Ex LNER (and Grand Central) Mark 4 sets for TfW
Steveswan10
11 Aug 2016
Herefordshire
A question out of curiosity, O appreciate that these carriages are getting on to be 30 plus years old, but are LNER suffering with as many faults with the MK4 they have left working? Just curious as to why there are so many faults/issues since they've been with TFW (No criticism of the maintenance staff intended)
SuperLuke2334
23 Oct 2021
Welsh Marches
Presumably some of the issues are to do with working with 67s rather than 91s, and having SDO fitted, neither of which they were originally designed for. Also the fact that the ex-GC sets were sat in store for the best part of 2 years when GC fell through on Euston to Blackpool, and therefore their mechanics have worsened.
craigybagel
25 Oct 2012
Indeed, the ex GC sets have definitely been more troublesome.
There's also the learning curve, both for maintenance staff and traincrew. The MKIVs have been on the ECML for 30 years - that's a lot of passed on knowledge to catch up with.
One aspect of the MKIVs that is improving is timekeeping. As crews get more familiar with SDO and the new stopping positions they have shown that with no other issues getting in the way, they are capable of keeping to the timetable - something that seemed questionable in the first week of Manchester services.
Envoy
29 Aug 2014
Yet another day with plenty of 2 car 150’s and 153’s doing the long trips up and down The Marches. Now mid February and still trouble with the loco hauled stock and no sign of 197’s arriving on this route any time soon. Surely, with some 197’s now operating in the north, more 175’s should be available? (Yes, I am aware that one has been damaged by fire).
GWVillager
2 May 2022
West Yorkshire
Considering how many diagrams that were formerly 175s have been transferred over to Mk4s, presumably creating a surplus, I'd say the issue probably isn't in 175 availability. Not sure what is keeping them from standing in for Mk4s though.
sd0733
7 Nov 2012
There's only 3 Monday-Friday and 2 Saturday diagrams (from today) which are currently Mk4s, 2 of the Monday-Friday diagrams were Mk4 anyway and with the split at Cardiff using 1 extra diagram, effectively Mk4s aren't currently freeing up a single unit compared to pre-December.
martinsh
27 Jan 2011
Considering a move to Memphis
A couple of Saturday Mk4 diagrams starting today which should be permanent:
Diagram 1
04:54 Crewe-Cardiff
08:49 Cardiff-Manchester
12:30 Manchester-Cardiff
16:50 Cardiff-Manchester
20:25 Ecs to ATC Crewe
Diagram 2
04:35 Cardiff-Manchester
08:30 Manchester-Cardiff
12:52 Cardiff-Manchester
16:30 Manchester-Swansea
21:28 Ecs to Canton
Oops.
The return 0830 Manchester-Cardiff (1V37) was cancelled at Crewe "due to a problem with the brakes".
But the 1630 Manchester - Cardiff was a MK 4 set - 67020. However, I believe this set was on the sidings in Crewe at around 1pm (that set had gone by 1700). Advertised as the "1710 to Swansea" at Crewe BTW
sd0733
7 Nov 2012
HD05 had an issue with dragging brakes. Was replaced by HD06 off the shed at Crewe on 1W59
From RTT, 1V37 was cancelled at Crewe, but the next northbound run was reinstated at Crewe with a different set (but was then turned at Wilmslow running 34 late).
So Crewe-Cardiff-Crewe and Wilmslow-Manchester-Wilmslow legs were cancelled out of diagram 2.
sd0733
7 Nov 2012
Anyone got An update on 67025? And did I see right 67029 is now with HD01?
Not heard anything about 025, would be with DB for repairs.
Yes that's right.
In Service rakes this week are:
HD01+67029
HD02+67017
HD05+67013 (spare)
HD06+67015
JakeMurphy
30 Aug 2018
S
Yes that's right.
HD01+67029
HD02+67017
HD05+67013 (spare)
HD06+67015
Seems as if HD01’s failed at Llandudno Junction
It should do, but I’m on 1W96 and I don’t fancy a unit back tonight
RTT says 1V96 cancelled Holyhead-Llandudno Jn (LLJ), but no live times shown from there.
I suppose the next tactic might be to activate the spare set at Crewe and position it to Chester to pick up the diagram on to Cardiff.
Edit:
Ah, now we have live times, 1V96 is running 34m late from LLJ.
adrock1976
10 Dec 2013
Is it the 67s or is the problem specific to the former GC stored sets?
