Better rail connection to Heathrow.
cactustwirly
10 Apr 2013
The relief line is not currently timetabled for maximum throughput though, capacity is expended on non standardised stopping patterns.
If 4 more trains were going to the airport, rejigging of the timetable would release the capacity necessary to achieve it.
Which is how it will be possible to expend every train to Old Oak Common.
The Freight trains a slotted in between the Elizabeth line. They have to skip stop to prevent the Freight being held up
Freight Traffic joins the line at Acton which is after Old Oak Common
If the 'longer distance' Maidenhead and Reading services ran all stops would there be room for passengers to board them?
Unfortunately that is not correct. The ‘non-standard’ stopping patterns are there to accommodate the freight.
DM352
9 Oct 2019
White north
I just stick with the Piccadilly to save money and connect in London when I visit the UK.
I still curious at what it would take to increase the bore west of Hounslow for larger district line trains for capacity. After watching youtubes including the driver who was unfortunately forced to stop recording the obvious answer is not cheap to stretch a cut and cover!
Unrelated, know at one time around the millennium Feltham station reinvented itself with a rebuild served by very frequent buses to LHR but think that died off.
Peter Wilde
14 Oct 2019
Have tried the coach connections to Heathrow from Woking or Guildford - but found them far from ideal. For anyone on the SWR network used to fast, frequent trains, the change to a slow and expensive coach for the last leg is off-putting. The worst part is the coaches run so infrequently. One an hour is insufficient to be attractive - just think how one feels arriving off a late flight and finding a coach has just gone, so another hour to wait (and in unappealing bits of the airport too). So most people opt to rely on pre-booked taxis instead.
andreading
27 Apr 2019
As a someone who works south of Heathrow I think that extending the Elizabeth line to either Staines or Feltham combined with diverting the Waterloo-Weybridge via Staines to Woking would help. Then if all SWR trains called at Woking it would be a useful link. the timetable for the branch is very heavily padded at Virginia Water.
Mgameing123
29 Apr 2023
Denmark
Just stop everything everywhere. A look at the timetable shows that not stopping saves almost nothing in times: The stop-everywhere trains typically take 20 or 22 minutes Paddington to Hayes and Harlington. The fast Elizabeth line trains also take up to 22 minutes, though some of them manage it in 17 minutes. As far as I can see, almost all the skip-stopping achieves is make the service provision at most stations worse than it need be.
Well you could also make alternating stops at some stations. (So trains stopping at Hanwell don't stop at Acton Mainline & Vice versa)
Well in theory those passengers should just be taking the first train to Hayes & Harlington then change there. or alternatively take the Didcot Stopper GWR train from Paddington.
And at peak time the Reading trains that run nonstop between Ealing Broadway & West Drayton run so slow anyways. The stopping train timetabled right behind isn't slower at all.
Meole
28 Oct 2018
Freight should be removed to facilitate passenger traffic, road is the place for freight.
