Brighton Belle On Test - 2025 onwards
trainmania100
8 Nov 2015
Newhaven
I have seen some gen around that 20118 and 132 are out on a test run with the Brighton Belle unit.
Subsequently I can't find the Brighton belle restoration website that was documenting the work on the train.
Would be good to get some up to date shots if anyone sees it today on its run to Chester and Back.
Makes a series of runs between Crewe and Chester.
Obviously it's now on the rails and in a running state I'm curious to know :
  1. Has the unit been assigned a class (other than 403), or a particular running number?
  2. Is the unit third rail compatible?
matrix24
6 Sep 2013
Very intresting and completely unexpected.
Beeston is just 8 miles from my home, so tempted but my work today simply will not allow. Sigh.
Hope someone is luckily enough to capture these initial test runs.
trainmania100
8 Nov 2015
Newhaven
Video of it here:
If you cannot view this video on X, the video shows the 4 car Brighton belle unit being top and tailed between class 20s, passing a boating lake.
D6130
12 Jan 2021
West Yorkshire/Tuscany
Video of it here:
That's not a boating lake. It's one of the canal marinas on the Shropshire Union....either Bunbury or Beeston Castle I think. (Sorry....O/T)
Strathclyder
12 Jun 2013
Clydebank
The Youtuber DestinationTrainsPlanes was on hand to catch the 20s escorting the Belle through Crewe on one of the runs (timestamped video linked below).
Perhaps the first time the Belle (as a unit and not loco-hauled stock) has been that close to the 89?
Can give you the carriage names that were in the consist if that helps you.
Mabel
Gravetye Manor
Doris
Beryl
Dan.
OK, thanks. So from pictures it looks like the carriages are carrying their 99xxx carriage numbers, so from the names above the consist is 99291-99285-99282-99288.
Cowley
15 Apr 2016
Devon
The Youtuber DestinationTrainsPlanes was on hand at Crewe to catch the 20s escorting the Belle through Crewe on one of the runs (timestamped video linked below).
The Brighton Belle, IC class 90s, the 89, Railfreight 20s and an orange 142 all in one shot!
elltrain3
9 Jul 2021
Chester
The Path (5D41/5K44) Has been activated again on RTT with 20118/132 and 4 'coaches' so looks like it's off on another test run again today!
Another YouTube video taken yesterday at Chester, this one includes a number of close up views of the unit.
norbitonflyer
24 Mar 2020
SW London
Great news
Seems to have been put in Railcam data as 403050 (running as 3050).
Although in the video it is carrying the unit number 3101 (which makes it a 4COR!). The original units were numbered 3051 to 3053.
  1. Is the unit third rail compatible?
Yes, which is why it is initially going to be tested in the Chester area. In the video it looks like the shoes haven't been fitted - or maybe they are retractable like on a 73 - presumably as, outside live rail territory, there is a higher risk of them fouling something.
Under the solebar I understand it is essentially a 4CEP, and as such can work in multiple with a 33/1 or 73, extending its geographical range to places like Salisbury, Swanage and Bath
WAO
10 Mar 2019
Great news
A 4CIG surely. B5 + Mark 6 motor bogies?.
WAO
norbitonflyer
24 Mar 2020
SW London
WAO
Possibly. But aren't the power bogies on the end cars, like a CEP? They certainly were on the units as built.
It should go to New Brighton!
Polarbear
24 May 2008
Birkenhead
Liverpool? What would it be doing up there? I thought it was for the southern region?
I wondered the same when I saw the video of the BB set in Chester. It is indeed intended for use on the Southern 3rd rail network eventually & I look forward to being able to travel on it in due course.
Deepgreen
12 Jun 2013
Gomshall, Surrey
It looks very fine, and the orange cantrail stripe is commendably muted (I'm pleasantly surprised they 'got away' with that). I recall my father taking me on one of the last runs of the BB in 1972. The headlines are ghastly, of course. I really hope 3101 is some sort of temporary number and that, say, 3050 is used instead - I don't think it has been used previously (unless I've overlooked something) and is at least consecutive with the three original units' numbers.
Ashley Hill
8 Dec 2019
The West Country
Having no yellow ends I presume it has high intensity headlamps? And are those the original names of the cars? If not then they remind me of the old Beryl & Cheryl set :D.
Sir Felix Pole
21 Oct 2012
Wilmslow
Great to see. The replacement underframes / bogies should give a smoother passage - as built they were notoriously rough-riding. Regular patrons avoided the soup course!
D6130
12 Jan 2021
Yes....Sir Laurence Olivier, his wife Joan Plowright and Dora Bryan usually preferred the kippers, I've been told.
Cowley
15 Apr 2016
Devon
I bet they didn’t have too many problems with the G&T’s though. ;)
Ted633
15 Mar 2018
Yes, high intensity headlamps are fitted. The BB never had headlights, so has no grandfather rights to operate with lights that don't meet current standards. They don't look great, but think it would be worse with a yellow panel.
