807/805 Speeds
Ellis101
31 Aug 2022
I’ve noticed a lot of MU signage now being displayed across the WCML showing speeds up to 125mph. Does anybody know when 807/805s will be able to run to these speeds?
I remember hearing that driver briefings were in September but that was on a previous thread about 807/805s and may have changed.
Fincra5
6 Jun 2009
No reason an 805/807 can't. They just can't do speeds that are "EPS" Speeds - which are for Tilting Trains.
Tilting007
21 Oct 2024
Rugby
Its waiting on driver training now.
Avanti hope to have the 805/807 running at MU for the Dec 25 TT change when additional trains are added.
Efini92
14 Dec 2016
I think the ORR forbade them from using the MU speeds for reasons that go over my head.
It was something to do with the 80x not having speed supervision. Somehow they were built and certified without anyone noticing.
GhostManDN91
2 Oct 2022
Wigan
As in does the to-be-introduced MU speed profile go above 125mph between those locations?
Yep that's what I was wondering. It would be nice to have a ride on one from Liverpool to Crewe when they can go faster than 110mph on that section.
gabrielhj07
5 May 2022
Herts
Was this to do with the ORR requiring that they had a means (TASS) to monitor a system (Tilt) that doesn't exist on the 80x?
hexagon789
2 Sep 2016
Yes, it does go up to the full 125mph between Crewe and Weaver.
You can see the new MU profile in the Sectional Appendices now. For Crewe to Weaver you want pages 15 to 19 of this document:
Sectional Appendix PDF copies​
Search files and folders
Search Results​
  • Sectional Appendix full PDFs September 25
London North Western (North) Sectional Appendix September 2025
As I interpreted it at the time it was first mentioned, it was the perceived additional risk of having drivers trained on two 125mph capable fleets, where only one had a speed supervision system.
Efini92
14 Dec 2016
Yes but only the speed supervision part.
I believe there is an A train in Japan that tilts. Would’ve been a lot easier to have just bought that and used TASS.
Imminent, AIUI
November the 10th will give us a good idea.
I thought it was more to do with the risks of trains exceeding the limits on bends.
So 125mph MU from Crewe Coal Yard to Weaver Jn, apart from a dip to 120 over Vale Royal viaduct (Down line only).
Weaver Jn itself towards Liverpool still has differential EPS speeds shown, but no MU.
Are these still the 221 differentials?
South of Crewe it gets complicated with no MU speeds at places like Whitmore and Rugeley (so 110 PS), and often different on Up and Down lines.
Railperf
30 Oct 2017
So is the suggestion that some or all services will run at MU limits from November 10th?
Tilting007
21 Oct 2024
Rugby
Yes, EPS differential remain, which means no MU speed at some locations
Railperf
30 Oct 2017
Interesting that in places such as Leighton Buzzard, the maximum speed remains at 90mph for non-tilting trains - while the Enhanced speeds of 115mph and 125mph for tilting class 221 and 390's remain respectively despite the fact that there are no booked Class 221 workings over the West Coast Main Line in tilt mode.
Efini92
14 Dec 2016
Are there any 221 still capable of tilting?
Railperf
30 Oct 2017
The off-lease ex -Avanti units had active tilt. Those that have been transferred to Crosscountry most likely have the tilt system disabled.
cambsy
6 Oct 2011
I noticed too on the sectional appendix that at some locations there EPS of 115/125 mph, So presume the 805’s-807’s will run at normal line speeds rather than the EPS speeds, am I correct?
Tilting007
21 Oct 2024
Rugby
If the 221 speeds were removed the Down at Leighton / Linslade would have gone to 100 MU.
One of the locations where tilt makes a massive difference.
35mph between a Pendo and 350/730 and 805/807…
I don’t believe it is being maintained any longer…
Railperf
30 Oct 2017
The issue I find after Linslade northbound is how long the 90mph remains before going back to 110mph within a zone that seems to be ideal for accelerating to a higher speed where the curvature is not seemingly that severe. Clearly the 90mph through Linslade is also about pressure sealing.
If you mean Linslade tunnel, the curvature is severe enough that 390s are on maximum tilt.
absolutelymilk
18 Jul 2015
It looks like there's actually a reduction in 805s running from Chester, as there's no 1932 service to Euston (no change in the number running Euston to Chester), unless it's just not been put into RTT yet?
cambsy
6 Oct 2011
Are 805’—807’s allowed to run at MU speeds at the moment if driver is trained to or is there no MU speeds driving till December timetable change?.
Efini92
14 Dec 2016
No, no MU speeds until DAS has been agreed.
Railperf
30 Oct 2017
What happens on November the 10th? IS this a date when the DAS system is going to be accepted or not? In previous messages it was suggested the DAS system was struggling to reliably show location and permitted speeds. Is the location based on beacons or GNSS /GPS?
hexagon789
2 Sep 2016
Avanti have been compelled to withdraw 5 services from December due to Network Rail concerns over capacity, which the ORR upheld, the 1932 Chester to Euston is one of the five.
From RTT, looks like the 1702 from Euston (10-car 805) will run through to Holyhead, rather than dropping a set at Chester for the 1932 back to Euston as now.
It's hard to see what the WCML capacity problems are in mid-evening, preventing the 1932 running.
cambsy
6 Oct 2011
I hope we get running to MU speeds, and that DAS doesn’t end up meaning it doesn’t happen. It will be a real shame if DAS means a lot of time and money is wasted because of needing this system And then not being able agree to using it.
Efini92
14 Dec 2016
Sorry it should’ve said 5th November. It’s the closing date for the ballot. If it’s accepted DAS will be used.
I’m not sure, they have tested it to the MU speeds. I didn’t hear of any issues.
I believe it uses GPS.
