Bath to Conwy - tight change at Newport.
seagull
28 Feb 2011
Yes, quite silly prices, and further prices rises recently. 4.15 a pint for me now. That's quite ludicrous for the pub it is, in the location it is.
O/T but does anyone know the reason the establishment at LLJ is known as "The Killer"? Always been curious.
Llandudno
25 Dec 2014
Matlock
Unfortunately apart from Wetherspoons or the Carlton in Llandudno , it’s difficult to find a pint for under £4 anywhere in Llandudno/Conwy…
Parallel
9 Dec 2013
I empathise with the tight connections - I used to occasionally travel from Westbury or Trowbridge to Aberystwyth, and had a 5 minute connection at Newport - and about a 7 minute connection at Shrewsbury. I usually had some luggage and the Holyhead train would usually arrive on Platform 3 at Shrewsbury, due to Platform 4 already being occupied.
After a couple of times of missed connections, I gave up and travelled an hour earlier, giving myself half an hour at Newport and Shrewsbury which was a lot better - this was using flexible tickets though, which weren’t too badly priced on this route at the time.
The exile
31 Mar 2010
Somerset
What if the trains were on time but the connection time was not enough? Thinking of situations where services may stop at the far end of platforms away from the steps (like they often do at Newport, Cardiff and Bristol Temple meads as examples) - if you have luggage with you too or are not very mobile then that could easily make you miss a short connection. I guess that would be on the passenger then if there were no actual delays?
Or indeed what happens if at both sets of stairs to the subway there is such a crowd of people coming the other way that what would have been “5 minutes for a connection that takes 4” ( remembering of course that “doors can be locked up to 49 seconds before departure) into “I had 5 minutes for my connection; the train was 28 seconds late - so still technically on time, I couldn’t fight my way through the crowds so arrived with 39 seconds to spare to find the doors locked. Each individual element happens so frequently that combinations of enough of them to cause a problem must also be common!
I don't think so. Obviously we are getting into the murky territory of implied terms here, but itineraries offered should be fundamentally 'doable'. Delays occasioned within the railway's areas of responsibility (e.g. getting onto the platform and the train, changing between trains) all fall under Delay Repay.
There are a number of stations where even the average person would struggle to make a connection, due to tight minimum connection times. Typically this happens where a MCT designed for a cross-platform etc. connection is applied in an unintended manner.
Envoy
29 Aug 2014
An odd thing that happens at Newport is that the journey planners - such as Nationalrail.co.uk - tell everybody heading west from England via the Severn Tunnel or Severnside line - to change at Newport for west Wales. So, for example, if you put in for a journey from PAD to Carmarthen, you are told to get off the GWR IET at Newport and transfer to a train coming off The Marches line (Hereford route). Now, the odds are that these trains are usually 2 or 3 coaches and hence often packed. The last thing they need is loads of people transferring at Newport. Of course, anybody with any sense would stay on the (usually 9 or 10 coaches) IET to Swansea and then transfer (on the flat) when the Manchester to west Wales train arrives. Many people don't do this because they are afraid they will be fined a fare supplement for not following the itinerary. Even those on trains that terminate at Cardiff would surely be better off staying on those trains to Cardiff and then transferring to a TfW train heading west.
Haywain
3 Feb 2013
There are also very many stations where the average person will consider the connection time to be far too long, because they are generally designed to allow a little old lady with a giant suitcase to be able to make the change.
Indeed. Cross-London connectional allowances do seem rather excessive - I can't really think of a London Terminal where you'd have a walk longer than that from platform 18 to 9E at Edinburgh, which 'only' has a 10 minute allowance.
Starmill
18 May 2012
Bolton
Connection times between Manchester Piccadilly and Manchester Victoria are too long if you intend to use the tram service, assuming that it's running normally when you travel. However, in most cases this won't be included in the fare, so if you wanted to avoid paying extra, you'd have to use the relatively unreliable free bus, or walk. Personally I don't think there's enough time for someone to walk comfortably unless they know the way already and are quick on their feet.
Mcr Warrior
8 Jan 2009
Isn't there normally a once-an-hour heavy rail service between the two stations, part of TPE's Manchester Airport->York/Redcar offering, takes 11 minutes (Mon-Sat)?
Starmill
18 May 2012
Bolton
Yes, but if that were convenient to your journey the question of how to make the transfer wouldn't arise in the first place.
It's so infrequent though it's little use. It's more likely that you'd get a good connection to change at Salford Crescent
Mcr Warrior
8 Jan 2009
Just pointing out that there are other options when interchanging between Piccadilly and Victoria stations in Manchester than walking, the free bus, or paying for the Metrolink (or indeed a taxi).
Starmill
18 May 2012
Bolton
There are indeed plenty of options to avoid the connection times, yes.
How much time do journey planners allow for MAN-MCV connections
10 minutes MCT at Piccadilly + 22 minutes "transfer" (i.e. make your own way) + 5 mins MCT at Victoria. Total 37 minutes.
I've done it in 15 minutes from train to train, but you've got to know exactly where you're going, be prepared to walk very fast and have some luck to make that!
is it the same in both directions?
Yes. I can't think of any connections where it isn't, although there are some (cross-London) where the mode/duration of transfer varies by the time you commence, so it might be quicker doing it at 1pm than 10pm.
mmh
13 Aug 2016
Ouch, that's pretty awful. I know Manchester very well, and I can walk very fast, but I'd still not want an official connection that tight.
trainophile
28 Oct 2010
Wherever I lay my hat
Thanks for the detailed info. We've got that very connection shortly but to my relief I've just checked my tickets and we've got an hour and 23 minutes. Better not diverge off route until we get to Picc, might be a Greggs instead of a Wetherspoons!
