Class 707 - SWT: Introduction into service
spark001uk
20 Aug 2010
More 458 on Reading then, nice. Quite like them on the Reading turn, always have. Passengers seem to be ok too (apart from one or two suits I've heard moan on entering the 1st class.)
I must say though, unsure if coincidence, but since SWR took over the toilets on them seem to be more frequently operational. ;)
They should appreciate it while they can. End date Dec 2018 for First Class on entire Windsor side including Readings.
TEW
16 May 2008
All 3 707 diagrams running today:
707008+707005 Diagram 1
707003+707004 Diagram 2
707011+707012 Diagram 3
GW43125
8 Dec 2014
2S41 14:22 Waterloo-Weybridge was a pair of 458s this afternoon instead of the usual pair of 450s. Is this a permanent move as a result of the cascades resultant from the 707s or just an unreported one-off?
TEW
16 May 2008
Appears to be booked this week at least. That diagram starts with the 0609 Reading-London Waterloo. Usually that set comes empty from Farnham Depot and is formed of an 8-450. This week it is stabling at Reading overnight. The stock works the 2220 Waterloo to Reading the stables. The 2220 is being formed of the 10-458 off the 2156 arrival at London Waterloo from Weybridge this week. I'm not sure if this is temporary or a permanent change that hasn't been reported yet.
TT-ONR-NRN
30 Dec 2016
Cambridge
It said above full first class on Windsor side 2018; surely the 707s aren’t going until the aventuras enter service?
Domh245
6 Apr 2013
nowhere
I think you are misreading it. It says "End date Dec 2018 for First Class on entire Windsor side including Readings."
ie, after 2018, there'll be no first class at all on the Windsor side.
GW43125
8 Dec 2014
It states quite clearly in the consultation document that first class on the reading route will be permanently discontinued as of December 2018.
TT-ONR-NRN
30 Dec 2016
Cambridge
Ohh, ok! So what will happen with the 450s then, permanently removed from the Reading side?
And if that’s the case why are the ex458/0s having their first class reinstated?
Domh245
6 Apr 2013
nowhere
They'll just run around declassified, as they've done previously. And the 458/5s are having first class reinstated because they'll be operating services with first class provision for at least a year.
The 450s displaced from the Reading route will be used to replace the 456s off the Guildford Ascot shuttles, and to strengthen 450 operated services all over the mainline side that do not already run as maximum length.
Apologies to some members for having to repeat this yet again, as it has been mentioned numerous times already...
Because between now and Dec 2018 first class will still be available on the Reading route.
GW43125
8 Dec 2014
2S41 was today a single 458, may be related to the chaos at Wimbledon Panel earlier (A lot of Weybridges were cancelled outright).
7028+7029 were running the standard Staines Loops<->Reading test paths today.
spark001uk
20 Aug 2010
Today's 2S55 canned at Vauxhall, door fault. No replacement available, thus 2S64 canned also.
Mordac
5 Mar 2016
How are these being received by passengers? Anyone’s impressions on comfort? Interested how they compare to the 700s and 345s...
GW43125
8 Dec 2014
Same seats as the 700s, different colour. Ascot to Staines was about the most I could manage.
Goldfish62
14 Feb 2010
So if all goes well then, this should be the state of play tomorrow.
