CAF class 197 Civity for TfW: News and updates on introduction.
Jacob Porrett
28 Jan 2022
Telford
When 197041 is delivered, it will be the only "2026" 197, and I believe it will also be the only "2026" pure diesel multiple unit!
If there's no "last Class 197 rolls off the production line" article it will require Freedom of Information I guess, but the 'Constructed' range of years in the infobox of the 197 Wikipedia article will say "2020—2026". Quite a long amount of time really, isn't it?
Will be the last 197 to come through Donnington RFT as well hopefully.
sbrignall72
3 Jun 2020
Brough
Does anyone please know when 197126 is likely to be repaired after it's altercation with a tree. Is it still on Chester depot
40029 Saxonia
31 Jul 2024
Flintshire
Passing Crewe today, 197040 was visible at the south end of the TfW/Ariva depot. Several 197s (approx. 5) were in Crewe South Yard but the only one I could identify (and that's not 100% certain) was 197039. If anyone knows which ones were in Crewe South yard at 12:15 today it would be appreciated. Its assumed they were 23/25/32/38/39 but I have no proof of that!
Gordonman
14 Jan 2020
Baildon
16/01/2025
197029 197030 5Z90 Holyhead - Shrewsbury sidings
197114 is back in service today.Was stopped on Crewe Electric depot on 10/09/2025
197023,197025,197032,197038 and 197039 were moved from Crewe South yard to the LNWR depot for further storage over the Christmas/New Year period.197040 remained in the south yard.
The moves between the south yard and LNWR and vice versa are very rarely shown on Trust so unless there are any visual sightings usually go unreported.
The units moved to LNWR for storage were all in a line on the first line inside the depot,so would be visible from passing trains through the gaps in the wall unless there was stock parked up outside next to the mainline which would block the view.
Perhaps Jacob could advise if these units are still on LNWR or have moved back to the south yard?
Caaardiff
9 Jun 2019
16/01/2025
197025, 032, 038 and 039 are at South Yard
197040 is at LNWR
Not sure about 197023
Jacob Porrett
28 Jan 2022
Telford
16/01/2025
I'm sorry to say but unfortunately I no longer work at Arriva TrainCare Crewe so I don't know what's around anymore.
tfw756rider
30 Nov 2024
Wales (sometimes in England), thanks for replying!
3C01,3C02 and 3C03 worked on the 6/1/26 with 197029 and 197030.
3C02 and 3C03 then ran on the 7/1/26 but as a 2-car. but I didn't know whether it was 197029 or 197030.
It was 197029, I went back to see it.
Very Short Term (Plan) schedules for 3C02 and 3C03 to Pwllheli and back for the 8/1/26 were added, but then removed again before they would've run, due to the bad weather.
197029+197030 went off the Cambrian on the 9/1/26 as:
...and went back onto the Cambrian on the 17/1/26 as:
So far, the following driver training schedules have been put on the system for the next week:
Peter Sarf
Croydon
Thanks for finding. I was not getting anywhere looking for runs today or tomorrow !.
These two 197s (197029 & 197030) appear on RTT so I assume they are accepted by TfW ?.
EDIT
Corrected 197/1 to 197/0 (brain fade).
Since this is driver training I hope that means entry into service on Cambrian Coast within the next six months (otherwise driver competency lapses) ?.
tfw756rider
30 Nov 2024
You're welcome - someone I know told me that he saw 197029+197030 at Machynlleth on the 17/1/26, so I looked for schedules.
Yes, 197029 and 197030 are accepted by Transport for Wales. The first 13 minutes of the video below show them:
  • On November 2025 pre-driver-training check runs (stopping points, train-platform step measurements etc.) at Aberystwyth, Bow Street bridge, Talybont (Gwynedd) and Caersws
  • On December 2025 driver training runs at Borth (9 minutes in), and 'Picnic Island' near Aberdovey
Regarding six-month driver training competency:
Even if the units don't come into service quick enough for a driver to maintain competence, this isn't unchartered territory. If you do lose competence, it's only a 1 day refresher to regain it rather than the full 5 days from scratch. This was required for a few drivers at other depots, when mass 197 training started quite a while before they eventually entered service. Better to have drivers trained too early than too late!
I believe that 197 Cambrian service is estimated to start in late Summer 2026, but if the above information applies, it's not the end of the world as I understand it.
