Which in turn results in a single from Heathrow to zone 1 at off peak times being charged at the Railcard cap.if you have a railcard discount applied to an Oyster card then the Off-Peak cap is discounted by a third.
This is exactly the kind of confusion that the mess of fares has caused (not to mention TfL's cakeism when it comes to the Elizabeth line fares - treating it as an Underground line in the 'core' but a National Rail service on the Heathrow branch).
What journeys are you making?I've got a Network Railcard which doesn't work with Oyster. I got a £10.50 paper ticket, from Heathrow Terminals 2 & 3 to my tube station in zone 2, changing at Paddington. TfL's fare finder doesn't have this: it has 13.90 or 9.20 (off peak).
As I can't get the 9.20 price with the Network Railcard, then the paper ticket seems the best option at 10.50 so I save 3.40. Am I understanding this right? TfL's fare finder doesn't mention this with seems like an oversight.
This one was single from Heathrow Terminals 2 and 3 to my zone 2 station. I'm normally travelling around London with trips outside every few weeks.We hat journeys are you making?
Does this also apply to the Piccadilly Line, or are the Heathrow Tube stations still in zone 6 both for Travelcards and for pay-as-you-go?Heathrow ticketing is rather bizarre in that it's in zone 6 for travelcards, but has special (higher) fares for pay-as-you-go. So I think "Special fares apply" is more accurate than zone 6, but ideally they'd note about the travelcard validity too
It's in Zone 6.Does this also apply to the Piccadilly Line, or are the Heathrow Tube stations still in zone 6 both for Travelcards and for pay-as-you-go?
Unless you continue onto a “red” National Rail route putting you on the mixed-mode fare scale, in which case off-peak fares apply once againHowever if you travel between Zone 1 and Heathrow, it's charged at peak rate, even if you travel off peak.
£10.50 is the fare for a paper off-peak ticket from 3081 Heathrow Rail to 0786 Zone U1256 Londn, with a Railcard discount. For a Network Railcard, this fare is only valid on weekends and bank holidays. On weekdays after 1000 the fare should be £13, and before 1000 it's not valid at all. The fare without a Railcard would be £15.80.
I'm aware some TfL* POMs** do not apply the £13 minimum fare correctly. I do not expect you will have difficulty using the £10.50 ticket on weekdays on TfL services, even though it's not intended to be valid, but if your journey were to include other non-TfL National Rail services, then you could encounter difficulty.
The fares the TfL fare finder has shown you are Oyster fares, but I expect the site isn't clever enough to note that a Network Railcard cannot be attached to an Oyster card. £13.90 is the full fare for Oyster/contactless. If you did have a Railcard that could be attached to an Oyster card, the reduced fare would be £9.20 off-peak.
It may be possible to reduce your costs further by changing short of Paddington, such as at Ealing Broadway, and avoiding zone 1. You've not mentioned your zone 2 destination station, but if you were to do so we might be able to suggest options.
*In this post I am using the term "TfL" widely and it should be read as encompassing TfL as well as all its franchises and subsidiaries, not just the central body.
**POM stands for Passenger Operated Machine and is the term TfL uses to refer to ticket vending machines.
TfL wants shot of paper tickets so it doesn't promote them.TfL's fare finder doesn't give he paper option for the journey which I feel it should if it's cheaper than contactless.
You can change at Ealing Broadway (level) to the Central line then Shepherds Bush (out of station and across the road) to the Overground then Willesden Junction (accessible) to the Bakerloo line or Overground to Kensal Green, with the full fare coming in at £8.80/£7.60 peak/off-peak by Oyster/contactless. You may need to touch pink Oyster readers at Ealing Bdy and Willesden Jct. The paper tickets equivalent (to 0829 ZONE U2356 LONDN) is £11.80 undiscounted, and £7.85 with a Network Railcard discount on weekends only.Destination station is Kensal Green.
The Piccadilly line stations are also in Zone 6, so Travelcards which cover Zone 6 are accepted - the same as the Elizabeth line.Does this also apply to the Piccadilly Line, or are the Heathrow Tube stations still in zone 6 both for Travelcards and for pay-as-you-go?
You may as well take the Piccadilly line from Heathrow, thus saving yourself a huge amount, if you are prepared to take such a long-winded route. Changing at Earl's Court and West Brompton will result in a fare of just £2.40/£3.60.You can change at Ealing Broadway (level) to the Central line then Shepherds Bush (out of station and across the road) to the Overground then Willesden Junction (accessible) to the Bakerloo line or Overground to Kensal Green, with the full fare coming in at £8.80/£7.60 peak/off-peak by Oyster/contactless. You may need to touch pink Oyster readers at Ealing Bdy and Willesden Jct. The paper tickets equivalent (to 0829 ZONE U2356 LONDN) is £11.80 undiscounted, and £7.85 with a Network Railcard discount on weekends only.
As I understand it, Heathrow has to ensure there is some way of getting between terminals 2 and 3 and the 'rest of the country' at no cost – there is no pedestrian route out of terminals 2 and 3 which sit between the Heathrow runways, and vehicular access is via tunnels from which pedestrians are prohibited. There used to be the Heathrow free bus zone but that was killed off some years ago, and it appears the free trips to/from Hatton Cross replaced it.you don't pay anything for the Heathrow <-> Hatton Cross journey (it's seemingly considered equivalent to the free inter terminal transfer?)
Unless your journey continues to a "red" National Rail route on the mixed mode scale, in which case off-peak becomes available again.The only difference is that peak fares are charged at all times if travelling to, from or via Zone 1
I agree. Although, making too much fuss about this might not get the result we want, because from TfL's and the TOCs' point of view the problem isn't that PAYG fares are too high, it's that these other pesky fares are too low.Thanks for the detailed reply. I was travelling on Sunday. I got the ticket from Uber trains so also had the 5% offer. Thing is, TfL's fare finder doesn't give he paper option for the journey which I feel it should if it's cheaper than contactless.
