Why white/silver liveries?
L+Y
4 Jul 2011
Just a quick and simple question: what (if anything) is behind the roll out on seemingly the majority of TOCs of primarily white/silver liveries?
387star
I'm hoping the 700 livery is brightened up before too long
The main answer is obvious: neutrality
the government is after a move away from corporate identities that are tied to a franchise holder's name and hard to eliminate come inevitable change
so yes Northern, Thameslink and Great Northern, Greater Anglia and C2C all employ white or grey liveries. Thankfully Southeastern is moving away from white on their 375s!
Wivenswold
24 Jul 2012
Essex
GA's looks very smart with the addition of dark grey whereas TL/GN/C2C isn't really a livery, just some painted doors and a logo.
TheEscapist_
18 Nov 2011
White just doesn't work unless it's cleaned a lot. Check VTEC HSTs the doors are horrid.
Sent from my iPhone using Tapatalk
Lrd
26 Jul 2010
Same for the Class 444s. Not sure if they've been cleaned/repainted recently but they were pretty grimy, especially near the roof.
cjmillsnun
13 Feb 2011
To be fair to the 444s they have not been repainted in over 10 years.
507021
19 Feb 2015
Chester
Easy to vinyl into something else?
I think it's this reason, because it will be a lot cheaper for future franchise operators to repaint the fleet into their own livery. I still think base white/grey liveries can be smart, but only if there's a decent amount of other colours to break it up. Northern's is pretty good, but Thameslink's very bland livery doesn't do anything for me at all unfortunately. Greater Anglia's isn't too bad, but it's not great, in my view.
The only exceptions to having a base white/grey livery at the moment seem to be GWR (green), Merseyrail (primarily yellow) and ScotRail (blue). It'll be interesting to see what happens with future franchises though, that's for sure. Personally, I'm all for having permanent brands and liveries as it'll be much cheaper and also very little will need changing when a franchise changes operators.
For exactly the same reason that airlines are all tending to 'Eurowhite' with a splash of colour - it's easier to place the asset with a new lease if it doesn't have to be completely repainted.
Mikey C
11 Feb 2013
Isn't white popular as it reflects the sun more?
Taking BA, AF and LH for example, the vast majority of their fleets will serve its full life with the airline
Mikey C
11 Feb 2013
The Southern and London Midland liveries are fairly "non white" as well, while the Southeastern High Speed (and new general) livery is blue
507021
19 Feb 2015
Chester
I was more speaking in terms of recently renewed franchises (I should have made that clearer), although Merseyrail (last renewed in 2003) is an exception to this however because it's always had a predominantly yellow livery for some time now, and I don't think that will be changing.
While the thermal effect is a factor, it's mainly about leases on aircraft.
AF's livery has been mostly white for a long time. BA's has progressively lost white and gained blue. Lufthansa replaced bare metal with grey over the years.
59CosG95
18 Aug 2013
Beeston (Notts)
The Virgin Pendolino/Voyager fleet have a lot of silver on them too, and that part (not so much the red) picks up dirt quite a lot. I do wonder what the fleet will be repainted in come the new Widnes Alstom plant opening.
You mean, presumably, the next franchise? I can't see VTWC repainting them in anything now.
Very true, I forgot about those ones somehow. It'll be interesting to see if Southern goes the same way as Thameslink, though.
Southern green is of course white-based.
As for Northern, I still don't like it. White looks terrible with no window band. The 156 looks less awful than the 150, but only just. Add a charcoal or dark blue window band and it'll work.
BMIFlyer
13 Mar 2017
The entire 390 fleet is actually due a repaint as part of the recurring maintenance program. They will be redone in the current colour scheme.
A little bird tells me that the next franchise has to design a new livery (as the DFT moves away from corporate liveries of the owner) and this will be vinyl applied in due course, like what TPE and Scotrail have done.
I really don't get why this is being done (sensible though it is) by franchise, ScotRail aside, and there isn't a national InterCity and Regional livery being used instead, with smaller "operated by X" decals like with ScotRail.
hotelmode
23 Jun 2009
It really isn't about leases. BAs aircraft (and I assume the other majors) are mostly mortgaged not leased so it's not even a factor. That's why they are generally kept until retirement.
No gain in blue either, it's the same basic livery since Utopia in the late 90s.
BMIFlyer
13 Mar 2017
It would be a nice idea what you suggest, but then in an ideal world you'd need all the trains with the same branding on the exterior to have the same interior decor etc.
It's not going to happen. Scotrail is easy, as it's one giant operation.
Would you?
London buses all have standard exterior liveries but differing interiors based on operator. Indeed, the interior is just about the only way they can put their stamp on it.
Mikey C
11 Feb 2013
Would you?
Even there, there are moves towards standardisation
The Borismasters are all identical inside, and I believe the Enviro 400City has the same TfL Borismaster seat moquette
