Wigan-Bolton electrification. Construction updates only please
Gricer99
21 Jun 2020
Hindley
The very first electric test train from Wigan North Western to Bolton and back, ran earlier this morning. Seems it was very successful as it ran early throughout.
pokemonsuper9
20 Dec 2022
Greater Manchester
Although there was a 2nd schedule that wasn't used, which might just mean they were confident enough in it or that there was an issue that needed to be fixed before they could go again.
Northampton
Well timed as a 15x and with that amount of pathing, you'd hope it ran early!
td97
26 Jul 2017
Entry into service was achieved over the weekend following Office of Rail & Road authorisation earlier in the month.
A £100m electrification of the railway between Wigan and Bolton is officially complete after overhead power lines were entered into service this weekend.
Overnight on Saturday (26 July), Network Rail teams unveiled new train driver signage and removed barriers at stations which have seen platforms extended in the final stage of the major multi-year investment.
It follows successful test train running and regulatory sign-off in recent weeks to commission the newly installed infrastructure along the 6.5-mile route between the two towns.
darylyates17
8 Nov 2015
St Helens
John R
1 Jul 2013
£5m per single track km doesn’t sound like exceptionally good value for what should on the face of it be a simple scheme, being a short extension of an existing network and relatively low speed too.
59CosG95
18 Aug 2013
Beeston (Notts)
The cost likely includes the numerous bridge rebuilds that dogged the scheme in the earlier stages.
The exile
31 Mar 2010
Somerset
“Short” does not necessarily imply cheap - as fixed costs will get spread over fewer km. Any ex-industrial / mining area is always going to be anything but “simple”. Going to stick my neck out and say if you want low £/stkm try Grantham - Skegness (and put any resignalling required in a separate budget!). Of course there’s plenty of economic reasons why you wouldn’t…
Northampton
It being short means less economies of scale, although £5m/stkm isn't brilliant. Peak GWML cost was apparently £4m/stkm although that was a while ago.
Nottingham59
10 Dec 2019
The important comparator is what was the expected cost at the time that the decision to electrify was made?
Geeves
6 Jan 2009
Rochdale
The red iron bridge that had to be raised, have extra ramps installed and all the associated engineering works Vs just taking it down springs to mind!
pokemonsuper9
20 Dec 2022
Greater Manchester
They still haven't installed those ramps yet! There have usually been some people around it when I've been passing it so hopefully we see access restored soon.
Nottingham59
10 Dec 2019
I can’t link to it currently but as recently as last summer Northern was quoting £78m.
According to Modern Railways in 2021, the cost at approval was £78m.
There were sucked teeth in the industry when Government approval for the electrification of the six miles of double track railway between Wigan East and Lostock Junction was announced at the beginning of September. The cost of £78 million equated to £3.9 million per single track kilometre (stkm).
Gricer99
21 Jun 2020
Hindley
They are aiming for it to be ready by October! Plenty of activity now after months of inaction.
15 Oct 2020
Formby, Liverpool
I travelled this line on Saturday 2nd August on the 2O79 1503 Service from Southport to Manchester Oxford Road on a Class 769. I wondered whether it would switch to Electric power from Wigan Wallgate (or possibly Ince as I am not sure the platform at Wallgate was electrified) but when I got off the train at Westhoughton it still had the pantograph lowered, and it definitely departed using Diesel power. Later that same day on my return journey, I observed a later Service 2O74 2049 Class 769 service Southport to Manchester and that definitely had the pantograph raised at Westhoughton, and departed using Electric. At what point are they supposed to switch to Electric Traction or is it at Drivers discretion?
Paul AC
3 Aug 2025
Timperley
There is no wiring at Wigan Wallgate: a 769 via Wallgate should change mode when stopped in the platform at Ince, both ways, and that has happened on the 6 or so services I have caught since the first day (last Monday).
