Wow, that was a helpful answer. Thank you Malaika. Would you also guide me for practice material what you referred to and how did you find all these exams. Did you give the exam recently?yes these all are paper based, group bourdon is finding 4 dots on a paper having 5 parts each part consists of like 20-22 lines accuracy and speed matters, trp1b is the memory test they give you a sheet to read for like 5 mint after that they take it from you let you sit for 2 mint and give you 18 MCQs to solve from the passage(they will take that sheet back) you should remenber all the key points, TRP2 is is the sounds and symbol consists of 3 parts in part one you have to count low beats there will be two beats high and low you have to count low ones in part 2 you have to circle the the matching symbols on a sheet in 45 sec, part three there will be just one beat you have to count and aswell as circle the symbols, and there is a dial and lever you have to solve like 43 mcqs in 8 mint they tell you everything about it and give you 3 practice questions in all the tests. hope you find it helpful
Do you have any practice material for VSE or any near to the acctual test material I can find online you know of??
Appreciate your response.
