AWC Derailment at Shap Summit 03/11/25
YorkshireBear
23 Jul 2010
A few pictures of the front of the train but does anyone seen any of the actual landslip and the conditions of the embankment? I'm no expert but considering the whole nose of the train came off it must be quite a bit earth movement, contrary to the photos where the embankment isn't actually that much higher than the train
The rails don't have to be covered more than a few inches to detail a train so the fact the cutting isn't higher than the train is irrelevant.
Think images of landslip removed as had no source, but a good chunk in the cess I imagine was enough to remove the superficial parts of the front end.
FrontSideBus
11 Feb 2025
The landslip probably wasn't that bad since the leading vehicle ploughing through it was enough to clear it to an extent that the rest of the coaches remained on the rails.
DaveyJones
12 Mar 2023
From some of the photos doing the rounds on news articles it's clear the Lifeguards and Cow Catcher have done their job pretty well
Master Cutler
23 Jan 2021
Mansfield
Looking at the front end damage, and guessing the nature of the land debris, the main force would have created quite an upward lift, enough to lift the front off the rails while the train was slowing down.
FrontSideBus
11 Feb 2025
I imagine even the ballast flying everywhere at that speed would cause quite a bit of damage.
cats_five
19 Sep 2021
Some photos of the recovery on the North Yorkshire Weather Watchers FB group. One shows jacks and the recovery engine was 57309.
35B
19 Dec 2011
Quite. Worth looking at images of the slip at Carmont to see what relatively little can do
trainmania100
8 Nov 2015
Newhaven
It's good that nobody was seriously hurt but it's concerning about the inefficiency of the equipment, be it the detection or the relay of the detection to control
BRX
20 Oct 2008
If I remember right, at Carmont it wasn't the earthworks that moved, it was a load of material that got washed out of a drainage trench onto the track. If the same thing happened here, then you'd not necessarily expect that equipment to detect it.
a_c_skinner
21 Jun 2013
As suggested above I've looked at the N. Yorks weather facebook page and an image on there is of 57309 obviously rescuing the 390. Will this loco still have a functioning Dellner coupler or will it be using an adaptor from its hook coupler?
Goldfish62
14 Feb 2010
Unit rerailed and being towed to Carlisle for onwards travel to Polmadie, overhead lines repaired, track, signalling and earthworks repairs in progress. All good stuff.
chrisjo
18 May 2024
Llanishen
From my recent observations 57309 has been the designated DRS Avanti Thunderbird rescue loco at Carlisle for a while, having taken over from Lady Penelope.
CAIB
22 May 2009
Lea
It does beg the question how passengers with restricted mobility are evacuated in such circumstances?
How far a walk did they have to the Shap Wells Hotel from the incident? Being localish we do extensive walking in all conditions around Orton and Shap so a good if not neccesary effort (especially for the elderly in abhorrent weather) all round walking on heavy ballast. Also a reminder how valuable TOC must treat and refresh emergency procedure.
bishdunster
9 Oct 2012
Dunster
Vis a vis the mysterious yellow "cable", It is quite common for the civil police traffic cops to use these heavy duty straps to imobilise a vehicle while they investigate, also to prevent unauthorised removal of said vehicle !:rolleyes::rolleyes::rolleyes:
enginedin
15 Dec 2020
as many others have said, it's not unheard of for (at least one of) the local mountain rescue teams to be drafted in to help with supporting the less mobile - they have stretchers designed to be carried over rough terrain
jadmor
26 Nov 2013
And Carmont would probably have looked like this if the train hade not hit the bridge abutment. On the other hand, this incident would have been magnitudes worse if a train had been approaching on the other track.
That would be very decent in the circumstances - weather's not great and the location isn't exactly Trafalgar Square.
I am not quite sure what the comparison is here, Trafalgar Square has lots of bystanders / spectators and is surrounded by lots of roads that have been blocked off or made one way.
It is not like the old days, as soon as the train jacked out of the way, single line working is instigated from a crossover at a station nearby so got around 2-5 miles single with pilot man. Nowadays they block off 20, 30, 40 miles of route, and use road/rail equipment from an access point with a trolley carrying equipment, it not as if if a crew walks lineside for couple of miles carrying jacks, blocks, shovels etc anymore.
Dave W
27 Sep 2019
North London
I think you are reading it rather too literally. It's up the top of Shap; regardless of how you want to cut it, it's not particularly accessible.
Spartacus
25 Aug 2009
It's about 2.5 miles off the nearest M6 junction though, you can get there from Carlisle in under an hour, no problem.
22 Jan 2024
It does still have a functioning Dellner- it's one of the four designated Thunderbirds (although the contract with DRS apparently ends later this year). The others are 57304/7/8.
