What is this coach?
EltonRoad
2 Jun 2009
Kendal
Can anyone help me with this train? I photographed it at Kinloid on the Mallaig line last month but need to know what is the coach and ideally what was the train doing. The coach I believe is TIC 2 - perhaps track inspection coach? Many thanks.
Wikipedia
4 Jan 2011
Not sure but it would appear to have a generator (I would assume) fitted judging by the black mark on the roof and some underfloor gear as well!!
rebmcr
15 Nov 2011
St Neots
Why would this need a second 37? It's clearly not for traction effort, nor can I imagine that the risk of breakdown is this critical (unlike the flasks).
Is it just filling in as a DVT? Essentially a "DMT"?
High Dyke
1 Jan 2013
Yellabelly Country
Not entirely certain, but there was a similar combination doing the rounds of the Nottingham - Lincoln line recently. Two different 'test' trips in the same week.
Topping & tailing with the Class 31 was 97304 (Cl 37)
Flying Snail
12 Dec 2006
A combination of both reasons, redundancy in case of failure is a bonus but the ability to reverse direction without having to run-round would be the main reason. Apart from the increasing number of locations where running round is now impossible due to rationalised layouts, even where the trackwork still allows it the delays and clogging up of busy locations mean it is avoided if at all possible.
To think that something that was done thousands of times a day in hundreds of locations at one time would now bring the entire network to it's knees if suddenly required. The railways are so dull nowadays in comparison.
DarloRich
Fenny Stratford
save running round & to provide a way of getting the thing moved in the event of a failure
have you got a number and i will tell you
