pablo
Very good idea. They could go straight to the National Transport Museum. A bit like APT.
No, it just means that the CC trains will travel at higher speeds for longer from day one, and the money that would've been spent building the WCML connection at Lichfield will be saved. CC trains will run via HS2 when phase 1 is complete to Liverpool, Manchester and Glasgow (and maybe Edinburgh).
I still think it is ironic (almost strange) in a way that with all the negative press HS2 gets around the Buckinghamshire & Chiltern areas, there are those "up north" who actually want to be on the line. Hopefully people will stop listening to the anti-HS2 bilge and start listening to people who want it in their back yard.
Although I'm in favour of HS2, I supect more people in Buckinghamshire and Chiltern would be in favour if they had a local station![]()
That may be true to some extent. Unfortunately a station would be very expensive in terms of cost and also each train stopping there would take up two train paths on a route which is planned to be fully used. As it is relatively close to London the time saving compared with Chiltern wouldn't be huge, and for many people would be outweighed by the extra time to get to an HS2 station that would be less convenient than the nearest Chiltern station.
If you look at the amount of road infrastructure required around Birmingham Interchange you'll see another reason why the Government isn't even considering a Chilterns Parkway station. The vast majority of travellers would use cars to get to the station, meaning that the roads around it would get very busy and you would need a truly enormous car park.
Actually a station could be included that would not use up paths - but it would mean that every train would have to stop there.
http://www.bbc.co.uk/news/uk-england-28672424
Interesting article about the north-south divide over support for HS2. Nothing new though.
Interesting statement from Stop HS2's Joe Rukin, who acknowledges there has been a groundswell of support for the project among councils in several northern cities and goes on to say:
"Basically, if you are getting a station, you think it's a great idea . . . If you're not, you don't."
I think an intermediate chilterns parkway, even a classic rail interchange at the HS2-EWR intersection, would cause many problems and should be avoided. Getting rid of those pesky non stop trains from the WCML will create capacity for many more semi fast expresses from all over the midlands and north west, interchanging at Milton Keynes with east-west rail routes and providing vast numbers of extra fast seats from Milton Keynes into London, as the burghers there have no doubt realised. The benefits are complementary and enabled by HS2, rather than being directly provided by its infrastructure. How to sell that to the public is the problem.
Four-tracking of the Chiltern line was never continuous throughout the length of the route.I haven't been following HS2 news for long time but wouldn't it save money if HS2 mainly followed Chiltern route seeing it was once quadruple tracked line? It would mean less CPO orders as well as less tunnels, etc? HS2 could still start from Euston and keep all of their stopping pattern (HS2 splits Chiltern Line at Leamington Spa to go to Interchange). I can see Chiltern line being disrupted but probably not much since line will be left alone most of time except for some rearrangement.
http://www.appghsr.co.uk/upload/Chiltern Railways submission.pdf
A number of commentators have suggested that the Chiltern line could be upgraded as an alternative to HS2. We do not believe this is practical:
The Chiltern line is now very busy, and in parts working at capacity. Claims that there is significant spare capacity are incorrect.
Extra capacity could only be added by building additional tracks. As noted above, this would be extremely disruptive, and the work would severely disrupt passenger journeys for many years.
Claims that Chiltern trains could be “looped” onto side lines to enable intercity/high-speed trains to pass are not practicable. Not only would the looped trains be excessively delayed, but the overall gain in line capacity would be slight.
Claims that the line was built with enough land to add additional tracks throughout (i.e. quadrupling) are largely incorrect. Whilst there are stretches of the line where 4-tracking was originally possible, these are not contiguous, and the width is often insufficient for earthworks and between-track clearances to modern standards. Significant extra land purchase would be required, along with much heavy engineering work.
Much of the additional land and construction work needed would be in the middle of urban and residential areas such as Gerrards Cross and Beaconsfield, and considerable purchase of domestic property would be required. Away from the towns it is also questionable whether significant work would be allowed in the Chiltern AONB.
At both High Wycombe and Leamington Spa the existing railway is elevated above the town, and on a sharp, speed-restricted curve. A new by-pass line would thus be needed, and due to (perceived) noise impacts this would probably also be desirable for the other towns en-route. In this case the various by-passes might as well be linked to give a wholly-new route throughout, rather than a sub-optimal mismatch of old and new.
Between Northolt and Denham the works needed to upgrade the existing railway would be little different from those proposed for HS2.
Plans to create one of the capitals largest transport hubs by linking HS2 to London Overground were unveiled today by the mayor amid a bitter row with town halls about the development.
City Hall set out the options to build a new London Overground station on the sprawling west London industrial area at Old Oak Common to fully exploit the economic potential of additional links it is due to gain to Crossrail and HS2.
Although Old Oak Common is already on the route of the London Overground, the mayor believes it needs a dedicated station to be paid for by government, which his transport planners calculate would link locals to a quarter of a million jobs.
Transport for London have produced three options for a station, the most eye-catching of which is building a viaduct diverting the Clapham Junction branch of London Overground to link with the Richmond branch at Old Oak Common.
In all three scenarios, passengers are linked via a walkway to the proposed new station which would overarch HS2 and Crossrail lines.
With the new Overground, a greater number of HS2 passengers arriving from the North of England at Old Oak Common would avoid having to travel into central London, easing the pressure on Euston.
Only Crossrail is confirmed but if all the new lines are built, Old Oak Common could handle 250,000 passengers a day, similar to Waterloo station.
The mayors vision is to create a mini-Manhattan around the HS2/Crossrail station as part of a wider development at Old Oak Common he says can create 24,000 new homes and 55,000 new jobs.
Why does it matter if there is going to be a port at Liverpool?
Noone ever goes to watch the port where a computer unloads their boxes amongst thousands of other near identical ones.
