BogiePicker
HSUK does in fact provide superior connections between those areas, with 1 hour journey times between the former Northern cities and Birmingham and 4tph proposed service frequencies for each. The reason you may have thought this is that the strategy does not involve new-build construction, but upgrades along existing, highly populated cross-country corridors. It is superior to HS2 because these corridors do not warrant very high speed alignments, because the intervals of non-stop running are not long enough to justify them; and also because they would take one directly to Birmingham New St. HSUK's outputs esteem Birmingham New St as the strategic and pivotal station of the entire national network, and cross-country services are given first order in their compendium.The HSUK route doesn’t appear to provide a direct or dedicated high speed line between Manchester/Leeds and Birmingham, so HS2 is far better on this key requirement.
In specific terms:
- Manchester - Birmingham: the strategy involves upgrading Birmingham - Stoke to enable journey times under 1 hr with 1 stop in Stoke. Selective four-tracking where possible and appropriate.
- Leeds - Birmingham: transpennine new-build to Sheffield Victoria, join new build main line and branch off via new/restored route to Derby. Then, upgraded cross country main line to around 155 mph to Birmingham New Street.
The other benefit of routeing to New St is that other cross-country destinations can also benefit from faster times from the North to New St, notably Bristol, but also Soton/Bournemouth/Cardiff/Exeter etc. Improved journey times along populated corridors also provides the basis for higher service frequencies.
Edit: response to other comments
- As said, HSUK values Birmingham New St as a station, but the best solution for the *national* network is not necessarily to route the main line through it. Indeed, since it is at the heart of the nation (in a manner of speaking), being on average closer to everywhere else, means it in itself paradoxically *doesn't* need super HS lines to everywhere else to get low journey times. Nonetheless it benefits viz. London with HS new build running along M1 corridor then joining WCML near Rugby; and for fast access to the NE and Scotland, HSUK proposes a 'HSUK10' service, running New St - Derby - York and then off to Newcastle, Edinburgh, Perth, and Dundee.
- The challenges of 400m stations would face any scheme, especially with Liverpool and above all Birmingham New St. Capacity issues are dealt with by 4-tracking out of London rather than just using two tracks, having high service frequencies supported by optimised routeings, and, as above, having diverse and integrated access corridors serving through-stations rather than squeezing absolutely everything onto a 18 tph Y-network with terminus stations.
