Correct, it’s to thin out the services running through the area as there is a 20mph speed restriction. You’ll see that most services running via the Trent valley are arriving into Euston late. I believe it’s a request network rail made.It's due to the landslip at Polesworth meaning the up slow is not available for use. Or so claims the Avanti website.
Up Trent Valley Slow is blocked and has a temporary support structure constructed in it.It's due to the landslip at Polesworth meaning the up slow is not available for use. Or so claims the Avanti website.
Should be 50 from the morning.Correct, it’s to thin out the services running through the area as there is a 20mph speed restriction. You’ll see that most services running via the Trent valley are arriving into Euston late. I believe it’s a request network rail made.
They won't anyway before New Year as Crewe being shut for all or part of that week won't allow it.Will Avanti bother to put them back next week when Monday is the only full day?
Services finish early Xmas Eve and start later on the 27th