I note from RTT https://www.realtimetrains.co.uk/service/gb-nr:W49688/2025-08-02/detailed that your 2O79 was 769450, and according to RTT it completed its diagram that day including running into Wigan North Western then ECS to Allerton depot. It is possible that it had developed a fault that was stopping it from running in electric mode, but I doubt that it would have completed its diagram pretty much on time all day if that was the case. I suggest that either the driver forgot, and changed at Bolton instead, or maybe there was some element of training the driver hadn't received.
TrainzBK
9 Apr 2018
450 ran on diesel throughout it’s entire diagram on the 2nd I believe, if it wasn’t 450 there definitely was one 769 that was stuck in diesel all day.
15 Oct 2020
Formby, Liverpool
Thanks for the response. I am not a regular user of that line, the one day do have an excuse to use it I get a Class 769 stuck in Diesel traction, and my return trip was on a Class 156, so I have yet to ride it under Electric Traction :frown:
John R
1 Jul 2013
Thank you. So even £78m raised eyebrows in the industry as to how much it was costing, and yet on completion it appears to have cost £100m. Even allowing for inflation, that’s a sizeable overrun.
on these figures, allowing for inflation it is under budget.
RPI since June 2021 has been +33%. That £78m then is the same as £104m now.
Dr Hoo
10 Nov 2015
Hope Valley
So how much per single track kilometre (stk) does that work out at? An ‘under budget’ figure from a team already experienced will be a useful benchmark for what is the best that we can expect nowadays?
Northampton
Modern Railways in the article linked above claims that the original £78m worked out at £3.9m/stkm. 78/3.9=20, (which is slightly more than 6 route miles of plain double track, so presumably includes some crossovers/overruns).
£100m over 20stkm would be £5m/stkm. Bear in mind that for a short scheme like this the project overheads are only being spread over a few stkm, not hundreds as major projects are able to do. Also the reported figures might be rounded off.
Adjusting for inflation is always tricky over a multi-year project, but the various calculators seem to suggest that £5m is right in the ballpark for an at-inflation increase on £3.9m. This scheme will be more expensive per stkm than most due to it's short length (possibly mitigated by being close enough to Manchester-Bolton electrification to benefit from that?) Oh, for a rolling programme with strategic vision!
Would be interesting to see a breakdown of the costs broken down into fixed across the project and variable by stkm.
Dr Hoo
10 Nov 2015
Hope Valley
Were there any ‘feeders’, substations and whatnot on a short scheme like this that meets existing catenary at both ends? Wouldn’t that tend to make it ‘cheap’?
Trainbike46
18 Sep 2021
belfast
I may be wrong, but I thought this project had an unusually high number of structures that needed work, which would drive up the price per stkm.
Northampton
According to the NR Press release there were no Feeders or substations, but there were:
Since 2022 the project has seen:
  • 21 kilometres of power lines installed
  • 414 new overhead line equipment stanchions erected
  • Six road bridges and one footbridge completely reconstructed
  • Modifications to 17 bridges and two-level crossings
  • Signalling and track upgrades completed
  • Platform extensions at Hindley, Westhoughton and Ince stations
6 bridge reconstructions, 17 bridge modifications for a total of 1.1 bridges/stkm won't help keep costs down. 2 LC's is also a big lump that can't get spread out in the averaged figure.
Dr Hoo
10 Nov 2015
Hope Valley
I thought that ‘bridge modification’ usually meant higher parapets with steeple copes and other anti-trespass measures. These can’t be avoided by track lowering and insulating paint.
I get that no two routes or schemes are identical but isn’t it just a case of ‘win some, lose some’?
I reckon that £5,000,000/stk is a good rule of thumb at modern prices when envisaging or proposing new schemes.
Trainbike46
18 Sep 2021
belfast
It depends - it looks like both MMLe and the recent Scottish schemes are cheaper than that.
Bridge modifications can mean quite a range of things. Averaging a bridge reconstruction, which is much more significant, per mile will have added to costs too.
Why are platform extension counted as part of an electrification scheme?