The 67s seemed to work fine on the East Coast diversions between Newcastle and Carlisle when the 91+Mk IVs were dragged.
craigybagel
25 Oct 2012
It was a much simpler set up with the drags, those 67s didn't have any modifications and worked with the MKIVs as though they were any other kind of thing to pull.
The TfW set up is much more complicated, with push-pull working, door interlock, loco to train communications and various other goodies added on.
Also, a nonstop run from Carlisle to Newcastle at 65mph is probably less intense than the kind of work they're doing now at TfW, even if the loads hauled were heavier.
RichardTBC
18 May 2019
It's probably in a post further up, but does anyone have a list of the set formations? HD01 doesn't seem to have any numbers on one side! Thanks for any help [sorry if it's in wrong thread]
sd0733
7 Nov 2012
Many thanks for this. Assuming it's back on the Holyheads I'm going to take it for a spin. Perhaps I can figure out where the numbers on it are!
There actually aren't any on one side. Someone got a bit carried away with removing branding when they first came over!
RichardTBC
18 May 2019
So that would explain my frustrations in not finding anything bar the DVT number when it was heading through Prestatyn. Perhaps they'll add them back when it gets a lick of paint.....
sd0733
7 Nov 2012
Yes it's not you!! The TOD which has been added later still has numbers and like you say the DVT but that's about it.
Leeds1970
13 Nov 2014
why bother having the loco hauled sets?
I personally really don't see the point in having a loco and stock capable of 125 mph (yes i know the line speeds are a lot less) with first class and dining option that stops pretty much at every market town and wayside halt between Holyhead or Manchester and Cardiff. For instance on the Manchester Run let them stretch their legs and be a proper intercity - starting Manchester then Stockport Crewe Shrewsbury Hereford Abergavenny Newport then Cardiff
is it really necessary to stop at such places as Church Stretton do they generate viable passenger numbers?
Armchair Bob
28 Oct 2021
Glamorgan
HD01 12225 12454 10325 11323 + 82226
I've been trying to follow the set formations. As far as l know, all the TSOs have been temporarily removed whilst they run as 4+DVT. So they are now made up as: TSOE-TSOD-RSB-FOD-DVT. When they become 5+DVT eventually, the TSOs will be re-inserted between the TSOE and the TSOD, but not necessarily the same ones that came out of each set. My table has the sets arranged as below:
HD01. 12225 12315 10325 11323 82226
HD02. 12219 12304 10328 11324 82229
HD03. 12217 12324 10312 11325 82216
HD04. 12211 12310 10318 11319 82201
HD05. 12224 12326 10321 11320 82200
HD06. 12222 12323 10330 11321 82227
HD07. 12210 12316 10301 11322 82230
HD08. 12215 12308 10305 11316 82220
Spare DVT 82204
Donor vehicles TSOE 12229, RSB 10307, DVT 82206
This may not be 100%, as vehicles could be swapped over of course.
TSOs 12434 12452 12461 12477 (exGC ones) 12446 12447 12454 12526 (exLNER ones)
craigybagel
25 Oct 2012
The timetable is still transitioning, when the full 2tph service between Shrewsbury and Cardiff is running it should be possible to drop some of the quieter stops.
Falcon1200
14 Jun 2021
Neilston, East Renfrewshire
Because they provide a far superior level of service between two major UK cities, Cardiff and Manchester, plus other decent size places in between, eg Newport and Shrewsbury. And every time I have observed the trains on the route, usually at Crewe, they are very busy and therefore need greater capacity. Also, not necessarily what TfW intend perhaps, but they provide an example of how good interregional travel (as opposed to to or from London) in the UK could be!
BTW is there any other route with a greater contrast in the stock operating it just now? Depending which train you catch, it could be a Mark 4 set with First Class and catering, a 2-car 150, or a pair of 153s!
Yes, because there is no other service, until as @craigybagel says the TT is improved.
Fuzzytop
4 Jan 2017
They are now made up as: TSOE-TSOD-RSB-FOD-DVT. When they become 5+DVT eventually, the TSOs will be re-inserted between the TSOE and the TSOD.
I have heard that actually the TSOs will go between the FOD and DVT as: 67 - TSOE - TSOD - RSB - FOD - TSO - DVT. Reason given was that it puts the accessible areas towards the centre of the formation and therefore more likely to be platformed. I don't know if that has been reconsidered, surely it will be a quieter atmosphere in First Class if it's at one end rather than a through-fare.
Additionally during SDO mods, the FOD is being turned so the WC is now at the loco end rather than the DVT end. I suspect the TSO would be as well if it goes next to the DVT.
