What is this thing in the 4ft at Derby Station
Waterlemon
18 Sep 2023
Waterloo
Could only see them in platform 3 + 4. They don't appear to be attached to the axle counter
m0ffy
24 May 2022
Leicestershire
I don’t know, but it looks a bit like a domestic CCTV camera, encased in a tougher shell. Strange all round though - it looks like it has been slung in and just left.
endecotp
23 Apr 2014
Is the part in the first photo a solar panel, powering whatever the thing in the second photo is?
Expression357
16 Jul 2009
Essex
That appears to be a camera. Expect it to be suitably High Def.
For some defects they can be used to monitor deterioration or to reduce the need to undertake a block after the passage of every train. Reduces the boots on ballast.
Geeves
6 Jan 2009
Rochdale
It's monitoring wheel position in relation to the axle counter. Many delays are occurring when trains roll back even tiny amounts, as it knocks the axle counters out of sync and leaves the section showing occupied, it's quite a process to fix it.
Here's the set up at Manchester Victoria. Lots and lots of Axle counter issues.
Waterlemon
18 Sep 2023
Waterloo
Ahh interesting. Thank you!
Bigfoot
2 Dec 2013
There are quite a lot of remote cameras across the rail network. Temporary ones used to monitor issues to save having a human having to take long winded line blocks to make inspections between trains. Also some permanent ones on problematic junctions/point work and like this here on axle counters.
