ECML disruption - broken down train near York (21/02)
Lifelong
1 Apr 2019
Hi
We’ve broken down just outside York (Peterborough to Edinburgh train). Apparently Thunderbird is coming to rescue us. Any ideas as to where it’s coming from and how long this is likely to take?
pokemonsuper9
20 Dec 2022
Greater Manchester
You'll want to look for a 1Z99 on a signal map site (like Traksy), 1Z99 is the usual headcode used for rescue locomotives.
Took a quick look around and couldn't find one near you.
Lifelong
1 Apr 2019
They're sending the one from Newark. 1Z99 is currently around the Retford area.
Thanks - forgive my ignorance but as it’s coming from South does that mean we’ll be dragged back to Doncaster or will we be pushed to York?
High Dyke
1 Jan 2013
Yellabelly Country
I can't answer that. Sorry. However, those effecting this will have a contingency plan in place. Listen out for any on-train announcements.
Northampton
1Z99 appears to have been routed via Knottingley to avoid the queue of trains stuck at Hambleton.
Quite likely given the position of your train that 1Z99 will back onto the front of your train at Colton Jn and then drag forward to York. But that's just a guess
Northampton
90 minutes later, no rescue and now apparently awaiting fitter…
1Z99 now approaching Milford Jn so not too far away, but appreciate it has already been a long time stuck and it will still take time even after the rescue is on scene.
55002
16 Aug 2019
Ldn
Rescue loco went into Holgate not Onto 1S09, been almost 2 and half hours now. Not a great response that
Lifelong
1 Apr 2019
From the train….2.45 hours now. People have been generally very calm; obviously buffet now out of food and drink. No sign of staff - though I can see there’s nothing they can really do. I think once we get to 3 hours moods will change…
Vexed
12 Jan 2020
Herts / Hants
Is it a class 800 or class 801? If it is a class 800 they could run it on diesel
801203. But is it actually a fault that could be fixed by running on diesel?
The 801s do have one engine that can be used for traction power in emergency use.
Banham7
12 Aug 2020
Lincolnshire
As it's been an extended wait, the emergency water bottle supply on board should be handed out now, or be handed out very shortly. Thankfully, a failure like this one is quite rare with the Azuma fleet (more often with the 91 fleet), I am sure Hitachi is working as fast as they can to figure a suitable solution out.
horsewalrus
24 Dec 2019
York
Not a great day at York, also saw 1S12 (12:19 to Edinburgh) cancelled (RTT reporting "problem with the on-board safety systems (M0)") and people seemingly moved onto 1S14 an hour later.
Lifelong
1 Apr 2019
We’ve had one water run. That was that.
It may be a seized axle. If that's the case the thunderbird may not be much use.
Exactly…if anyone can make sense of train movements re the evacuation, I.e when this might happen etc, your insights will be greatly appreciated
Banham7
12 Aug 2020
Lincolnshire
Newark Thunderbird 1Z99 has now released from its wait at Holgate Sidings into Platform 10 at York.
Edit: It has now gone back into Holgate Sidings...
Trainguy34
29 Apr 2023
Kent
Looks like 1S11 is now slowly moving from Hambleton Jn towards you (1S09), it can't go anywhere apart from towards you now without reversing so that might be a source of hope?
Edit: Looks like 1Z99 has also turned around in York p10, but also subsequently disappeared off Traksy so who knows :lol:
Banham7
12 Aug 2020
Lincolnshire
1S11 is heading back to Doncaster to terminate unfortunately.
10:51 Peterborough to Aberdeen due 17:07 was terminated at Doncaster.
It will no longer call at York, Darlington, Newcastle, Berwick-Upon-Tweed, Edinburgh, Haymarket, Inverkeithing, Kirkcaldy, Leuchars, Dundee, Arbroath, Montrose, Stonehaven and Aberdeen.
This is due to a fault on a train.
https://www.lner.co.uk/travel-information/travel-updates/
Peterthegreat
22 Feb 2021
South Yorkshire
IZ99 is back in Holgate....
Trainguy34
29 Apr 2023
Kent
Ah, probably just swapping lines then. That doesn't sound hopeful if they're still turning alot of trains back...
Banham7
12 Aug 2020
Lincolnshire
I would keep tabs on 5S12 (801205) as the potential unit for train-train evacuation. It was meant to be on the 12.19 York to Edinburgh, however, arrived in York from Holgate Sidings and was then cancelled because of the disruption. It's currently just sat in York Platform 11.
Segedunum
International Transport
22 Dec 2013
Up North
A crew member for this service was stuck on 1S11. When it was apparent it wasn't getting past anytime soon, 1S12 was cancelled.
FuzzyDuck
28 Mar 2020
North Hampshire
5S12 on the move
1S09 appears to be moving.
Aaron_TTL
9 Jun 2022
Wonder if its moved in time for 1V62 Edi to Exter to go the normal route as i assume its about to divert via Leeds.
