Brighton Belle On Test - 2025 onwards
Sun Chariot
16 Mar 2009
Yes, high intensity headlamps are fitted. The BB never had headlights, so has no grandfather rights to operate with lights that don't meet current standards. They don't look great, but think it would be worse with a yellow panel.
The yellow didn’t flatter cab ends of the units at all, when they ran in corporate blue-grey.
Deepgreen
12 Jun 2013
Gomshall, Surrey
Possibly. But aren't the power bogies on the end cars, like a CEP? They certainly were on the units as built.
It should go to New Brighton!
They are power bogies, but they are a later design - I'm guessing CIG/BIG.
Ted633
15 Mar 2018
Correct, from CIGs. Vehicles from 4 units (1304, 1392, 1881 & 1884) were scrapped for parts. Some of these vehicles were initially 'saved' from scrap for restoration to mainline standards at Eastleigh (in 2008 I think), however that all went quiet and the inevitable happened. At least some use has been made of the parts.
eastwestdivide
17 Aug 2009
S Yorks, usually
Interesting that it's now presumably twice as powerful as a 4-CIG. Four motor bogies per 4-car unit versus two on a CIG. Gives plenty in reserve for adding a fifth car later.
DustyBin
20 Sep 2020
First Class
Pathing the BEL between modern stock, I suspect means the acceleration will be a necessity rather than a nice-to-have.
To be fair the CIGs etc. weren’t sluggish, and operated alongside modern stock. I’m sure the additional power won’t go amiss though as you say, especially with the extra weight.
contrex
19 May 2009
St Werburghs, Bristol
Under the solebar I understand it is essentially a 4CEP, and as such can work in multiple with a 33/1 or 73, extending its geographical range to places like Salisbury, Swanage and Bath
I hope the misbegotten monstrosity doesn't come anywhere near the West Country. It's scarcely more authentic than a Belmond British Pullman with shoegear.
Ted633
15 Mar 2018
Does each driving car have 2 motor bogies though? Tricky to see from videos and little other info is available without the main website. Some of the scrapped vehicles were from 'greyhound' units, so performance should still be reasonable with only 2 motor bogies if it was those vehicles that were the motor donors.
I quite like the idea of a trip from London to Brighton on this, scoffing kippers and swilling back gin and tonic like the regular punters used to !
61653 HTAFC
18 Dec 2012
Were any of the donor vehicles "Greyhound" units?
Well done!
New Brighton to Brighton would be a good run... though you'd need quite a run-up (and clear signals) to coast between Chester and Farringdon!
ExRes
16 Dec 2012
Back in Sussex
I hear a tour hauled by an original Class 69 will be heading Westwards as soon as it can be arranged .......
eastwestdivide
17 Aug 2009
S Yorks, usually
Good question. That’s what I understood, but I don’t have a definitive source.
If it was only 1 per driving car, it would end up underpowered compared to a CIG once the 5th car was added. In fact the pullman bodies are probably (?) heavier than Mk1s, so even a 4-car “new BEL” with equivalent power to a CIG would be a bit underpowered by comparison. I’m sure we’ll find out in due course.
edit: a poster on a.n.other forum says 4 motor bogies on the new Belle unit
WAO
10 Mar 2019
If they do have a two motor bogie DMS at each end then they are more akin to a 4REP than a 4CEP but with 185kW EE507 TM's rather than the the 300kW EE546B's of the Bournemouth line trains.
A CIG weighed 148t but a REP weighed 175t.
I would love to see a test on Merseyrail, but would stand well away from the circuit breakers!
WAO
Fincra5
6 Jun 2009
I believe, like the original 5-BEL it has 8 Traction Motors (so 4 Bogies).
If the stats on Wikipedia are to be believed, and the motors are from CIGs, then it's 2000hp output, 200 more than original.
DustyBin
20 Sep 2020
First Class
That’s correct, the EE507s used in SR EMUs produce 250hp. The “rule” was a motor per carriage, the exceptions I can think of being the temporary 8VAB (12 motors for 8 carriages) and the MLVs (2 motors in a single carriage).
norbitonflyer
24 Mar 2020
SW London
Other exceptions were the 6PUL/6PAN, which had four power bogies (eight motors) in a 6-car unit, and the 5BEL itself which had the same arrangement but only five cars (as they were heavier).
the 4REPs had 4 power bogies (8 motors) in a 4-car unit but, like the VAB, they were designed to work with TC units.
contrex
19 May 2009
I think it was Richard Catlow who described on the uk.railway Usenet group the strongly felt impact on the chest (because of the arc blow out air blast) when a breaker was test-tripped during commissioning of a substation for the beefed-up supplies for the Channel Tunnel.
norbitonflyer
24 Mar 2020
SW London
403 was the 5BEL TOPS class. 4CORs were 404s.
Quite so. But the original unit 3101 was a 4COR. The Brighton Belle units were numbered 3051 - 3053. As the 4RES units were numbered from 3054 upwrads, 3050 is the only number available consecutive with the original series. (The restored unit includes cars from all three original units, so none of the original nunmbers would be authentic)
Liverpool? What would it be doing up there? I thought it was for the southern region?
It's currently at Crewe as that is where the final work on it was done, so Merseyrail is the nearest place where it can be tested under its own power
DustyBin
20 Sep 2020
First Class
Your quite correct, I was however referring specifically to the units with EE507 motors.
That's interesting re the VAB; I've only ever seen photos of it working on it's own or with a VEP.
eastwestdivide
17 Aug 2009
S Yorks, usually
Think you’re right. Blood and custard at https://www.bloodandcustard.com/BR-4VEP.html says
Unit no.8001 had the three motorcoaches to maintain the faster 4 REP schedules as it was used on Bournemouth line semi‑fast services. However, it could be divided into five and three-car portions and occasionally operating as such. It could also run in multiple with other 4 VEP units, although not with 4TC stock as it was unable to supply heating and lighting current to the 4TC units
Peter Mugridge
8 Apr 2010
Epsom
They worry about the number not being authentic? Really?
In any case, as the revived unit is technically different in running gear from the original three units, I think 3101 would be the correct number to use... it's a new sub class.
Brush 4
25 Nov 2018
It's a recreation though so old numbers rule. 3050 is a good compromise, in the same way that new build steam locos have the next number in the sequence. As it has carriages from all 3 5BELs, it could carry any of those numbers in turn. I expect the carriages were swapped around as well between units.
