CockneySparrow
Wonder if the off the wire 379 trials will be sucessfull enough to run through to/from Great Yarmouth thus making the drags redundant eventually.
wouldn't have thought you would ever see a 379 at Yarmouth
but those carriages won't be used for the summer timetabled drags though
Well no, because part of the point of those is that you can board a train in London and get to Great Yarmouth without changing.
...and something like a 379 would be a great replacement for the LHCS from Liverpool Street.
Sure the Norfolk commuters wouldn't like them (even though they've got 2+2 seating throughout) but better acceleration, ability to shorten/lengthen sets and less reliance on a single traction source would be an all round winner for those services.
Not quite sure how many seats a 90+MK3 set has got, but I can imagine there'd be a worthwhile jump in capacity too.
379s to Norwich would be awful, yes they are better than 317s only because they are new and have better seat and table set up, but the seats to sit in are rock hard and the interior is cheap
I don't know why on earth you think the Norwich need to be shortened at any point during the day. They are always wedged as they are coming through Colchester apart from the early morning down roads and the last London bound service but they need to be full length for their return working. Plus from what I've been told by Cambridge and Bishops Stortford drivers the 379's are rubbish. Keep the hauled sets, give them a thorough refurb, convert the DVT. Plus I've been told 10 coaches are nothing for a class 90 so you point about acceleration is a mute one.
If he's proposing using them instead of the Yarmouth drags, that includes the London-Norwich run...But this is only Yarmouth![]()
I've heard the opposite about 379's actually, that they are very nice to drive, its just when things go wrong on 379's there is rarely anything that can be done on the spot to rectify them.I don't know why on earth you think the Norwich need to be shortened at any point during the day. They are always wedged as they are coming through Colchester apart from the early morning down roads and the last London bound service but they need to be full length for their return working. Plus from what I've been told by Cambridge and Bishops Stortford drivers the 379's are rubbish. Keep the hauled sets, give them a thorough refurb, convert the DVT. Plus I've been told 10 coaches are nothing for a class 90 so you point about acceleration is a mute one.
I
Noticed a train go past SED today around 11am class 47 with a couple of carriages, odd movement it come from Derby to Norwich, it seems to have lost its way at Ely, surely it should have picked up the Breckland line
(having looked up SED- Shelford it is then) were the carriages yellow?
If they were yellow carriages, it could have been a test train, which would explain both it starting at Network Rail in Derby and it taking such a circuitous route to Norwich. There's a "FRGT" service leaving "Norwich Stn C.S.D" (the destination of that train) tomorrow morning that goes to Harwich, reverses, goes to Liverpool Street, reverses, goes to Southend, goes to Liverpool Street, goes to Barking, goes to the Gas Factory Loop, then heads into East Ham depot for the night. Very much test-train routing! Looks like it spends Wednesday on the LTS, then heads to Peterborough on Wednesday night- via Clapham, Barking, Gospel Oak and then the ECML.
Sitting at Norwich when I passed earlier this evening were:
3 Network Rail yellow carriages sandwiched between 2 DRS Cl 37's.
I cant account for the GE side but on the west anglia we have had dozens of failures recently related to GSMR radio. Basically there has been a software upgrade accross alot of the fleet and according to our fitters there were still bugs in the update which causes a GSMR failure code to arise which in turn makes the unit unfit for service. Ive had more train failures recentley due to GSMR problems than I have in past 5 years with other problems combined. 2 weeks ago there were four in one day on the 315s.
from what i hear other operators are not having the same level of problems with the radio, so sounds like bad management. That seems to be the Greater Anglia theme these days doesn't it?
That might be the GSMR network test train, that has 3 coaches and diesels each end.
I don't see how it the companies fault for the GSMR faults?
Because the majority are unit faults rather than system faults? Magic box delay codes suggest. Perhaps the fleet being thrashed to death by GAs decision to increase unit diagram availability requirement and reduce fleet has caught up with them yet again? EMU MTIN down on NXEA days all round at last period figures...
Btw has anyone noticed the little shark fin on the roof of 315's that have been modded to GSMR?
What? A lot of unit failures recently have been caused by GSMR radio problems. What unit faults are you referring to?
Its been out and about today, Cambridge to Norwich, Norwich to Ely and Ely to Middleton Towers
Greater Anglia JourneyCheck said:10:30 London Liverpool Street to Norwich due 12:31
Will be formed of 8 coaches. First class reduced. Disabled toilets are not available.
Additional Facilities Information:
No Wi-Fi or wheelchair space available.
13:00 Norwich to London Liverpool Street due 15:03
15:30 London Liverpool Street to Norwich due 17:31
18:00 Norwich to London Liverpool Street due 20:03
20:30 London Liverpool Street to Norwich due 22:31
23:05 Norwich to Ipswich due 23:50
Looks as though there's a 321 vice 90+Mark 3 on the Norwich run today:
The situation must be dire if EMUs are being used on Sundays between Liv St and Norwich, when only an hourly service is booked anyway.
According to the Class 90 Electric Loco Group website that diagram was being covered today by 90005. Has 90005 failed?
Or has the AJ1G-RFM simply been removed from the usual formation?
