c2c more stock
bengley
18 May 2008
There are some key differences though, e.g. 357s don't have end gangways, 387s do, and the 357s use Tightlock couplers, whereas the 387s have Dellner couplers, so they would be unable to couple.
387s are also fitted with in-cab DOO monitors whereas 357s are not
absolutelymilk
18 Jul 2015
Presumably they would run as two twelve car 387 trains to replace four or eight car 357 services, meaning those would be freed up to run coupled to other 357s?
rebmcr
15 Nov 2011
St Neots
7 months from new build to being introduced on a line where 387s aren't already in service? I know 357s and 387s aren't worlds apart but given what I understand fairly substantial technological differences between the units, and 387s not having been used on that route before, plus the fact they aren't already in service elsewhere, does that not seem like a bit of a tight deadline? Or have I misunderstood the article?
c2c are desperate for extra capacity, so this would seem to be the fastest possible deployment, on purpose.
chris11256
27 Dec 2012
Thats the idea I gather. The 387's can replace two of the 12 carriage 357 services. That then frees up 6 357 units to be used elsewhere. So potentially 6 trains going from 8 carriages to 12, or 4 to 8.
Peter Sarf
Croydon
I am sure the 387s will quite easily interwork with 357s. Already the 377/6s and 377/7s interwork with earlier 377s. If I remember correctly the 377/6s and 377/7s are really just the first examples of 387s given the wrong class number, they are certainly not real 377s. The 357 could be argued to be an AC only version of a 377 so is hopefully not going to provide as many challenges. The 387s can work alone (as two 12-car diagrams) until they (or the 357s) are ready to work together in multiple. Whatever the challenge it is going to be a damn sight easier than the earlier idea of using 360s from a different manufacturer.
The in-cab doo screens can just be ignored ?. The inter-unit gangway connection can just be ignored/blanked off as the 357s do not have them. The couplers are not a big deal surely ? (tries to forget the conversion of 170s to 171s !).
Domh245
6 Apr 2013
nowhere
For a 3 year lease, they sure as hell won't be changing anything - it'd be the equivalent of leasing a car for a week. They'll act as their own microfleet, but vaguely similar to the 357s. The in cab DOO screens will almost certainly be ignored (especially if they are operating as 12 cars, which on c2c are guarded), the inter-unit gangway will exist as normal, couplers will definitely not be changed under any circumstances - it'd be far too much hassle.
WatcherZero
25 Feb 2010
DfT apparently hopping mad with c2c for announcing the deal as completed when it hasn't actually been physically signed and Dft hasn't even in principal approved the expenditure for it.
Class377/5
19 Jun 2010
377/6 and 377/7 are backwards compatible with eariler 37x model (hence the 377 prefix) however no 387 is compatible with the eariler Electrostar's so you can't run 357 and 387 together in passenger service as it's a hardware issue.
SpacePhoenix
18 Mar 2014
Will the 387s mean drivers and guards having to do a full traction course or just a course covering stuff that is different from the existing units?
chris11256
27 Dec 2012
c2c plan to introduce DOO to their 12 carriage services soon. They're installing the monitors now. So not sure if guards will be an issue come October. Of course that's ignoring any union issues relating to 12 carriage DOO.
c2c were on BBC Essex last night, I remember them saying paper work was signed the other day.
jon0844
1 Feb 2009
Hardware issues can always be solved with a hammer...
The Ham
6 Jul 2012
Sometimes a BIG hammer, in fact there is a school of thought within certain engineering sectors which says, "hit it with a big hammer first as if that doesn't work nothing will".
Lack of communication within DfT apparently; according to Tony Miles in wnxx.
Panic over then...
387star
Other than London Overground I think.C2C has been the only toc to implement new doo successfully since privatisation
What do these guards do when not working 12 cars..
Are they part time or rpos the rest of the time?
chris11256
27 Dec 2012
I'm not 100% sure, c2c only run a handful of 12 carriage services in each peak.
Often i've had the same guard on both my morning & evening journey.
bengley
18 May 2008
I believe the guards work long day shifts and work the AM & PM peak and sit spare for the middle part of the day
