ECML delays 9/11
SaveECRewards
22 Jan 2015
There appears to be a train broken down outside of Doncaster blocking other trains going north. Can anyone provide any other info?
SaveECRewards
22 Jan 2015
1S09 is broken down just after Shaftholme jn north of Doncaster. The rescue engine has arrived to bring it back to Doncaster.
Thanks for confirming which one has broken down. I'm curious as to why this has taken so long to deal with, it seems additional issues were found when the rescue locomotive arrived. Any ideas?
TMLB UK
10 May 2010
Looks like they are sending a Leeds train around you on the slow. Literally ran out of places to loop trains heading to york now.
This is quite unusual.
gavin
25 Dec 2006
Broken down train is heading to Doncaster NB line will be reopened very shortly
gavin
25 Dec 2006
1S10 (0930 London Kings Cross - Edinburgh) now on the move to inspect the line where 1S09 broke down services held south of Donny should be starting to move shortly
Tracked
30 May 2011
53.5440°N 1.1510°W
Agreed 1S09 the failed train appears to be moving back towards Doncaster
It's been quite a while, I was on the 10:00 EDB-KGX to Doncaster, we passed by at about 12:55 and a DBS 67 was already attached, so that's about 3 hours for a train that failed 10 minutes from Doncaster (where I assume the 67's been?).
A couple of years ago I was on a train that failed at Alnmouth one Sunday, was only an hour late into Doncaster, which included a drag from a pair of 66's and 15 min's at Newcastle.
GW43125
8 Dec 2014
If it's taken a while to move after the loco has attached, that may suggest there's an air and/or other brake issue preventing movement. In which case, you're a bit stuffed.
Class315
9 Feb 2008
South of the main disruption, 1S23 15:30 London King’s Cross - Glasgow Central has come to a stand just south of the platform at Stevenage, with all services using the down slow from Woolmer Green to Hitchin.
Chrism20
27 Feb 2013
Wasn’t it an air brake problem caused by vandalism that affected the Kings Cross to Glasgow service yesterday?
I’m sure it was around the Doncaster or York area as well. Possibly related in some way?
gavin
25 Dec 2006
VT 1S23 London Kings Cross - Glasgow Central has broken down at Stevenage all NB services will pass on the slow line minor delays
jon0844
1 Feb 2009
Can admin create a new forum for ECML delays as they're a daily occurrence at the moment!
High Dyke
1 Jan 2013
Yellabelly Country
Had a text from the Mem. She advises the problem with 1S09 was a main res pipe fault. That explains the hissing air leak upon arrival back at Doncaster.
Seemingly this is the second time, that i am aware of, that problems between the failed train and rescue loco have occurred in the last week or so with VTEC.
tsr
15 Nov 2011
Between the parallel lines
The problem with the 1S09 breakdown was actually that although the fitter and rescue loco were deployed in good time, the fitter and driver had to make multiple different repairs to a badly damaged brake system before there was enough air pressure achieved to continue. There wasn’t really just one area of damage, but that fact was discovered after a substantial amount of time.
I don’t know precisely why the brake pipes (etc.) suffered quite so badly, but it adequately explains why another train had to examine the line.
800001
24 Oct 2015
And now, for the 2nd day in a row, 1S23 the 15:30 Kings Cross - Glasgow is now at a stand with a fault in the Stevenage area.
