Bi directional platforms
MadMac
13 Jun 2008
Moorpark, CA
Scottish ones, excluding terminal platforms and single lines:
Through platforms at Waverley, Dundee and Aberdeen
Through Highland Line Platforms at Perth
Carrbridge, Aviemore and Pitlochry
Elgin, Forres and Platform 1 at Nairn
Stirling (Platform 6)
Dalmeny
Ladybank (Platform 2 for services from Perth)
Dunbar (Platform 1)
Kilwinning (except Platform 1)
Ayr
Kilmarnock
Barrhead
Busby (Platform 2)
Hairmyres
Newton
Motherwell (Platform 4)
Carstairs
Dumbarton Central (Platform 3)
(Edit) Springburn
Kingussie, Blair Atholl and Dunkeld (one platform at each?)
Disclaimer: may not be an exhaustive list.
Shipley P2, P3 and of course P5.
Preston P4 at least. Most at Leeds and York
Dorchester South Up platform and various Salisbury-Exeter.
Tonbridge Up loop (at least), Tunbridge Wells?, Ashford (some?) and many more of the Southern.
Teignmouth, Dawlish, ?D Warren (all up side)
Yeovil PM
Parallel
9 Dec 2013
All of Westbury’s 3 platforms are bi-directional. I believe both through platforms at Newbury are too. Platform 1 and 3 are at Swindon, unsure about platform 4. Platform 2 is a west-facing bay.
I believe all 4 platforms at Newport are bi-directional too.
Springs Branch
7 Nov 2013
Salford Crescent.
I've never experienced it myself while travelling through there, but noticed recently on RealTime Trains several trains per day in both directions using the 'wrong' platforms. These are normal passenger services - not the booked TPE reversals in the early hours. Often, but not always, involving parallel arrivals/departures from the Victoria and Oxford
Road routes.
EDIT: Whoops - I see SLD already mentioned at post #29
bluesfromagun
12 Jul 2010
There's literally hundreds, if not thousands I'd think.
East of Scotland
Waverley platforms 1, 2, 7, 8, 9, 10, 11, 19, 20.
Dalmeny platform 1.
Glenrothes platforms 1 & 2.
Ladybank platform 2 (only to / from Perth).
Dundee platforms 1N, 1S, & 4.
Perth platforms 3, 4, & 7.
Montrose platform 1.
Aberdeen platforms 6S, 6N, 7S, & 7N.
Also Stirling platforms 6 & 9, Bishopbriggs platforms 1 & 2.
These are all truly bi-di, meaning through platforms at which passenger trains can both arrive and depart in either direction.
pompeyfan
24 Jan 2012
You’ve also got platforms which are not through platforms but can be used to turn back in, so it depends if you want those included. On top of that you’ve got turn back platforms that are accessed by ground position signals so not accessible generally accessible for passenger services.
According to my paperwork I have for the outer Wessex route;
Dorchester south P1 (fully) P2 (turn back)
Wool P2
Wareham both platforms (turn back only)
Poole P1 or p2 (turn back)
Bournemouth P2, 3 and 4
Brockenhurst P1, P4 (turn back)
Totton P2
Southampton Central (already discussed)
Eastleigh P2 and P3
Shawford P1 and P2
Winchester P1 and P2
Micheldever P1 and P2
Basingstoke P1 - P4
Woking P1, 2, 4 and 5
Andover P2 (turn back)
Salisbury P3 and P4
Gillingham
Yeovil Jn
Axminster
Honiton P1 or P2 (turn back only)
Guildford P2-P8
Haslemere P2 (will change after resignalling)
Petersfield will become turn back after resignalling
Havant already discussed
Fratton P2 and P3
Portsmouth and Southsea P1 & P2 turn back only
Aldershot P2 and P3 turn backs only
Bentley P1
Romsey P1(?) turn back only
Platforms mentioned above do not include ECS moves or bay platforms
honestreviews
21 Jul 2025
Welcome to the Forum, I'm afraid that the short answer to this is that there's not 1 single official list.
As has been mentioned, a the definition of a bi-directional platform is somewhat variable, as it could require being able to use it as a through platforms in both directions and not simply reverse in the platform. If using the more limited definition, most major stations will have at least one bi-directional platform, and any station on a bi-directionally signalled line will also have them. Additionally, any station with only a single line (i.e. not a passing loop) would be a bi-directional platform.
Thankyou for the welcome and well it was worth a try asking but thankyou for the information
SteveyBee131
28 Oct 2017
Grimsby Town
Platform 2 at Grimsby Town
Through platforms from 5 upwards at York
Platforms 13 and 14 at Manchester Piccadilly
Think all the others I know of have already been mentioned
SOU P5 is westbound only and not in passenger service
In any case I think bay or terminus platforms are probably out of scope, as although the OP didn’t state they weren’t included, they must always allow moves in both directions.
DelW
15 Jan 2015
Guildford P2-P8
Strictly p2 - p6 and p8, since AFAIK p7 has never been used for passengers since slam-door stock was withdrawn. (For the benefit of others, it faces the same track as p6.)
Is p6 ever used for through trains now? It seems to be more or less permanently occupied by the Farnham shuttles which lay over for about 26 minutes of each half hour. It seems to have effectively become a north-facing bay.
Efini92
14 Dec 2016
evening all , does anyone know if there is a way to find a list of stations with bi directional platforms
The sectional appendix will show you which platforms are bidirectional, though they won’t have a list of them.
Manchester Victoria Platforms 3-6
Blackburn Platform 2
1-6 at Victoria are bidirectional
As are 1-4 at Blackburn.
GrahamD83
5 Mar 2018
Most stations between James Cook (Middlesbrough) and Whitby are bi-directional as the line is mostly a single track with a token system.
Magdalia
1 Jan 2022
The Fens
All platforms at Cambridge and Ely are bi-di, as are all at Peterborough except P3.
Both platforms at Royston.
Platforms 3 and 4 at Welwyn Garden City can be used for up departures.
Platform 1 at Audley End.
Platforms 2 and 3 at Bishops Stortford (not sure about platform 1).
Platform 4 at Broxbourne can be used for up departures.
