As I understand it on modern signalling there are timeouts after a signal is put back to danger before the points it protects can be changed, but I doubt there was/is any such protection on purely mechanical boxes.Is that an old railway myth? It wouldn’t be possible to move the points in front of the train.
Dipping the throttle has almost no effect on a train. Way too much momentum for anything meaningful to occur.As a driver, do you have complete faith in the system and continue at line speed, or do human instincts cause you to dip off the throttle just in case?
Once the route has been set and the train has passed the junction signal the points are locked in place by means of track circuits. In the situation above it would be impossible for the route to be set for Halton curve and the points be set for the down main.As I understand it on modern signalling there are timeouts after a signal is put back to danger before the points it protects can be changed, but I doubt there was/is any such protection on purely mechanical boxes.
This one went in with the resignalling there in 1976, with a reversible line in the centre of two conventional direction lines, and was specially advised to drivers at the time that it could occur. Possibly the first one. It seems subsequently from the above to have been put into a couple of other Southern places that resignalled shortly afterwards. Possibly there was a Southern design engineer there who was attracted to the concept.happens every morning at London Bridge, at a closing speed of 100mph.
50mph through London Bridge, by two trains? Which ones do this?
There usually, or at least often, is. There's no such thing as a purely mechanical box nowadays anyway - there's invariably at least some electric locking. Normally approach locking is achieved by preventing the signal lever from returning fully normal until the timer has run its course (or the train has been proved to have passed the signal).As I understand it on modern signalling there are timeouts after a signal is put back to danger before the points it protects can be changed, but I doubt there was/is any such protection on purely mechanical boxes.
Why wouldn't it be allowed? They're not heading in to a head-on or side-swipe.Seen this video and it got me wondering: would a manoeuvre like this be allowed in the UK, or would sending trains as close as this to a head-on/side-swipe be forbidden in case of points failure?
Reddit - Dive into anything
www.reddit.com
Was that similar to the one at guide bridge where the signal man tried to beat the interlocking?There was an accident at hull where they managed it. The signalman was a bit quick replacing the signals after a train, allowing a conflicting movement. head on collision
The one at Audenshaw Junction (report on Railways Archive) was due to two deliberate acts of corner cutting by the signal man. The interlocking should have prevented it happening, but there is a limit to how far you can go to prevent deliberate acts: such things are very rare. And it was 1970.Was that similar to the one at guide bridge where the signal man tried to beat the interlocking?
Did it involve platforms 3 and 4?Interestingly, just seen something similar on a video at York station.
I've had it at York before when I was going north into platform 5 and a Northern train was coming out of platform 6 or 7 (southern bay platforms).Did it involve platforms 3 and 4?
I think so. Two 800s. One leaving south from the two main platforms in the front of the station and the other headed north to the platforms on the far side (NRM side) of the station.Did it involve platforms 3 and 4?
Not 3 and 4 then.I think so. Two 800s. One leaving south from the two main platforms in the front of the station and the other headed north to the platforms on the far side (NRM side) of the station.
Surely the whole point of the Westbourne Park autoreverse system is that it’s supposed to work without a driver in the cab?On the BBC News website is a clip from the 15 Billion Pound Railway called Emma comes close up to a driverless train (sorry, I can’t do a link). It is filmed from a train entering the southern reversible through siding at Westbourne Park while another comes out of the adjacent siding at speed. That seems fine to me, but I was taken aback because, so it seems, the train coming out had no driver in the leading cab. (Of course, it could be hyping it up to seem more dramatic.)
Indeed, but the idea of a train whizzing along with nobody looking out of the front window, who could react to something like a trespasser, is somewhat shocking to a signalman of my generation. Or is there somebody watching on CCTV? Alternatively, is the line completely separated by barriers?Surely the whole point of the Westbourne Park autoreverse system is that it’s supposed to work without a driver in the cab?
That would lead to an interesting question of what level of fencing is required to satisfy the ORR about driverless operation.
Right out to Westbourne Park carriage sidings, which are on the open? Are they isolated from incursions from the GWML?yes there’s barriers.
I hope you haven’t been on the DLR anytime in the last 35 years.
We have done quite well with this on the DLR for the last 35 years without issue or any of this stuff.Indeed, but the idea of a train whizzing along with nobody looking out of the front window, who could react to something like a trespasser, is somewhat shocking to a signalman of my generation. Or is there somebody watching on CCTV? Alternatively, is the line completely separated by barriers?
apart from a gap for the connections to/from the GWML, obviously.
That was exactly what I was thinking of: someone getting through by using one of these gaps. Youths on a dare?
I don’t know. I don’t have platform numbers memorised.Not 3 and 4 then.
From your description it sounds like the southbound train was leaving platform 5 with the northbound train going into either platform 9, 10 or 11, which would mean a movement as discussed in this thread.I don’t know. I don’t have platform numbers memorised.
looks about right in pictures.From your description it sounds like the southbound train was leaving platform 5 with the northbound train going into either platform 9, 10 or 11, which would mean a movement as discussed in this thread.
DO you have any information on how tall the fencing is? I've been unable to find a clear picture.that question has been resolved by this very issue.
