December 2025 Timetable Change - Confirmed changes only
2 Feb 2019
Darlaston and Willenhall only have 1tph in RTT, the Shrewsbury to New Street via Tame Bridge stopper; is the Walsall – Wolverhampton avoiding Birmingham service still supposed to start in the coming timetable period?
From the following news report the train service for these two new stations has not yet been decided. Clearly they will not be open for the December 2025 timetable change so this could be something to watch for in the May 2026 timetable change.
A West Midlands Rail Executive spokesperson said there were clear proposals to introduce a second train service that has a direct connection to Walsall's main station and it was working with others to get those proposals delivered.
A Department for Transport spokesperson said: "No decisions have been made on timetables for Willenhall and Darlaston.
"We're working closely with West Midlands Trains, the West Midlands Rail Executive and other stakeholders to maximise connections for customers at the new stations."
Class 170101
1 Mar 2014
I thought it had already been decided what services were calling there. Looks like a Shrewsbury service and I thought the Crewe to Stafford service was going back to New Street via this route. I don't recall there being any direct links between Walsall and Wolverhampton via Darlaston being planned.
2 Feb 2019
The new Darlaston and Willenhall Stations are on the line used by one of the two West Midlands trains each hour between Birmingham New Street and Shrewsbury, the train that calls at Tame Bridge Parkway, so that train would just need to call additionally at Darlaston and Willenhall. AIUI the plan was always to have this and a second train service each hour at the two stations which would be Walsall-Darlaston-Willenhall-Wolverhampton so the two new stations would have a hourly train service to Walsall.
Scotrail88
21 Jul 2014
With Scarborough losing its 802s - is this to enable more ECML to Redcar be operated under electric and have faster speeds?
Kite159
27 Jan 2014
West of Andover
Logically using the 802s on Redcar services would be better than Hull. Just so it can use the wires from the Church Fenton area* to Northallerton. Reducing diesels under the wires
(* Assuming those wires have gone live and are available for 802s to change on the move)
Unfortunately the driver links at York depot are set up poorly for this. The 802 link only signs Newcastle, not Redcar. The rest of the depot (the former 68/Mk5 link) signs Redcar/Saltburn but not 802s...
td97
26 Jul 2017
The difference in electrified mileages for each route is
  • Hull to Liverpool
    • Liverpool to Stalybridge (39mi)
  • Redcar to Manchester Airport
    • Stalybridge to Manchester Airport (21mi)
    • Church Fenton to Northallerton (40mi)
Danfilm007
5 Jul 2015
There's hardly any difference between using bi-modes for
  • Hull to Liverpool
    • Liverpool to Stalybridge (58mi)
    • Church Fenton to Northallerton (40⅓mi)
But those kinds of distances are still quite reasonable for running electric vs diesel?
Scotrail88
21 Jul 2014
  • Hull to Liverpool
Thanks
Suppose irrespective of which alternative, there is a fair amount more benefit of the 802 on those than Scarborough
Class 466
5 Mar 2010
Atherton, UK
Thanks
Definitely- but you need to disregard crew training and depot locations in the process as both are currently incompatible with putting an 802 on Manchester Airport to Redcar services.
DazCM
29 Apr 2010
Southern changes have appeared online at
The one that had piqued my interest is the re-introduction of half hourly services on the East Grinstead branch during Monday to Friday daytimes, but apparently only during school holidays. During term time it says half hourly on Thursdays and Fridays only.
How’s that going to work then?
HamworthyGoods
15 Jan 2019
I’m unsure how what you’re asking how will this work?
The trains will run on all Thursdays and Fridays and then additionally on Mondays to Wednesdays during school
Holidays.
Holidays.
There does come a point when one has to ask whether the extra complexity, both operationally and for the user, is worth the cost saving.
DazCM
29 Apr 2010
Holidays.
Sorry, my poor choice of phrase.
I’ve just never known the railway to differentiate services between school holidays and term times to such a massive extent before.
dk1
2 Oct 2009
East Anglia
That’s very much a bus thing and causes much confusion and inconvenience.
Does it though? Most rail passengers use a journey planner these days, so you could make it different every day of the year and people probably wouldn't really be that bothered.
For buses by contrast people tend just to go to the stop around the time they usually do and are confused if a bus doesn't show up.
Commuters are likely to be somewhat more confused. I don't look at a journey planner every day just whether the train is running or not! So I'd be somewhat irritated if I had to remember five different (ten in reality with the journey back) departure times!
True, but these journeys are off peak so don't really affect commuters in the traditional sense.
FWIW these days I do look at Realtime Trains to check for short-forms or cancellations before going out just in case those might make me change my plans!
dk1
2 Oct 2009
East Anglia
It’s the throwing the regular timetable out that makes it a pain. When you know there’s a service at say 18 past each hour then suddenly no 15:18 its a pest. I personally have no idea when school holidays are apart from roughly Summer & Christmas. Railways just usually run everything regardless which is great.
Horizon22
Jobs & Careers
8 Sep 2019
Is it that complex? You can easily build diagrams for each day, it probably just needs some changes for Monday mornings and Wednesday mornings respectively, which is probably a diagram or two from Selhurst amended. Nothing too complicated.
These appear to be off-peak amendments only though, so commuters will not generally be impacted. If it is part of the LTP then it will be fine, but no doubt some local publicity would be helpful so as to not catch some people out.
Which arguably isn't always ineffecient and for lightly-loaded trains and might be an "quick win" saving, even if relatively minor.
At least this is bring back some trains (if not all) as opposed to removing trains.
mangyiscute
6 Mar 2021
Reading
Plenty of train companies offer summer-only services, which I'm sure some year-round travellers get and then get confused about where their train went—it's just natural for public transport operations. We need to be more flexible to adapt to changing travel patterns.
jfollows
26 Feb 2011
Wilmslow
Perhaps, but saying “only during school holidays” is vague and confusing.
There are many of us who have no interest or knowledge in when schools are on holiday, so I trust it’s clearly communicated in actual timetables in proper terms. I’m assuming the phrase was only used to summarise the particular timetable change.
D1537
11 Jul 2019
North Yorkshire
Holidays.
Let's hope that none of the stations served by those trains are on the border of two counties that have, for example, different Easter school holidays next year, then - that could get confusing for people.
Like, for example, East and West Sussex...
Magdalia
1 Jan 2022
The Fens
This is an interesting development, and it will be interesting to see if it happens elsewhere.
Here in the Cambridge area train usage is very different between term time, when the railway has lots of students travelling to/from college, and school holidays, when there are a lot more young people and families making leisure trips, especially to/from London.
But my experience is that the operators will struggle to run more trains in school holidays because they won't have enough drivers. In particular the drivers with children will be wanting to do the leisure trips, not drive the trains.
dk1
2 Oct 2009
East Anglia
That seems to be much more a GTR problem than a GA one.
HamworthyGoods
15 Jan 2019
The use of school days / school holidays is already often used by public transport operators, it’s a very common differential used by bus companies.
Buses are the most heavily used form of public transport in UK so if their users can cope I’m sure so can rail users.
D1537
11 Jul 2019
North Yorkshire
As I mentioned above, school holidays can change across county boundaries. This usually isn't an issue with local services such as buses (and a lot of their services are specifically school services anyway).
sjm77
8 Jan 2020
Manchester
  • Hull to Liverpool
Actually I think that Liverpool to Stalybridge is only 39.5 miles
