Guards vans on fully-fitted freights
AndrewE
9 Nov 2015
Hello
On Saturday I saw a model railway layout and a train of (just) milk tanks was running, with a guards van. It occurred to me that the tanks would probably have been fully fitted as they were also run in mixed trains (e.g. on branch lines.) If this is the case, would they have even needed a brake van?
(On reflection I suspect the answer is Yes, if only because a guard wouldn't ride on a steam loco footplate, unlike the back cab of a diesel.)
LYradial
8 Jun 2024
welsh marches
The brake van and guard have many responsibilities to the train, the train and its contents are “traffic” while the loco and crew are “ motive power” and have little to do, in theory, with whatever they are pulling.
in practice there are lots of things, the guard gives the driver details of what is the train consist, makes sure his tail lamp is fitted and lit, and has responsibilities if an incident occurs.
there is lots more
Up until about 1969, even fully-fitted freight trains had to have a brake van, so that would cover any steam-hauled train. This was partly because the guard had safety duties, such as protecting the train in an emergency, and probably also because of conservatism and union agreements.
Actually the brake van didn't need to be the last vehicle in a fully-fitted train and often wasn't on fast freights as having wagons behind gave a smoother ride. If I recall correctly up to three vehicles were allowed behind, and obviously the van had to be at least piped so the wagons behind could be braked.
MarlowDonkey
4 Apr 2013
Doesn't it depend on the the time period depicted? It was sometime in the 1960s that freight trains first ran without guards vans.
AndrewE
9 Nov 2015
That is very interesting and could lead to some discussions about the realism or otherwise of people's model railway train consists!
weren't these the Freightliners where they discovered that you couldn't put a guard in a box on the wagon on the tail? Hence the move to the back cab...
They were first introduced with a "guard's container" having a Perspex dome in place of a ducket - there was one in the NRM York last time I visited. Then they switched to various coaching stock brake vehicles for a while.
Gloster
4 Sep 2020
Up the creek
Six or seven of the guard’s containers were built at Derby in 1965, but it appears that only one or two saw any use and that was effectively on a trial basis. They very quickly proved unworkable and were boycotted by the NUR as the guards were hurled about like a leaf in a hurricane. Management very quickly accepted this without demur, which shows how strong the NUR’s argument was, and from mid-1966 former revenue coaches, mostly Mark 1 suburban non-corridor brakes, were included in the consist. From the beginning of 1969 they were surplus as the guards could ride on the loco.
ChiefPlanner
6 Sep 2011
Herts
In "theory" in the back cab - often , in the front.
thesignalman
9 Jan 2012
Until the late 1960s, all Freightliner services that I saw had a BG marshalled into the formation - either at the front or rear - for the guard to travel in. So at this date there was no restriction (mentioned elsewhere) on how many vehicles could be marshalled behind the brake van. The introduction of permitting guards to travel in the rear cab (after considerable trade union negotiation) rendered the provision of these BGs unnecessary.
John
matchmaker
8 Mar 2009
Central Scotland
I saw one of these brakes going through Arbroath on a Freightliner in 1967. From what I recall it was painted white or cream and badged "Air braked, gas heated".
AndrewE
9 Nov 2015
So that's another unusual but true-to-prototype train formation for the perverse modeller to run, what a surprise this thread has turned out to be!
Thanks all.
A
6Gman
1 May 2012
I'm aware of a serious (fatal) accident where the presence of the guard in the front cab was felt to have been a contributory factor.
Which prompts a question. If a single Class 20 worked a fully-fitted freight what was the official policy?
AndrewE
9 Nov 2015
Cowden? Wikipedia https://en.wikipedia.org/wiki/Cowden_rail_crash says
The cabs were so badly damaged that it was impossible to determine who had been driving 2E27.
Provide a brake van? Or turn a blind eye to an extra person in the cab (which might have been at the back of the loco.) Or maybe cancel the train until a pair of 20s were available...
Hairy Bear
13 Feb 2011
Derbyshire
Brake van required, same applies to an 08. Even a pair of 20's required a brake van until the mid 80's when a brake valve was added to each class 20 cab, this then allowed the guard to ride on the 2nd loco with the ability to apply the train brake if required.
thesignalman
9 Jan 2012
Thanks all.
A
Make sure you model them so dirty that you can barely see the colours underneath, they never got washed!
John
Brightonboy
20 Jan 2025
Suffolk
I don't recall seeing brake vans attached to the coal hopper trains that pairs of 20s regularly rumbled through Nottingham in the late 70s?
eastwestdivide
17 Aug 2009
S Yorks, usually
Mid-1980s there were regular coal trains from the Wigan area (?) to Fiddlers Ferry near Warrington, formed of double-headed 20s, merry-go-round HAA coal hoppers and an air-piped (actually dual-piped) CAR brake van. The route involved a double reversal to reach the westbound lines under Warrington BQ from the southbound lines through that station. The brake van enabled a propelling move from S of Warrington BQ past all the yards to reach the E-W lines. Somewhere I’ve a photo of the guard looking out during the propelling move.
[edited for clarity and typos!]
ChiefPlanner
6 Sep 2011
Herts
Apologies - photo nicked from somewhere in my enthusiasm to illustrate a temporary fix for Freightliner - note they are old school "bottom lift" domestic FLL containers - presumably long since scrapped or ended up in non railway use. !
Harpo
21 Aug 2024
Newport
In BR days, the manning agreement for a single 20 was for it to be double manned by a driver and secondman.
ChiefPlanner
6 Sep 2011
Herts
Even the Ipswich Yard to West Bank RCT was worked by a double manned 08 with a CAR brake van , some times a brake van which had strayed far from it's normal and legal home , and had both a guard and a shunter. Loadings could be heavy - my record was no less than 25 loaded FFA amd FGA wagons when the port was handling diversions from other ports due to "staffing problems" - good job I quite enjoyed shunting ! (1980 ish era)
Ashley Hill
8 Dec 2019
The West Country
When I started we had brake vans on our fully fitted trip work to convey not only for the guard but also the travelling shunter. They were handy for propelling moves.
MarlowDonkey
4 Apr 2013
Another thought on this. Were the traditional four wheel brake vans speed restricted so as to be unsuitable for the speedier of fast freights?
AndrewE
9 Nov 2015
AIUI the SR "Queen Mary" bogie brake vans were designed for use on fast freights.
The GWR "Toads" also look like a longer wheelbase than a standard wagon, but I can't find figures anywhere. Besides the extra weight you would think that a longer wheelbase would let them ride better at speed - on an unfitted train all the wagons have another one in front and behind, but the brake has nothing to stabilise it in the rear.
(I am aware of freight train derailments from rigid vehicles hunting, and short-wheelbase wagons being banned from being attached to passenger trains.)
Gloster
4 Sep 2020
Up the creek
As far as BR built vans are concerned, the LMS, LNER and BR designs appear to have had a top speed of 60 mph if vacuum-fitted or -piped and 50 mph if unfitted. The only speed I can find for GWR ones was 45 mph, but this may have been applied later in their life.
Source: British Railways Brake Vans & Ballast Ploughs (Gent, HMRS, 1999).
