Class 810 for East Midlands Railway Construction/Introduction Updates
43102EMR
28 Mar 2021
so far no announcement on thetrain about any swaps. what is the issue?
Sitting in coach A, the HVAC drone seems noisier than other 80x classes.
Based on experience they usually do this right before the stop it’s about to get swapped at
I've been informed they are trying to sort the issue out on the move to prevent the swap from happening
Apparently 810010 had this done yesterday and it worked, so fingers crossed
Railperf
30 Oct 2017
what is the issue?
liamf656
2 Aug 2020
Derby
Both accessible toilets OOU based on the above
Toilet door issues. They managed to fix it on 010 yesterday, today they are monitoring it and probably biting their nails over it! Hopefully they can revert to rest of the diagram back to 810 before it gets to Derby
As a side note I'm not 100% sure if it's both or just the one in coach E (the most important one as the only wheelchair accessible areas are in that coach)
43102EMR
28 Mar 2021
Fingers crossed!
I did see on EMR’s website that there were no accessible facilities available, so likely both
Railperf
30 Oct 2017
front accessible loo was working at st pancras before 1132 departed ; faultless so far approaching Leicester, but the lack of through tracks due to BR rationalisation means we will crawl behind some late running freight!!
Engine noise partially drowned out by the loud HVAC. HAVC almost as noisy as Class 360 desiros.
43102EMR
28 Mar 2021
Any updates? Still can’t see a path into Derby from Etches Park so assuming efforts are still ongoing to fix it?
Railperf
30 Oct 2017
Investigation over!
confirmed unit will go all the way to Sheffield by TM. now behind the Matlock. Unit seemed to have acceleration issue from Loughborough, acceleration suddenly stopped after apparent wheelslip, eventually resumed, but not to 222 standards. Start from East Midlands more restrained, as if drivers start to apply full power, then ease off. It is wet today. Now an extended stop at Long Eaton - though line ahead is now clear. Looks like Hitachi people heading to cab.
BuhSnarf
22 May 2010
Leicester
There were a couple of people in the cab as it departed EM Parkway.
What time is it due to come back south?
Railperf
30 Oct 2017
Due on the 14.00 from Sheffield but, it won't get there for the return trip at this rate. Hitachi individual hurriedly running back down the train from cab.
43102EMR
28 Mar 2021
There’s a late running XC Voyager in front of it as well, which probably isn’t helping
BuhSnarf
22 May 2010
Leicester
The return trip is showing as cancelled between Sheffield and Derby.
Is it being turned around at Derby or swapped to a 222 there for the return journey?
LowLevel
26 Oct 2013
It's running empty from Sheffield to Etches Park and 222004 is restarting the diagram from Derby.
Railperf
30 Oct 2017
I am guessing it will terminate at Sheffield. The 1400 cancelled and the 810 will most likely head back to the depot. A 222 will be inserted at Derby for the rest of the diagram?
Bellecat
12 Feb 2022
I am guessing it will terminate at Sheffield. The 1400 cancelled and the 810 will most likely head back to the depot. A 222 will be inserted at Derby for the rest of the diagram …..
Bad luck for me if so. Hey ho. Will try again tomorrow here in Nottingham!
Railperf
30 Oct 2017
Not a good day for 810006. More issues under power leaving Chesterfield again. These are the sort of issues that should be ironed out in testing. This is not caused by passengers being on board. If anything a train full of passengers should aid adhesion.
BuhSnarf
22 May 2010
Leicester
That's a shame, was hoping to catch it again on the way back. Guess I'll have to wait till next week now and hope for better luck!
Nottingham59
10 Dec 2019
810s have two only powered bogies per unit. I'm not surprised if they're having adhesion issues accelerating at low speeds
43102EMR
28 Mar 2021
Exactly what happened, 222004 took over from Derby
