GWR to use Euston
irish_rail
30 Oct 2013
Plymouth
Surprise surprise its the Bristols and the south wales that get direct Londons, whilst the south west has to make do with Reading with our passengers have to change onto already full and standing trains from those places just to get into London. Hs2, the gift that keeps giving...
Wilts Wanderer
21 Nov 2016
Are you sure about that? I’d heard it’s 1tph Euston-Swansea via Bristol and 1tph Euston-Plymouth. This might have changed though.
Incidentally just typing those routes felt bizarre! :D
Wolfie
17 Aug 2010
A whole new group of passengers to experience the "delights" of train boarding at Euston.....
Sly Old Fox
21 Jul 2008
England
I don’t think that’s correct. One Swansea and one Plymouth per hour.
lachlan
11 Aug 2019
Euston-Swansea via Bristol - presume that's Bristol Parkway?
I'm surprised it's only 2 trains per hour - so would the majority of trains be terminating at Reading?
jfollows
26 Feb 2011
Wilmslow
I imagine the WCML can only just accommodate even 2 trains per hour, the slow junctions at Willesden are discussed in the thread I linked to earlier and the WCML normal timetable is designed around no such conflicting movements.
See https://www.railforums.co.uk/threads/gwr-waterloo-and-euston.264545/page-3#post-6783592 for example.
Presumably the normal WCMLs can use the slows during the reduced Christmas period, leaving some fast capacity to the GWRs.
Also presumably the GWR 80x will run into Euston on diesel and then stable on electric to minimise emissions in the shed.
Euston-Bristol was of course part of the original L&B/GWR intention until GWR decided to build their own terminus at Paddington.
And we will have a GWR service using the Fast line rather than the Main line. ;)
Russel
30 Jun 2022
Lichfield
Just out of interest, why Euston?
I know they've used Waterloo in the past and I'm sure I remember them using Marleybone too?
I don't know if it is still the case, but I am sure at least 6 (might be 7) platforms at Euston are at least 330m.
Fairly sure some platforms at Reading are fairly long too.
So if I have remembered lengths correctly, in theory (but probably won't happen in practice), could couple a 9car and 5car and have two trains combined for the 2 trains per hour to increase capacity, rather than just running a limited capacity 9car. (Bearing in mind each train east of Reading might be taking 3 or 4 trainloads of passengers.
Blame your management then, they chose the services they wanted to go to Euston, no one else. The SW isnt losing out.
That won't be happening.
FGW_DID
23 Jun 2011
81D & 81E
That article mentions: "...GWR believes Euston offers a better alternative than Waterloo for its inter-city services — including the Night Riviera sleeper train"
An opportunity to photograph the Caledonian and the Riviera sleepers together? 8-)
Test run for the Night Riviera stock this Sunday (30/06):
Nippy
13 Aug 2013
I’m sure that could be arranged.
Trainguy34
29 Apr 2023
Kent
Well if the Night Riviera is using 16 in the mornings and the Highland Sleeper is on 15 as scheduled then...
EDIT: Looks like the Highland is due in at 8 and at the moment, the Night Riviera leaves PAD to Reading Depot at 7:33 so maybe not but hey, you never know!
Halish Railway
26 Apr 2017
West Yorkshire / Birmingham
There is no point running IET's to Marylebone. 9/10 are too long and 5 cars don't provide enough capacity and would be a waste of a path.
I believe the idea is/was to have the Cotswold line services run into Marylebone, using the Chiltern Mainline and reversing at Oxford. These services would be worked by 5 carriage units given that not too much capacity will be necessary.
