needed to ensure that Redhill line passengers can be treated well service wise. (and get a seat)
I have made a few errors in this please feel free to contradict it![]()
Redhill isn't a minor suburban station though?Portsmouth / Southampton services should not run via Redhill.
They are long-distance intercity services so the pattern should be the usual London Victoria - Clapham Junction - East Croydon - Gatwick Airport - ...
Redhill is a minor suburban station which shouldn't be served by trains primarily for long-distance passengers.
It was removed because there wasn't room for Redhill passengers to board going to London. The current arrangements are better and changing at Gatwick / Three Bridges / Horsham is not as big an issue as you suggest, particularly once the work is finished.there needs to be an increase in Southern services to the south coast eg that Portsmouth Harbour & Bognor train should run via Redhill all the time like before 2018. (Does anyone recall the reason why it was removed)
Passengers from Chichester and the Arun Valley do thoughTo be fair Long distance passengers who are really going to Southampton or Portsmouth from London wouldn't use the southern services anyway
The only viable option is Gatwick to change as by Three bridges/Horsham the train is already too full to board?It was removed because there wasn't room for Redhill passengers to board going to London. The current arrangements are better and changing at Gatwick / Three Bridges / Horsham is not as big an issue as you suggest, particularly once the work is finished.
Which train is too full at Three Bridges and Horsham to board? Brighton trains get busy on a sunny day in the summer but do coast bound Arun Valley trains have standing passengers going south in the morning?The only viable option is Gatwick to change as by Three bridges/Horsham the train is already too full to board?