707
Diagram 1
5U07 0502 Wimbledon Park Depot-London Waterloo
2U07 0558 London Waterloo-Windsor & Eton Riverside
2U14 0721 Windsor & Eton Riverside-London Waterloo
Repeat every 2.5 hours until
2U67 2058 London Waterloo-Windsor & Eton Riverside
2U74 2221 Windsor & Eton Riverside-London Waterloo
5Y80 2332 London Waterloo-Wimbledon Park Depot
Diagram 2
3F09 0500 Wimbledon Park Depot-Guildford
9D10 0558 Guildford-London Waterloo via Epsom
9F09 0720 London Waterloo-Woking
9F96 0817 Woking-London Waterloo
3Y83 0914 London Waterloo-Wimbledon Park Depot
5V47 1610 Wimbledon Park Depot-London Waterloo
2V47 1637 London Waterloo-London Waterloo via Brentford and Richmond
2R53 1815 London Waterloo-London Waterloo via Richmond and Brentford
5Y36 1955 London Waterloo-Clapham Yard
Diagram 3
5H91 0602 Clapham Yard-Shepperton
2H92 0700 Shepperton-London Waterloo via Richmond
2R13 0815 London Waterloo-London Waterloo via Richmond and Brentford
5Y24 1000 London Waterloo-Clapham Yard
5V39 1356 Clapham Yard-London Waterloo
2V39 1437 London Waterloo-London Waterloo via Brentford and Richmond
2R45 1615 London Waterloo-London Waterloo via Richmond and Brentford
2S55 1752 London Waterloo-Weybridge
2S64 1937 Weybridge-London Waterloo
5Y92 2112 London Waterloo-Wimbledon Park Depot
458 to Reading
Diagram 1
5N92 0642 Farnham Depot-Farnham
1N92 0651 Farnham-London Waterloo via Ascot
2C83 0837 London Waterloo-Reading
2C28 1009 Reading-London Waterloo
2C31 1150 London Waterloo-Reading
2C42 1339 Reading-London Waterloo
2C45 1520 London Waterloo-Reading
2C56 1709 Reading-London Waterloo
2C59 1850 London Waterloo-Reading
5C60 2020 Reading-Farnham Depot
Diagram 2
5C87 0534 Farnham Depot-Reading
2C88 0654 Reading-London Waterloo
5Y17 0942 London Waterloo-Clapham Yard
5C55 1726 Clapham Yard-London Waterloo
2C55 1750 London Waterloo-Reading
5C56 1920 Reading-Farnham Depot
450 on Guildford-Ascot
Diagram 1 (Always Been a 450)
2N51 1838 Aldershot-Guildford
2N64 1900 Guildford-Ascot
2N61 2023 Ascot-Guildford
2N74 2130 Guildford-Aldershot
5N67 2155 Aldershot-Aldershot via Guildford
2N67 2238 Aldershot-Guildford
2N80 2300 Guildford-Ascot
5C74 0017 Ascot-Farnham Depot
Diagram 2
5N06 0528 Farnham Depot-Ascot
2N05 0623 Ascot-Guildford
2N18 0730 Guildford-Ascot
2N15 0853 Ascot-Guildford
2N28 1000 Guildford-Ascot
2N25 1123 Ascot-Guildford
2N38 1230 Guildford-Ascot
2N35 1353 Ascot-Guildford
2N48 1500 Guildford-Ascot
2N45 1623 Ascot-Guildford
2N58 1730 Guildford-Ascot
5N59 1858 Ascot-Aldershot
2N55 1938 Aldershot-Guildford
2N68 2000 Guildford-Ascot
2N65 2123 Ascot-Guildford
2N78 2230 Guildford-Aldershot
5N79 2256 Aldershot-Farnham Depot
Reading Diagram 2 is 450-operated this morning.
TEW
16 May 2008
The Windsor 707 diagram is not running today either. First round trip cancelled with the rest of the diagram formed of 8 coaches instead of 10.
fairysdad
27 Dec 2010
London, Surrey... bit of a blur round here...
707
Diagram 2
I realise that this is a few days old now; is this the general diagrams for the 707s at the moment? In other words, is the highlighted by me service (the 0558 Guildford-Waterloo) likely to be a 707 during this week? (If I can get away with being late for work to satisfy my rail enthusiasm...!)
TEW
16 May 2008
Still correct this week as far as I am aware. The 0558 Guildford-Waterloo was definitely a pair of 707s today, as the return working to Woking was reported as breaking down at Wimbledon causing chaos.
