MidnightFlyer
- Joined
- 16 May 2010
- Messages
- 12,856
Just reading through these pages, you just get that feeling. is it the stock, the timetabling, the on-board stuff, or just Arriva?
The main problems with the XC franchise are the high fares, even for advance tickets, and the design of the Voyagers, There is insufficient luggae space, and some seats do not give you a view out of the window.
It went bad when they introduced Voyagers, and Op Princess was over-amboitious. XC went worse when they took out shops to put in bike stores, and when they put on super-nice HSTs, then take all but one out of use and put Voyagers back on.(that bit about the HSTs may be wrong -- not my area of rail interest!)
XC use 2 HSTs Mon-Thu and 3 on Fri. On Sat and Sun it varies and is sometimes up to 4. I'm intrigued by your comment about when Voyagers came along. I can find, without looking too hard, plenty of vidoes of failed 47s, 86s and even the hallowed HSTs being dragged by all manner of freight locos running hideous amounts of hours late. The counter to this will no doubt be 'poor maintenance', but a clapped out 47 or AC electric will always need more frequent maintenance than a newer DMU. And at least Bombardier can switch engines out on Voyagers very simply and keep the unit running, don't think it's quite so simple on any of the locos mentioned, especially 86s. People also lambast XC for no longer running the truly random trains you used to get under BR, such as a Fishguard to Dundee via Swindon and Preston (I'm deliberately using hyperbole). But under privatisation, where a TOC can only call on it's own traincrew, rather than a nationwide pool of route/traction knowledge, that's never going to be practical. Think of all the route learning and refreshing crews would need to do. XC is a franchise that will constantly be under change and getting remoulded to the needs of the customer, but sadly rolling stock is the most expensive variable in all of this, and at these austere times there's little chance of that changing any time soon.
Personally as a TOC i think us guys and gals on XC do a good job Dont blame us for Virgins errors
Engines aren't my thing - I couldn't even tell you want used to do XC trains. I meant, to me, the old IC stock had nice interiors, more seats etc. The Voyagers are RyanAir planes on rails. Sorry - just really really horrible. HSTs were just great on XC
The voyagers are good trains but often overcrowded had they been 6 or 7 carraiges it would be better. But Arriva have to work with what they got Arriva didnt order the voyager VIRGIN did.
Virgin XC might have ordered the trains, but from what I understand they were spec'd by DfT so in that respect Virgin XC had to work with the spec they were allowed by the DfT and given the increased frequency, 4 & 5 coach 220/221s were considered sufficient..
It seems strange that they are being criticised for being over-priced *and* over-crowded... do you honestly expect them to introduce hundreds of "bargain" fares when they struggle to provide a seat for existing passengers on many journeys?
XC is in an impossible position. The trains are often crowded, yet the franchise isn't making enough money - I'm not sure how it could "square that circle" easily.
Best thing to do, IMHO is abandon the real "cross country" element, forget about Aberdeen to Penzance journeys - either split most journeys at Birmingham (with a handful a day from one end of the UK to the other) or concentrate on the "core" York/ Manchester/ Bristol/ Reading service for most services and let the likes of First Great Western provide the links to places like Brighton/ Swansea/ Penzance.
I appreciate the above won't go down well on here, and that a Lot of people like the "one a day" services and think that there is demand to go from Cornwall to Grampian, but...
and I think that XC has no need to go to brighton
There aren't any XC services to Swansea, and I think that XC has no need to go to brighton, which is very well served by other operators with plenty of services
But Penzance is a different matter. XC does provide valuable extra capacity in the South West and is used for local journeys in Devon and Cornwall. Where it;s right that there's little demand for through services from Cornwall to Grmapian, there is a market for journeys to Bristol and Birmingham from Devon and Cornwall, which is reliant on the XC service from Plymouth.
Sadly any additional coaches in the Voyagers MUST be poweredsurely adding one coach per train, and spreading it out over a long period, would provide the capacity at little extra cost
