Derby-Skegness HST
Welshman
11 Mar 2010
I might have a trip out on this service this coming summer, especially in view of the interesting routing between Derby & Grantham.
Does anyone know, please, if the first-class is de-classified on this HST, as I can't find any reference to first-class fares.
If I'm going to go, I may as well go in comfort, as I'll only be going for the ride!
The train only conveys Standard Class accommodation, therefore any coaches marked '1st' are treated as Standard Class.
Tomnick
10 Jun 2005
Looks like it's running via Melton, Peterborough and Grantham. Not sure how the dubious 1Sxx headcodes came this far without being challenged - you might end up off to Scotland!
Qwerty133
7 Oct 2012
Leicester/Sheffield
Is it stopping between derby and Grantham or are EMT doing their usaual trick where these things are concerned and forgetting about passengers from Leicestershire.
Eagle
20 Feb 2011
Leamingrad / Blanfrancisco
It's not uncommon for Class 1 trains to have interregional codes without being interregional though. For instance SWT Ascot terminators usually have 1Sxx codes. Exeter to Waterloo and Swansea to Paddington both use 1Lxx.
Tomnick
10 Jun 2005
That's true - there are probably other class 1 examples too (class 2s tend to make more use of them anyway, as there aren't so many inter-regional examples). 1S01 (to Skegness) will be right behind 1S08 (to Scotland) entering Doncaster PSB's area in this case though!
Welshman
11 Mar 2010
Yes - it should be an interesting ride through Derbyshire, Leicestershire, Peterborough & Lincolnshire!
Thank you for all your comments. :D
For the price of an off-peak return Derby-Skegness [with Senior Card], I wouldn't mind even that!
Roverman
22 Oct 2012
Can someone tell me when this service will be on? Just had a quick look at NR which seems to suggest you have to catch something called a 'bus' to Nottingham.....
Welshman
11 Mar 2010
It's intended to save those from Derby from two buses, and runs on summer Peak Saturdays during the Nottingham blockade.
Details can be found here:-
http://www.realtimetrains.co.uk/train/C82029/2013/07/27/advanced
The HST could be justified - It seems there may be more enthusiasts than holiday-makers!
Eagle
20 Feb 2011
Actually it's been running since summer 2011 (via Nottingham). It's just this year that it happens to coincide with the blockade and is diverted.
Roverman
22 Oct 2012
Thanks for that upload Welshman. Annoyingly the next free Saturday I have is 31/8 so I think I'll be asking a favour when I go to work tomorrow!!
The return at 16:40 is that the same unit?
If so this could be the makings of a 'GRAND DAY OUT' (apologies to Wallace and Gromit there)
Welshman
11 Mar 2010
Don't forget to take a "nice bit of Wensleydale" with you. :D
MidnightFlyer
16 May 2010
For anyone wanting to bash the HST to Skeg, IIRC it's also working a return to Grantham and back (ex-SKG) during its break between Derby workings.
Yes it is - 1235 ex-Skegness, calling at Boston and Sleaford only, 1412 ex-Grantham, with same calling points.
Mugby
25 Nov 2012
Derby
It seems to have quite a bit of standing time at various points.
Are these purposely inserted photographic stops?
Welshman
11 Mar 2010
Probably because of the difficulties of the route.
On the outward journey, I imagine the 6 minutes at Peterborough is to allow the driver to change ends [obviously more time needed than for a 2xcar dmu].
Then the Grantham-Skegness stretch has some single-line sections. So the 7 minutes at Sleaford could be to allow the 0915 ex Skegness clear the section from Heckington, and the 6 minutes at Boston to allow the 1015 ex Skegness to clear the section over the Grand Sluice Bridge.
34D
9 Feb 2011
Have you got the times coming back
All on [Url='http://www.realtimetrains.co.uk/search/advanced?location=Skegness&date=27%2F07%2F2013&tocs=All&timespan=3&show_schedules=11&schedule_type=0&show_wtt=1&show_var=1&show_stp=1]realtime trains[/url]
Look for the trains starting/finishing in derby and grantham.
CallySleeper
27 Jun 2006
trentbartonland
Is platform 4 at Grantham long enough?!
Would it not be more logical to give this train a 1Exx code?
louis97
14 May 2008
Derby
No in the terms that you are thinking, as that is the interregional code for trains coming south down the ECML from Scotland, as this train isn't classed as interregional the regional code for going to/from Skegness which is S is used.
Tomnick
10 Jun 2005
It is interregional - Midland to Eastern, and vice-versa on the return. 'S' is, I'm sure, only to be used for class 2 trains to Skegness.
AlexS
7 Jun 2005
Just outside the Black Country
It just means it's come from another region, not necessarily Scotland.
M = to London Midland
L = to Anglia
O = to Southern
S = to Scottish
V = to Western
E = to Eastern
It's been a bit diluted of late but by and large it still stands.
