What in the class 91 is going on here?
yoyothehobo
21 Aug 2015
In the youtube link below at Stoke Tunnel there are some very very curious 91 movements from 1989.
These include what looks like a charter train and some running with 5 mk3 sleeper coaches both forward and blunt end forward.
Anything to shed light on this mystery?
24 Nov 2019
Testing of the 91s in different configurations before they entered squadron service?
Flying Snail
12 Dec 2006
It was originally planned that the 91s would do more than just the core ECML IC service, fast freight such as parcels, sleepers and I suppose charters as well. It is part of the reason why they were built with the second blunt cab rather than as a single cab power car.
hexagon789
2 Sep 2016
Mk3 sleepers were often used in the 91 testing as before the Mk4s appeared in any significant numbers, they were the only spare coaches BR had that could be run at 125mph. They had an excess of them, as too many were built for the declining sleeper traffic requirements.
Stampy
21 Sep 2014
Peterborough
I can still remember the 91's running with a HST power car on the other end - those things SHIFTED....
hexagon789
2 Sep 2016
At least 8,315hp short-term, probably slightly higher.
(Based on the 91s short-term output of 4,830kW (6,477hp) and an HST's traction motor rating of 1,838hp continuous.)
sprinterguy
4 Mar 2010
Macclesfield
Class 91s were used on some Hertfordshire Railtours charters on the ECML immediately post-electrification.
The sleeper stock, as noted above, was commonly used for test workings as they were rated for fast running and available.
DarloRich
Fenny Stratford
I recall going to London around the time of ECML electrification and seeing a couple of rakes of mkiii sleepers stabled at Newark Northgate. That was very exciting. We didn't get sleepers on the ECML!
it is only in later years that one learns they may have been there for testing purposes.
Strathclyder
12 Jun 2013
Clydebank
As has been pretty well documented, the HST power cars were used as DVTs with the 91s initially with the engine left at idle for auxiliary purposes; the power cars had at first been converted purely for testing the 91s when released from the works. Worth mentioning here is that there was something of a precursor to this practice on the WCML, with a 86 and 43 sandwiching a rake of Mk2s (linked images below).
However, the Valentas didn't much like being left at idle for extended periods and after several exhaust fires - unburnt fuel building up in the exhausts; a particularly bad one damaged several hundred yards of freshly installed OHLE - modifications were thereafter made to the control system so that the 43 could supply traction power normally. The result was, like you say @Stampy, akin to a hot-rod with nitrous installed.
(copyright of Flickr's blackwatch55013 aka John Webster)
Helvellyn
28 Aug 2009
I guess on the WCML 43123 was just dead to act as a DVT because the 86 was providing the ETH, whereas on the ECML the power was needed to provide three-phase supply to the HST trailers given HSTs didn't use ETH. So the exhaust fires would have been unexpected.
hexagon789
2 Sep 2016
Correct, the engine was isolated and the power car purely used as a driving trailer.
43096
23 Nov 2015
But they presumably could not run above 110mph when working just with the sleepers as there was no brake pipe pressure control unit (E70 or DW2) at the rear of the train.
Strathclyder
12 Jun 2013
Clydebank
That does make sense, yeah. Sticking with this and a idle thought has been nagging at me: did the 89 ever find itself working with the HST DVTs post-modification? I'm aware that it worked with them on Peterborough - King's Cross peak hour runs when it first entered service, but I'm referring to the post-exhaust fire period here.
61653 HTAFC
18 Dec 2012
Is it just me that found the most unusual movement in the video to be the 156 appearing on the southern ECML? :lol:
Sun Chariot
16 Mar 2009
Some more info on this recent thread
OPs video, 1m 45s to 2m 05s shows the Tees-Tyne Pullman HST service:
Three FOs, two with Pullman crest amidships,
The TLUK (I think) third carriage from front.
hexagon789
2 Sep 2016
The sleepers were usually run with a 'surrogate' HST PC DVTs and often the Mk3 test car.
Not sure if they ran without a DVT other than with Mk2s.
Yes, though it lacked TDM initially so ran services such as 1735 to Peterborough, which was usually an HST set anyway, with a Mk1 BG included as a barrier vehicle and the set hauled conventionally.
I don't believe it gained TDM until into Mk4 days, when it was often used on similar duties to its GNER period, until it suffered a major failure and was stored at Bounds Green.
23 Nov 2015
See the video in the OP’s post for examples of them running just with sleepers.
There was at one point three test/commissioning sets for the 91s, all of which had a Mark 3 RFM in them. Don't think the RFMs lasted long before they went back to the West Coast again, but formations were reported as:
BN81 10202 10511 10521 10619 10706
BN82 10206 10509 10611 10618 10654
BN83 10204 10517 10518 10525 10615
Strathclyder
12 Jun 2013
Clydebank
As illustrated by Martin Loader below, on both the morning and evening workings it was initially assigned to:
I did suspect that it didn't gain TDM until the Mk4 era, just thought I'd ask either way.
I thoroughly enjoyed that as well to be honest
North West to East Anglia duty presumably. The blind looks to read "Norwich".
156403 and it definitely appears to be on a Norwich-bound working there if the blind is to be believed. It's origin point I couldn't tell you tho.
hexagon789
2 Sep 2016
Thanks. To be honest I think I was having a senior moment and thought the footage was from further south!
I wondered where 'south' was myself until I read it was only Stoke Bank! ;):lol:
Having since checked on the Train Testing website, it does appear to have been into the mainstream Mk4 era, when the surrogate HST push-pull sets were no more.
I'd assume a Birmingam or Liverpool to Norwich working.
Strathclyder
12 Jun 2013
Clydebank
I suspected as much.
Yep, as would I. I too thought for a minute 'what on earth is a 156 doing on that part of the ECML?', before I realized it was only Stoke Bank lol
Magdalia
1 Jan 2022
The Fens
The first batch of class 156s were new to Norwich in 1988, and they were used on the cross country services between East Anglia and the Midlands/North West. The class 156s were relegated onto the local services a few years later after the arrival of class 158s.
hexagon789
2 Sep 2016
They might have permitted it in testing, having no rear brake unit. Either that kr imposed a 110 or even 100 limit, as when the 91s ran tests with Mk2 vehicles?
There were tests conducted with an 86 on the WCML in the early 70s, IIRC at up to 129/130mph (125 limit was set for testing), the Test Car was on 90mph bogies(!)... and I doubt they had any form of rear-end brake control.
It'll be a Northwest - Nottingham - Norwich working, the Birmingham trains normally go via Stamford so don't run over Stoke Bank.
Did they do that back in 1988 as well though? I had an idea that the initial Sprinter timetable of cross-country workings towards Ipswich/Norwich was more varied in routings than today.
43096
23 Nov 2015
I would be amazed if normal training/commissioning runs allowed 125mph running without a rear brake unit as it is linked with braking distances. Some specific testing under test conditions with DM&EE staff, possibly, but not more widely.
Strathclyder
12 Jun 2013
Clydebank
Cheers for the info/memory refresh there gents. :) I had known about the initial allocations & workings of the first 156s, but had forgotten key details.
Magdalia
1 Jan 2022
The Fens
Yes. The big timetable change was May 1988 when the loco hauled trains were replaced with class 156s and a very different timetable. Broadly speaking Norwich had 1tp2h to/from Birmingham and 1tp2h to/from Liverpool from May 1988.
Deepgreen
12 Jun 2013
Gomshall, Surrey
Interesting, if unsteady, footage, seemingly taken from inside the fence...
