EMR Class 360's
Supercoss
5 Jun 2016
A certain amount of shunting required to position units at new home , all visible from Depot Exit Road that runs behind platform one at Cricklewood .
OTRail
14 Jul 2019
Not the actual new home, that’ll be at Bedford. I assume their just at Cricklewood for convenience when on driver training runs.
Class 170101
1 Mar 2014
Updated list for 360's. Only 3 unit's left for 110mph mods now:
Class 360 (only showing units which have 110mph modifications)
360102 - Blue with Greater Anglia Fleet names (returned to Anglia)
360103 - Blue with Greater Anglia Fleet names (returned to Anglia)
360104 - Blue with Greater Anglia Fleet names (returned to Anglia)
360105 - Blue with Greater Anglia Fleet names (returned to Anglia)
360106 - Blue with Greater Anglia Fleet names (returned to Anglia)
360107 - Blue with Greater Anglia Fleet names (returned to Anglia)
360108 - Blue with Greater Anglia Fleet names (returned to Anglia)
360109 - Blue with Greater Anglia Fleet names (returned to Anglia)
360110 - Blue with Greater Anglia Fleet names (at Northampton)
360111 - Blue with Greater Anglia Fleet names (returned to Anglia)
360112 - Blue with Greater Anglia Fleet names (returned to Anglia)
360113 - Blue with Greater Anglia Fleet names (returned to Anglia)
360114 - Blue with Greater Anglia Fleet names (returned to Anglia)
360116 - Blue with Greater Anglia Fleet names (returned to Anglia)
360118 - Blue with Greater Anglia Fleet names (returned to Anglia)
360119 - Blue with Greater Anglia Fleet names (returned to Anglia)
360120 - Blue with Greater Anglia Fleet names (returned to Anglia)
360121 - Blue with Greater Anglia Fleet names (returned to Anglia)
Presumably this list is now out of date as some are now at Cricklewood - which ones though?
43055
8 Mar 2018
A move is planned for tomorrow to Cricklewood. The one last week was cancelled. Once numbers are known I will update the list.
anthony263
19 Aug 2008
South Wales
Rumours posted on Facebook saying the heathrow connect class 360s were going to EMR too although I thought they weren't
OTRail
14 Jul 2019
I don’t think they will personally - unless extra capacity is needed for social distancing or additional stock is needed for Corby, although this is unlikely as their won’t be enough work for 26 360s. Not to mention that the TfL units are owned outright by Heathrow as opposed to a leasing company.
Shunter_69
10 Dec 2014
Oddly enough I noticed today that the top speed label in the cab hasn’t been updated in the modified units - I’m guessing this will be changed once the units are refurbished?
They are still electronically limited to 100mph with Ga
David Goddard
8 Aug 2011
Ely
It was caused by a assumption made by someone obsessed with where they think units should go following an update the class 360 Wikipedia page that said EMR against the 360/2s. Wiki was later corrected.
D365
29 Jun 2012
Makes sense while there is a mixed fleet, and no need for 110mph capability. IIRC the Class 350/1s were all "activated" at once.
OTRail
14 Jul 2019
Today’s movement should be happening - the locos arrived at Ilford at 11.
Supercoss
5 Jun 2016
360 120 and 360 121 being formed up either side of barrier cars 64707 & 64664 hauled by 66 731 for the short trip over rooftops Ilford to Cricklewood
OTRail
14 Jul 2019
Has if left Ilford yet?
Cancelled
23 Nov 2015
Just found out the reason it was cancelled is because the wrong coupler was sent with the class 66's.
360110 heading back to Ilford tonight https://www.realtimetrains.co.uk/train/K03479/2020-11-06/detailed
Next 360 heading to Northampton tomorrow https://www.realtimetrains.co.uk/train/K03480/2020-11-07/detailed
You were a bit premature with "tonight" and "tomorrow" for those moves. 360110 heading back tonight [Friday]. One of 101/115/117 should go the other way early tomorrow.
There's also Ilford to Cricklewood paths in for next Tuesday and Wednesday next week - perhaps having another go at delivering sets to EMR. Hope they take the right coupler this time!
Supercoss
5 Jun 2016
3rd time lucky next week, a different Haulier bringing sets from Clacton EMUD after this weeks non arrival Times will be in system from Sunday late
DBS92042
13 Apr 2019
360115 has gone up today. Either the rear driving car of 360115 or 47749 had wheel flats but I'm not sure which one
Shunter_69
10 Dec 2014
Probably 115 then as one of the 360’s had a big slide on the Harwich branch last weekend.
Shunter_69
10 Dec 2014
360’s definitely do but you can still slide in any train with Wheel Slide Protection. It’s better than not having it but it’s by no means perfect.
221101 Voyager
17 Nov 2019
Milton Keynes
You can still slide in a train with both WSP and sanders.
Ok, I just thought that WSP and sanding would reduce sliding significantly.
For the incident the rails must have been really slippy and the train must have been going quite fast downhill to cause wheel flats like that. Does anyone know what actually happened?
OTRail
14 Jul 2019
I saw 115 at Colchester on Monday working between Liverpool Street and Colchester Town then the shuttle for the remainder of the day. All seemed fine with it.
Shunter_69
10 Dec 2014
Driver was approaching a permanent speed restriction, applied the break as normal and had a big slide.
221101 Voyager
17 Nov 2019
Milton Keynes
Driver was approaching a permanent speed restriction, applied the brake as normal and had a big slide.
Ah, right. Maybe the big slide occured becuase they don't have RHTT trains perhaps?
Do RHTT trains go down the Harwich branch? If not, that's proabably why it happened.
306024
23 Jan 2013
East Anglia
The RHTT does run on the Harwich branch as far as Harwich International, saw it last Monday.
