There's a set waiting at Dollands Moor at the moment, I believe, due to be delivered tonight (as in Friday night into Saturday):Is there a delivery to Clapham Yard this weekend?
5V39 1356 Clapham Yard-London Waterloo
2V39 1537 London Waterloo-London Waterloo via Brentford and Richmond
2R45 1615 London Waterloo-London Waterloo via Richmond and Brentford
2H92 0700 Shepperton-London Waterloo via Richmond
2R13 0815 London Waterloo-London Waterloo via Richmond and Brentford
5Y24 1000 London Waterloo-Clapham Yard
2S55 1752 London Waterloo-Weybridge
2S64 1937 Weybridge-London Waterloo
Yes I do, thanks for spotting that.Can I just check - do you mean 14.37? Based on the time of the ecs and how tight that looks between 15.37 and 16.15?
It should do, haven't seen any turns suggested though.Presumably this will release a second pair of 458/5 for the Reading line - if so, does anyone know which turn?
http://www.realtimetrains.co.uk/train/R90256/2017/10/13/advanced
Yes, the working to Clapham has been cancelled now too. It was only activated at 4.19 this afternoon too! Unless that process is automatic that is.For anyone interested - the working from Wembley to Dollands Moor to collect this seems to have been cancelled, not sure if this means it's off for this evening.
Is now set to run today (in daylight!)Yes, the working to Clapham has been cancelled now too. It was only activated at 4.19 this afternoon too! Unless that process is automatic that is.
Once all of the 707s are in traffic, will there still be a need to run 455s and 450s on the Windsor side or will they all go to the main line?
cancelled again!!Is now set to run today (in daylight!)
http://www.realtimetrains.co.uk/train/O35051/2017/10/14/advanced
3973EXL beat me to it!
56312 & 081 in charge, should have been 47813 & 848 except 813 had wheelslip issues at Sharnbrook this morning.
Reported elsewhere as being 301 not 312. No idea which is correct.
*EDIT* Just seen a picture of 301 with 081
Short term a number of 450s will have to stay on the Windsor side as Basingstoke Depot do not currently sign 707s and they have several jobs that take them to Weybridge via Hounslow and to Staines.
Here they are passing me in south london just now
@Domh245 is right. The braking system on the units isn't operational at that stage, so the wagons brake for it.Anyone know why the 707s were being moved with containers at both ends of them?
Not sure, there's engineering up at Waterloo again this weekend. Funny thing is this weekend the hourly Woking via Hounslow loop services are being worked by 455s, not 458s. Wonder if it's because they're needed elsewhere? Wouldn't have thought so though, as Sunday services generally require less stock if anything?Hello, are there (or will there be) any Class 707 services on weekends, particularly Saturdays?
Thanks.
The rest have been 455s though, I didn't even have to get up and go outside cos you can hear those horrendous kiepe motors a mile away!It was a 458 on the 07:52 Woking - Waterloo this morning![]()