Peter Sarf
Croydon
Thanks.
(corrected my post to reflect correct sub class).
I had not taken in that Summer 2026 was a possibility for Cambrian services to switch over to 197s. Subject to slippage of course.
Peter Sarf
Croydon
That's what I heard, I just didn't want to say it until someone else did.
I expect the dependencies will be :-
398s into service on the TAM lines.
756s moved to Rhymney Valley and VOG etc.
Improvements in availability of 197s *.
How many 150s will be kept beyond the first two unless 197 availability improves (or some 158s continue on Cambrian but not expected).
* = I am assuming that 197 availability is not quite what is expected yet BUT I may be wrong ?.
Jez
22 Jan 2011
Neath
197 availability does seem to have been better recently. Ive not noticed many substitutions. It helps that the MK4a are behaving at the moment too.
Obviously we still have quite a few Cambrian units helping out but on paper I think those are covering the fact we have 197s doing work intended for the 231s long term.
BillStampy
6 Jan 2024
Llanharan
You've said it now, we're all doomed! Cue the reliability falloff! :lol:
In all seriousness it does seem to be going very well for both fleets at the moment and they're still substituting for the 230s. Overall I think it's going quite positively!
Peter Sarf
Croydon
Some of the long term stopped sets are starting to come back into service.
I suppose that may be a good indication that Chester is able to cope with the fleet size these days.
I am assuming Machynlleth will help with the extra Cambrian 197s but to what level I do not know.
WirralLine
4 Jun 2024
Wirral
Im sure it was mentioned here that Mach would be doing the general maintenance and light repairs on the Cambrian 197s, with Chester being used for large jobs.
A few things I have noticed - the "older" 197s ie the ones introduced early on, are starting to look shabby inside. Ground in dirt around the windows (a matt, textured white surround on the windows seems a bad idea to start with when it comes to ease of cleaning). A number of broken/damaged seat tray tables. The carpets are torn/fraying in places and looking a bit worn down in the well used parts. Not to mention the toilet doors still dont work properly on any of them.
XFeed
25 Nov 2025
Chester
The toilet modules/control systems including the toilet doors have practically been an issue from the beginning and have been pretty unreliable with Rolen the toilet module supplier issuing numerous software updates and corrective actions.
Jez
22 Jan 2011
Neath
Haha! Hopefully not!
Ive not really noticed any major issues with the older ones but next time i go on one I will be sure to have a look. I am guessing it will be a long time before they are due for a refresh however. Definitely noticed the issue with the toilets however, id say nearly every time ive travelled recently there has been an issue with 1 or more toilets.
tfw756rider
30 Nov 2024
Still more to go, hopefully? Also, do you know if there are any plans to sort out any loose seat-back tables that open themselves, and toilet lids/seats that don't stay up?
XFeed
25 Nov 2025
Chester
Numerous rectification campaigns are developed but do not know any timescales about the faults you raise sorry.
BenBracken
27 Oct 2019
Pembrokeshire
I travelled on an SWR Arterio unit last summer and noticed the toilet setup was identical so guessing the same supplier? All seemed to be working perfectly, have there been issues elsewhere on other operators?
XFeed
25 Nov 2025
Chester
I don`t know if other fleets have the same toilet manufacturer as 197s but I am led to believe 195s are a different supplier and are more reliable ?
Maybe more knowledgeable people than myself who are familiar with different fleets can chip in with the answers.
tfw756rider
30 Nov 2024
Carry your own Allen keys
Well I suppose that's one way of doing it :p
The above 4 workings all ran, with 197029+197030.
10 more schedules are on the system:
BenBracken
27 Oct 2019
Pembrokeshire
Just got this photo off the TfW enthusiasts FB page taken at Llandeilo JCN. So 197s are using SDL whilst Landore Bridge is closed. I had thought TfW were just putting buses on! Hadn’t realised 197s were cleared for SDL and driver training etc had taken place. Be great to know which services use it usually, everytime I’ve tried recently the service just goes round the back of Landore depot!
Rhydgaled
25 Nov 2010
There don't appear to be many diversions over the SDL though compared to when the Loughor viaduct was replaced back in Arriva Trains Wales' time. Tomorrow for instance there don't appear to be any through trains Carmarthen-Cardiff between 06:00 and 20:00. Do fewer crews sign the route now compared to back then?
