ac6000cw
I also recall reading about the experimental use of aluminium - instead of steel -conductor rail in order to save both costs and weight....although I have a feeling that that may have been part of the Portsmouth-Eastleigh/St Denys electrification scheme a few years later.
AFAIK, the main reason for using composite aluminium and steel conductor rail is because aluminium is about 6x better (lower resistance) conductor of electricity than steel. This means you can potentially extend the distance between feeder stations, thus needing fewer of them which lowers the overall cost of the electrification scheme.rom the minutes of a meeting held in late '89, for the South Hants scheme, the said rail is referred to as 'Composite Conductor Rail', and there is brief mention of further staff consultation being needed in relation to the maintenance of same, so obviously not bog standard conductor rail at the time?
(Basically the aluminium is the main conductor, with steel for the contact surface - it's much harder wearing and can withstand the arcs that can occur between pickup shoes and conductor rail - aluminium melts at quite low temperatures compared to steel).
