Class 395s and HS1
Bungle73
19 Aug 2011
Kent
These are restricted to 125mph in service, correct? What is the actual reason for this?
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
They're limited to 140 mph on CTRL Track (HS1) and 100 mph on standard 'conventional' tracks :smile:
TP
Bungle73
19 Aug 2011
Kent
They're limited to 140 mph on CTRL Track (HS1) and 125 mph on standard 'conventional' tracks :smile:
TP
Are you sure about that? I'm pretty sure 3rd rail lines cannot handle 125mph trains, and the limit there is 100mph.
starrymarkb
4 Aug 2009
Exeter
This seems to be a myth that comes up every so often. They are using 225km/h on a regular basis on HS1.
And I presume 125mph would be the max speed on AC on the classic network
Monty
12 Jun 2012
That may be true, however the maximum on conventional AC lines is 125mph and while they do not run on those lines in normal service there is nothing to stop them running at those speeds if they did.
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
Of course that is subject to line speed restrictions.
TP
Correct but TP's point was if the conventional track could handle a train at 125mph then that would be the limit. Obviously if the maximum linespeed is lower then the top speed of the 395 is academic.
district
4 Aug 2011
SE16
Speeds on HS1 are in proper measurements. They are limited to 225kmh (~140mph) on CTRL and 100mph on Network Rail lines.
The attached image is the sticker from a 395's cab.
ryan125hst
2 Jun 2011
Retford
Presumably, they are limited to 100mph on National Rail lines as they are only cleared to run on third rail lines, which have a maximum speed of 100mph.
If they were required to work on AC lines, unless there are other factors involved, I would imagine that they would be able to run at 125mph (on the ECML for example).
Peter Mugridge
8 Apr 2010
Epsom
That should be that cleared up once and for all then!
Although are they timetabled for 125mph or 140mph? ;)
I believe the timetable can be maintained with 125mph running, but every 395 I have ever been on ( on the HS1 sector ) has run up at least to 135mph and most have touched the full 140mph.
Bungle73
19 Aug 2011
Kent
OK, thanks. I was discussing it with some people on FB and wanted to check my facts with the experts before proceeding any further. ;)
rebmcr
15 Nov 2011
St Neots
Not necessarily. The NoL 373s were limited to 110mph on the ECML due to power supply limits.
A-driver
9 May 2011
There are stretches of track south of Grantham where they can run up to line speed-there are blue 'TGV' signs indicating this-one by hitchin and one in the stookley bank past Huntingdon.
ryan125hst
2 Jun 2011
Retford
GNER 91128 said:
Really? I can imagine nervous kittens when one went through Hitchin or through the fens. :lol:
What? I was referring to the fact that they are only allowed to travel at 125mph south of Grantham. They are restricted to 110mph north of Grantham. (Well, they were. They aren't used on the ECML anymore).
TGV
25 Nov 2005
320km/h Voie Libre
One more time: 373/2 sets were initially restricted to 110 and later cleared for 125 where permitted, South of Grantham. The reason was pan head / catenary interaction. I worked on the job.
395s as said, do run at the full 225 on CTRL but still manage to get in the way very often.
