FrodshamJnct
Are they proposing to scrap the TFW services from Piccadilly to Chester/North Wales via Warrington Bank Quay, or is this in addition to them?
Fair enough - hadn't realised that
They would be re-routed via Altrincham, but the Leeds-Victoria-beyond Northern service would become 2tph to compensate.
When will this be happening?
May 2022 at the earliest if they do decide to stick to these plans after covid.When will this be happening?
Apparently so. Helsby, Frodsham and Runcorn East get a 2 trains per hour service to Manchester Victoria and Leeds. No more direct services to Oxford Road or Piccadilly.Would they also compensate by calling at stations like Earlestown, Newton-le-Willows, Runcorn East and Frodsham?
You probably wouldn't lose any cash if you bet on the taskforce not knowing that detail currently.One slight issue, if 195s aren't cleared, what about the proposed TfW service? Will they have to keep some 175s on for this specific service? Because as far as I'm aware, all UK Civitys use the same bodyshell.
So would there still be services fast from Chester - Warrington - Victoria?
To me, that makes much more sense for the North Wales service.
Frodsham and Helsby will have the Liverpool-Chester (onwards) 1tph too. There was also talk of this going up, maybe 2tph but maybe through splitting, unclear: 1tph to Shrewsbury (0.5 to Cardiff) and 1tph to North Wales.
As for Mid-Cheshire, I don't think it's best used for the longer distance services. But does need improvement. The best thing would be some Alty shuttles and full integration with Met - or the tram-train to Hale or even Knutsford, to cover the highest demand.
I believe one option is for the TFW services currently running through Bank Quay to go via the Mid Cheshire.So would there still be services fast from Chester - Warrington - Victoria?
Haven't TfW services fairly recently (last year or so) been diverted via the Mid Cheshire line during a period of engineering work affecting a section of their normal route between Chester and Manchester? If so, what stock would they have been using on such workings?
As shown in my post on page 1, Class 175s are cleared throughoutHaven't TfW services fairly recently (last year or so) been diverted via the Mid Cheshire line during a period of engineering work affecting a section of their normal route between Chester and Manchester? If so, what stock would they have been using on such workings?
Did you? Which post number? Must have missed that! Either way, thanks for clarifying / re-clarifying.As shown in my post on page 1, Class 175s are cleared throughout
They have a handful of empty class 175 Chester-Manchester services booked over the Mid Cheshire line to keep up crew route knowledge.Did you? Which post number? Must have missed that! Either way, thanks for clarifying / re-clarifying.
(Presuming that class 175s are what TfW might run on the Mid Cheshire).
Post #55, page 2 (sorry!).Did you? Which post number? Must have missed that! Either way, thanks for clarifying / re-clarifying.
They were actually booked for some early morning runs to Manchester. Sadly, I never got to experience that but oh well.The occasional 175 wandered onto the "normal" Mid Cheshire service occasionally in First North Western days.
I believe paths between Crewe and Sandbach would also be an issue, especially once HS2 Phase 2a opens and the London - Manchester trains start running via Crewe and Wilmslow. And Northwich station would need a costly rebuild, to reinstate a platform on the Middlewich line.As for providing the line with a better service, I'd suggest 1 tph Chester - Manchester, and 1 tph Crewe - Manchester via Middlewich. The Chester service to skip-stop some of the smaller stations between Northwich & Altrincham and the Middlewich service would be all stations. Appreciate paths would be an issue presently, especially between Stockport & Piccadilly though.
Although TfGM's five year plan actually says:Altrincham is the natural terminus for Metrolink. Extending the service beyond there requires the complexity of tram trains and would interfere with the extensive freight traffic. It isn't worth doing so just as far as Hale, which is in any case very affluent and low density suburbia, and beyond there is the relatively empty Cheshire countryside.
In the next five years, we aim to complete the business case for early delivery of Tram-Train Pathfinder South: South Manchester to Hale via Altrincham.
Rationale: A pilot scheme to maximise the utilisation of the existing Metrolink capacity in order to accommodate rapid transit demand growth to and through the Regional Centre. Will also facilitate testing of the tram-train concept for wider application in Greater Manchester.
The proposal is that Runcorn East, Frodsham and Helsby will get a half-hourly Northern service all day, with the TfW trains diverted on to the Mid Cheshire.I’d hope if it does happen that the Northern services through Runcorn East, Frodsham and Helsby would stop at these stations more frequently than they do now (couple of times per day).
I suspect the TfGM intention is to change the parallel single tracks between Deansgate Junction and Navigation Road back to a double track railway, shared between heavy rail and tram-trains.I am aware of TfGM's proposal to run tram-trains beyond Altrincham to Hale. I stand by my previously expressed view and think it is futile and a waste of resources. Another TfGM suggestion for trialling tram-trains is from Bury to Rochdale via Heywood. This would be a much more useful link and a better way to try out tram-trains in Greater M/c.
Tram-trains are vehicles that run on both the heavy rail network and tram tracks. Currently the only ones in the UK are the Class 399 on the Sheffield-Rotherham. Manchester only has trams adjacent to trains on independent single tracks.Isn’t that what there currently is? Or are ‘tram-trains’ different to the trams that currently share that bit of the network with heavy rail?
Yes, through Navigation Road the trams run both ways on one track and heavy rail trains both ways on the other parallel track. This single line working causes a bottleneck on both networks.Tram-trains are vehicles that run on both the heavy rail network and tram tracks. Currently the only ones in the UK are the Class 399 on the Sheffield-Rotherham. Manchester only has trams adjacent to trains on independent single tracks.
Tram-trains, like the Class 399s currently operating between Sheffield and Rotherham, are built to higher crashworthiness standards than the current Metrolink trams, and are equipped with heavy rail systems such as TPWS to permit operation on National Rail tracks.
