AWC Derailment at Shap Summit 03/11/25
Skiddaw
2 Jan 2020
Penrith
Yep- it's been pretty wet up here. I presume that had something to do with it. We heard the emergency services rushing through the village earlier and wondered what was going on.
The Shap Wells hotel is lovely- I'm sure the passengers will be looked after. Just glad no-one hurt.
Louby
16 Feb 2012
For those who call modern trains "plastic" - these images are a fine example of what's behind the body panels and why I'd far rather be in this situation in a modern train than something older.
A pigeon at high speed will dent the older ones ! I hit a deer once and it crumpled my defector on a 158
Mogster
25 Sep 2018
It looks lucky to have ended up sat in the middle of the two sets of track. To either side could have been much worse?
Straus
20 Jun 2025
Manchester
Derailing to the centre is normal with a landslip related derailment as more material covers the rail closer to the earthwork.
Strathclyder
12 Jun 2013
Clydebank
Yeowch! Just shows how solid and well built the 390s are that the cab structure and windscreen are intact despite what was clearly a fairly substantial impact. It did it's job and protected the driver.
AM9
13 May 2014
St Albans
Which so long as there is nothing using the other track at the same time is fine.
sh24
28 Sep 2023
Wow. As posted above, a great tribute to modern design and build standards.
Mcr Warrior
8 Jan 2009
What other Northbound / Southbound passenger services in the area have been caught up in the aftermath of this morning's derailment? Presume they'll all have to, in due course, return 'wrong direction' to an appropriate station so that passengers can then be de-trained. (And maybe then continue by other means).
SWML9102
28 Oct 2019
bridgend
Yeowch! Just shows how solid and well built the 390s are that the cab and windscreen are intact despite what was clearly a fairly substantial impact. It did it's job and protected the driver.
What's the yellow cable at the right hand side which appears to connect to the track?
AM9
13 May 2014
St Albans
Headlights maybe, which are mounted on the absent front fairings. The cable may have been dragged under the front when the fairing became detached. Any track cables aren't likely to be as clean unless recently replaced.
Deepgreen
12 Jun 2013
Gomshall, Surrey
Utter trivia of course, but it's bizarre to have major incidents declared on the WCML and ECML concurrently - I can't recall the last time.
SWML9102
28 Oct 2019
bridgend
Ah ok, I wondered if it was something deliberately connected to the rail post accident, temporary earth, or signalling related.
AM9
13 May 2014
St Albans
All but the lead car is reported to be still on the track therefore the train earth is carried through. Normal practice is for the rearmost pantograph tp be used and it looks as though the knitting at the site was undisturbed by the derailment.
Strathclyder
12 Jun 2013
Clydebank
Just been reported on BBC Radio 4 that Avanti saying the line will be closed for several days.
Not a surprise, given the damaged unit will need to be rerailed and dragged away and the track and earthworks will need to be inspected and repaired/secured/stablized. Rest of the week I can see it being closed.
21 May 2014
The following photo has been added to the BBC live feed, from a Network Rail release:
Photo shows the lower portion of the leading vehicle derailed between the two lines.
Western Lord
17 Mar 2014
How old does a train have to be before it is no longer considered modern? The 390s were designed more than a quarter of a century ago.
Guard86
14 Nov 2020
Manchester
Landslip behind the train and the front of the train fouling the Down line. How does one run another train alongside?
TT-ONR-NRN
30 Dec 2016
Cambridge
Very glad no one is hurt, though my thoughts are with everyone onboard, I’m sure some must have been shaken.
Strathclyder
12 Jun 2013
Clydebank
Not really a surprise, given the damaged unit will need to be rerailed and dragged away and the track and earthworks will need to be inspected and repaired/secured/stablized.
