c2c more stock
hwl
5 Feb 2012
Sounds like 377/7 is the only realistic option lets hope GTR have some other suitable stock to substitute rather than short forming Southern services as that wouldn't be good for their reputation. Any souther rolling stock substitute plan is going to be complicated...
Given the similarity between 377/7 and 387s and the potential Porterbrook order for 20x 4 car 387 and options for 20 more would this be an indication of the direction in which C2C are heading for their new stock?
357 software should be updatable to work with newer electrostars to certain extent.
It also gets C2C passengers used to a high capacity (narrow seat, wide aisle) 2+2 units.
physics34
1 Dec 2013
I was wondering when the next time that you suggest strippong down a unit would be :lol:
As far as I am aware, Electrostars built after 2009 (excluding Class 378?) are not compatible with Electrostars built before 2009. But as you say, it makes training a lot more straightforward.
377/1s are compatable with 377/6s and 7s for example.
Software was an issue though
rebmcr
15 Nov 2011
St Neots
Presumably this would mean that 3× 4+4 diagrams become 1× 5+5 + 2× 4+4+4 ?
Mikey C
11 Feb 2013
Why would they want 5 car units when all their existing stock are 4 car units?
D365
29 Jun 2012
Surely, if 2x4-car is suitable, a few 321s or 319s could be hired in?
But that shouldn't be a concern if c2c have made this preliminary agreement.
GatwickDepress
14 Jan 2013
Surely Electrostars would be preferable for maintenance as the base kit of 377s can't be that different from the 357s, surely? They're the same family after all, right... r-right?
SpacePhoenix
18 Mar 2014
Wouldn't that mean their drivers and fitters having to do a full traction course, just for a couple of units?
D365
29 Jun 2012
c2c have in the past hired 321s in from Silverlink, which is why I made the suggestion. Maintenance could be sub-contacted to Ilford if necessary.
87015
3 Mar 2006
GEML/WCML/SR
They will be doing it for the 360s, although maintenance may well be done at Ilford by Siemens. It has to be something compatible with the c2c DOO method of working which rules out anything involving cameras.
Paul_W
14 Jan 2016
A c2c spokesman said on BBC Essex this evening that the leased trains would would be brand new trains, to arrive in Spring. Nithing was mentioned abiut the length of the trains. Could they be 387/2s currently destined for Gatwick Express? There was a quote here earlier that mentioned an Airport connection.
Class 170101
1 Mar 2014
Ilford is about to under go major developments as part of the Crossrail project - it won't have room for anymore trains.
Good job as badly needed, though we can add it to Southern, SWT, Thameslink, London Overground and First Great Western when it comes to TOCs serving London that have very recently received additional stock or have confirmed plans. Southeastern passengers meanwhile twiddle their thumbs.
How about c2c concentrating on sorting out their timetable rather than looking for new trains?
The line isn't the worst for crowding by any means.
319s hanging on for a little longer on the Brighton Mainline until the Class 700s start to enter service perhaps?
chris11256
27 Dec 2012
At the passenger panel last night we were told that Two 5 carriage unit would be leased. They couldn't say where from, but gave a hint of an airport connection.
fgwrich
15 Apr 2009
Hampshire
Well, that to me makes it more plausible that it's Gat Ex 387s then!
D365
29 Jun 2012
Aside from the mention of 5 carriage units...
andyb2706
21 Jan 2013
Manchester
The Class 387/2 is only 4 carriages. Like I said earlier I think it is probably 377/6 or 377/7 because both of these probably call at Gatwick Airport and are 5 carriages and seeing they are part of the Electrostar family like c2c Class 357 there may be little conversion for the drivers so they can be introduced quickly.
Hophead
5 Apr 2013
But C2C drivers don't sign 360's!
And switching the units from Heathrow Connect would mean a 20% reduction in capacity on what are, during peak hours, very busy services (assuming they were replaced by 387s). That would keep the PR folk busy.
43096
23 Nov 2015
Unless they use a pair of 387s....
D365
29 Jun 2012
They can't run any other stock into Heathrow as it would need GW ATP fitting which is obsolete.
How are the new/future EMUs on the mainline going to get by until resignalling works are complete?
The mainline has normal TPWS, so EMUS such as 387 will be fine there.
The Heathrow Branch only has GW ATP and does not have TPWS. A new different system is being temporarily fitted in time for Crossrail to run on the Heathrow Branch in 2017. That will then be replaced by ETCS.
I did try and explain this earlier in the thread.
D365
29 Jun 2012
Apologies for going OT, but is GW ATP a leftover from the installation under British Rail? I was under the impression that it is mandatory for all rolling stock on the line.
Domh245
6 Apr 2013
nowhere
Perhaps a shuttle service from would be more appropriate for services to Heathrow? My impression is that the Heathrow Connect services are more of a service for the GWML stations to Paddington than for GWML stations to Heathrow. Although I imagine Heathrow airport holdings won't be best pleased if that were the case
