Class 707 - SWT: Introduction into service
HeelBurton
10 Mar 2014
Wembley
Has anyone told the guards????
No idea mate. I just know a few diagrams have been amended to show they are 707's instead of 458's. One of them in particular I have seen is the 1828 Windsor and return. 2U57/64. The driver was told by a manager, unsure about the guard.
Sent from my iPhone using Tapatalk
TEW
16 May 2008
I saw a bulletin in the New Notice Case this morning, so they should be aware. Also mention of a 458/5 diagram on the Reading Line from Tuesday, starting with the 0651 Farnham-Waterloo via Ascot.
SpacePhoenix
18 Mar 2014
Have all drivers and guards that could potentially work the 707s had all their training yet?
pompeyfan
24 Jan 2012
Worth bearing in mind too, that no one should ever get rostered to pick up traction they don't sign, usually someone else will pick up the duty with 36 hours notice, and if rosters have dropped the ball then crew should speak to the resource manager at the first opportunity. The last thing they want is for a train to be sat waiting blocking a station while they find any available bodies that can move the thing.
Feathers44
12 Aug 2014
Why do you ask? Do you think SWR would ask untrained staff to operate these trains?
That's a bit improbable isn't it? The more likely reason for asking such a question is to explore whether the service of the new units is dependent on a limited pool of trained staff.
class387
9 Oct 2015
They are, going down and up Windsor from today.
Only issue today was a train fault so Windsor lines are massively disrupted.
So they ran today? (The diagram posted said from Tuesday)
Was it running to the diagram posted? If not, what runs did it do?
Also, was it the 707 that failed?
D365
29 Jun 2012
It does also tie into how many drivers they can take out of service at a time for training.
Monty
12 Jun 2012
A little over half way for the guards, traction training resumed this morning after a break during the Waterloo works.
spark001uk
20 Aug 2010
No, a (presumably) 458 on a Weybridge gave up just outside Feltham at about 7:30 this morning.
And in true swt style they turned everything for Waterloo round at Staines and down the Weybridge branch, sailing through every station on the branch leaving pax there with no service at all. They do it every time. Being SWR hasn't changed anything!
FenMan
13 Oct 2011
Weybridge - Virginia Water and Ascot - Aldershot -Guildford were just annoyances to SWT. Will SWR take action to regain customer confidence on these lines? I doubt it.
Tom m
28 Mar 2016
Confirmed running this morning, saw a set on a 6:30 ish departure from staines towards Windsor
spark001uk
20 Aug 2010
707004 and 006 at Richmond just now on 2U27. Both with SWR branding on.
Why ever would you expect the same control staff, and same signallers, to come up with a new and different plan? They've been doing the same recovery procedures for 20 years or more.
spark001uk
20 Aug 2010
Well the SWR suit at Waterloo launch yesterday promised all these sorts of issues are going to be ironed out, so we shall see.! ;)
spark001uk
20 Aug 2010
Is the 17:23 running tonight from Windsor. Hope to pick it up somewhere
Hopefully, the diagram was running fine earlier, as of when I posted pics. I may jump on the following working (1828 ex WAT), curious to see how the units cope with a peak(ish) load.
Edit: yep just checked rtt, so far so good! :touchwood:
ohnonotagain
15 Aug 2017
I usually get the 1843 from WAT to STW, but I'm thinking of leaving the office a little earlier to get the 1828 to WTN instead. I'm not saying anything at work, but I hope I'm among friends here... :D
spark001uk
20 Aug 2010
Also is there a way to check in Realtime trains what train class it will be for future use?
Not really no. At the top of each working it shows you, but all it usually says is "electric multiple unit", that's about all you'll get.
i26
5 Sep 2017
RTT Shows that they are doing tests throughout the night between Barnes and Reading until 4
Are they still running today?
