Barking - Gospel Oak
BrianB
21 Jan 2018
Does anyone have background information why the data for this line for May hasn't been uploaded into systems yet, as all other LO lines were uploaded weeks ago
greatkingrat
20 Jan 2011
I assume it is likely related to the opening of the Barking Riverside extension which should happen at some point before December.
SargeNpton
19 Nov 2018
Which date are you looking at, and in which journey planner? National Rail Enquiries shows services on that route for 16th May.
Taunton
1 Aug 2013
One wonders who will win the race to open first, Crossrail, or Barking Riverside (which I believe started construction after Crossrail was meant to have been finished).
For all dates in May RTT seems to have a fully VAR timetable showing, but it’s looking very like a normal service.
306024
23 Jan 2013
East Anglia
If you search RTT for Barking Riverside in July you’ll see the full WTT service. It will just be amended back to Barking by short term planning until it opens.
BrianB
21 Jan 2018
I am seeing no LTP entries for the existing route from May onwards. A random search of RTT for Blackhorse Road for 8 June shows no trains.
cle
17 Nov 2010
Barking Riverside has been a discreetly, very swift build without much public facing fuss. I do hope the house-building and place-making happens at scale, for the investment.
Will the timetable change considerably, or will it be a case of just starting back X minutes from Barking, per normal? And still at 4tph?
SargeNpton
19 Nov 2018
Try any weekday between 16th May-3rd June. Looks as it the timetable is being rolled forward one week at a time - presumably until the Barking Riverside opening data has been confirmed.
For weekends engineering work may be taking places, but without the replacement buses yet input.
306024
23 Jan 2013
East Anglia
Really? Works OK here. The full WTT service to Barking Riverside is currently shown on 8/6/22. Check the detailed filtering options.
Freightmaster
Verified Rep
7 Jul 2009
As per the previous posts, you need to change the services type to "calls only" to get trains to show on that date:
If you set the search to "Passenger services", you won't get any results as the trains are currently suppressed:
hope this helps,
MARK
55002
16 Aug 2019
Ldn
The driver will have to be quick at Riverside, only 1 min turnaround?
Looks like there is a step back, with most trains having a ~17 minute turnaround.
It's rather inefficient, considering it's an end to end journey of just 38 minutes, with another long-ish turnaround of 12 minutes at the Gospel Oak end. But I suppose at least it should make for a reliable service.
55002
16 Aug 2019
Ldn
Ah you
Ah youre right..that makes more sense
306024
23 Jan 2013
East Anglia
With a 15 minute service the alternative is a 7 minute turnround both ends, and that is only if optimal paths through Barking can be found that don’t conflict with c2c, and don’t foul freight paths between Barking and Stratford, which are fairly fixed across Forest Gate Jn.
Yes, a significant disadvantage of the new extension is that you suddenly "gain" a conflict with all the freight and C2C services towards Ripple Lane and Dagenham.
Isn’t the major grade separated junction near Renwick Rd aimed at reducing that?
Class 170101
1 Mar 2014
It will remove a conflict at Barking Station Jn for services coming from Platform 1 at Barking, but inevitably it creates new conflicts elsewhere that have to be resolved.
Mojo
7 Aug 2005
Will Goblin trains once the extension starts run over the existing flyover used by c2c services when diverted to/from Liverpool Street and serve platforms 7 and 8 at Barking?
Freightmaster
Verified Rep
7 Jul 2009
Correct - it's the only way for trains to get from the GOBLIN to/from Ripple Lane.
MARK
cle
17 Nov 2010
So GOBLIN won't be on p1 any more at Barking? What will?
I wonder if they’ll still open doors on both sides of the LU services on P2, as wasn’t that mainly aimed at GOB interchanging? Or am I out of date on that procedure?
(Using only one side would presumably reduce PTI risks from TfL’s point of view?)
Horizon22
Jobs & Careers
8 Sep 2019
I don't think you can get to Riverside from P1 or P2, so that seems unlikely.
Horizon22
Jobs & Careers
8 Sep 2019
What I meant was with no trains using P1 the existing need for opening both doors isn’t there?
Ah I see. Yes I suppose not seeing as they won't regularly be using P2, and P7/8 is an island anyway.
greatkingrat
20 Jan 2011
However the P1/2 island is the only one with a lift so I think they will still open doors both sides. If the district only used P3, then any passengers needing step free access would have to walk the length of P3, then down the ramp, across the subway, then back up the ramp and walk the length of P1 to get to the lift.
Oh right, I wasn’t aware of that palaver…
Class 170101
1 Mar 2014
Booked ECS once a day in the morning
appears to split for
and
