Ex LNER (and Grand Central) Mark 4 sets for TfW
markymark2000
11 May 2015
Great Britain
Cardiff drivers don't sign Crewe - Chester. So unless there happens to be a spare Crewe or Holyhead driver handy, if it's got a Cardiff driver on it can't go via Crewe.
In that case, the staff onboard my service said that it was only because of the train type that they couldn't go that way so I must have had a Crewe or Holyhead crew. Depending on the disruption and availability of other staff, is it still acceptable for 1 driver who knows the train and 1 driver who knows the route to work together? Same for guards?
I suppose staffing is probably the easier one to overcome still with staff of course being flexible. If a train doesn't fit, it won't fit irrespective of what staff are onboard.
craigybagel
25 Oct 2012
In theory yes but in this particular example probably not. TfW policy is that where a 67 driver needs piloting by another driver over a route they do not sign, that driver must also be qualified to drive locomotives.
True, but it's one reason why it presumably wasn't deemed worthwhile to clear the route earlier.
ABB125
23 Jul 2016
University of Birmingham
Do they have to be specifically qualified on class 67s, or will any locomotive suffice?
And surely this policy is a bit wasteful - my understanding is that the whole point of a route conductor is that the original driver can continue over unsigned track?
craigybagel
25 Oct 2012
My understanding is it's any type of loco. That said, it's an extremely rare scenario anyway
As someone who is qualified to drive both I can see the sense in it. When I learnt 67s it felt like having to relearn my routes again at the same time as it's a very different style of driving. If you try and drive them the same way you'd drive a DMU it's not going to end well.
sd0733
7 Nov 2012
Another attempt to get HD05 off Crewe is planned to be made on Friday.
If it all works it will run as 5T96 to Chester Friday evening which then forms 20:02 Chester to Holyhead to stable there until Tuesday.
That would leave HD02 and HD03 at Crewe with one of those due to head for SDO fitting and emergency window removal next week.
SuperLuke2334
23 Oct 2021
Welsh Marches
Which windows are they removing, and why? Will it be 67020 on with HD05 and which service will it run on Tuesday due to late starting with strikes?
sd0733
7 Nov 2012
All the emergency window system (the big green boxes above the middle windows) is removed and replaced by standard glass, Its all gone on the ex GC sets and its got to be gone by Dec 31st I believe on the others.
They will normally cut out the first train each direction so would likely be doing 11:33 Holyhead-Cardiff-Holyhead on Tues and Thursday then the full diagram on the Friday finishing at Canton for the weekend.
SuperLuke2334
23 Oct 2021
Welsh Marches
That's great info thanks.
jfollows
26 Feb 2011
Wilmslow
Stop boards for the Mark 4 sets have been installed at Wilmslow station; I was waiting on the platform today and someone came along and removed the black plastic covering, then went back along the platform and took a picture of the new sign with his iPad, then went back and replaced the black plastic covering! So they're there but remain covered up for now.
GWVillager
2 May 2022
West Yorkshire
Is there any actual reason that they're still covered?
sd0733
7 Nov 2012
No longer
Believe they're no longer compliant as signed emergency exits as they can't be tested without smashing the window so impossible to know if it actually works. That's what I was told anyway!
Due to faults on 67020 it's currently touch and go if HD05 makes it off Crewe now. Depends when it can be fixed or loco changed in time
SuperLuke2334
23 Oct 2021
Welsh Marches
No longer
Oh golly that's not good news! Really hope they can get 020 going again quickly as it would be amazing to see that loco out on its inaugural run with the black set.
Please do keep us informed.
sd0733
7 Nov 2012
There's a backup plan now to send HD02 back out until Tuesday where it could be swapped onto the diagram on Tuesday evening at Chester instead.
HD02 is the set now planned to go for SDO which is required to go ASAP to get it back for December and really HD05 is wanted in service by Friday or its rememberance day wrap was a bit pointless
SuperLuke2334
23 Oct 2021
Welsh Marches
Indeed it would be. Sounds like a good plan for now and we'll see how it pans out.
victormildrew
5 Apr 2021
Shrewsbury
Reading the comments about the mk4s starting service in December, have i missed anyone saying what is the actual start date for the Cardiff/Manchester services?.
The services themselves will continue to run (albeit to slightly different timings, and with rubbish connections to/from West Wales in most hours).
In theory these will, in part, run using 3 Mk4s diagrams from December - but I won't be holding my breath!
TT-ONR-NRN
30 Dec 2016
Cambridge
I think he means the specific date for the MK4 introduction on this route, which should be the Timetable Change
SuperLuke2334
23 Oct 2021
Welsh Marches
Should be starting on the 12th December, the date of the timetable change.
I understand from a few senior staff I've spoken to on the recent training runs that it will be 2 Manchester diagrams to begin with, moving up to 3 very quickly and then 4 when all sets are back from SDO fitment.
sd0733
7 Nov 2012
Got you, hope they can fix the faults over the weekend ready to potentially be swapped on Monday (if timetable reinstated) or Tuesday.
Very unlikely to be Monday. The paths are already in for a set swap at Chester on 1W96/1T96 on Tuesday.
SuperLuke2334
23 Oct 2021
Welsh Marches
Great thanks for the update. I should see it out on Friday. Assuming 67020 is the loco with the set still or has that gone out with HD02? No allocation showing on RTT.
sd0733
7 Nov 2012
The faults were mostly with the 67 so unlikely that's been put on another set.
HD02 had an original TFW loco on it but couldn't tell you which I'm afraid. Looks as if it's cancelled now due to a fault so presume issues with both sets.
victormildrew
5 Apr 2021
Shrewsbury
Thank you for that info.
SuperLuke2334
23 Oct 2021
Welsh Marches
Ah thats not good. Hopefully things will be sorted soon enough.
warwickshire
6 Feb 2020
leamingtonspa
67020 and HD05 are finally heading into service this week. On it's way to Canton now as https://www.realtimetrains.co.uk/service/gb-nr:99448/2022-11-08/detailed.
Should then enter service on 06:45 Cardiff to Holyhead on Thursday with HD02 coming out of service on Wednesday night after arrival at Cardiff. This will then head off for SDO fitting.
Has HD01 been fitted with SDO and hopefully be back into service soon presumably?? If anyone kindly knows.
Thank you.
Jacob Porrett
28 Jan 2022
Telford
