5Q92
MarkWi72
13 Nov 2017
Just seen this on Traksy heading through Atherstone. Any idea what this is? Heritage empty stock?
Northampton
Most likely it's mileage accumulation/fault-finding or -free running for new stock, I'd guess the new LNR units. Could be a test train. Empty Heritage stock would usually run as 5Zxx.
LAX54
15 Jan 2008
'Q' also means must not be routed off booked route, so if new stock, will have limited routing options
merry
19 Oct 2011
Realtimetrains has 5Q92 Crewe-Nuneaton and return as 5Q93. Booked as a class 350, so likely not a new unit unless just a placeholeder type for pathing.
Possibly test or training run.
Northampton
Yes, although you could also run a normal headcode with a RT3973 restriction form, or have no restrictions but running under a Q headcode to mark it as on a timing run/specific stopping pattern or whatnot. Headcode discipline's been slowly degrading for ages, with 9s, Zs and Xs appearing for convenience as much as need.
It's timed as a 350 because they won't have the SRTs in for now, partly because some of these runs will be used to verify the new SRTs! It's possible it could be a 350 but I think a 720 is much more likely.
warwickshire
6 Feb 2020
leamingtonspa
I have seen the 7206 c2c units on this run.
With the same headcodes previously as well.
But only when in passing at Rugby to catch something else.
MarkWi72
13 Nov 2017
Thanks all. I wondered after I posted if it was new stock , too. 720s do run between Nuneaton and Crewe
HOOVER29
26 Mar 2009
Usually a class 720
