What happens to ES when HS1 shuts?
itsjamierawr
2 Jun 2013
I noticed today that there are bus replacements between Ashford Intl and Ebbsfleet Intl, obviously it's fairly easy to replace the domestic service but what do they do about Eurostar? are they diverted somehow, not run at all or do they terminate at Ashford and passengers clear passport control there to board a bus?
philjo
9 Jun 2009
My interpretation when reading this was that the engineering works were taking place at Ashford station so the Eurostars would just bypass Ashford on HS1. Therefore they would not be affected as there is no mention of disruption for passengers from London.
thelem
17 Mar 2008
@philejo that might apply in this instance, but I think the question was asked more generally.
What about when the tunnel itself is shut? Or can all work be done overnight?
Hophead
5 Apr 2013
Eurostar would have to terminate at Ashford and do a deal with either Southeastern or some local bus / coach companies.
The trains no longer have a 3rd-rail capability, the drivers would not know the route, there's no way to get the trains to St. Pancras (Waterloo's platforms are slowly being turned over to domestic use) and, in any case, pathing would be somewhat problematic.
HS1 was built in such a way that all routine maintenance, and indeed routine track renewal, can be done with trains running on one of the two lines with a speed restriction, or in the periods overnight when no trains operate. Any major stuff is done on Christmas day.
user15681
3 Jun 2012
As Bald Rick says really.
Tunnel is bi-di with two crossovers between the two running tunnels - located a third and two thirds of the way through.
For this weekend, the possession was only around Ashford station. Specifically the Up and Down Canterbury - platforms 5 and 6, Up and Down CTRL Chord - platforms 3 and 4, part of the down slow, the down fast, Maidstone loop and Maidstone relief. Possession only until 1710 if I remember right.
In general, ES would terminate at Ashford and then an agreement would be in place with the TOC or a bus company.
FlippyFF
5 Jan 2014
Ashford, Kent
I live about 100 feet from HS1 * at Ashford, I can confirm ES have been running all day and as I type one has just gone whooshing past.
As for overnight maintenance, are there freights using HS1 at night now? To/from Ripple Lane?
* Close to what Realtimetrains calls "Ashford West Jn (Ctrl)"
Simon
There are only a handful of freights so it should be possible to get these past any engineering closures by single line working.
NotATrainspott
2 Feb 2013
Something that may change how Eurostar/HS1 operates when Ashford is closed is that the Eurostar platforms at the station are not part of HS1 per se, but are actually on the standard NR network and were rebuilt to UIC GB+ gauge (by raising the track level and sluing them away from the platform edge) when Section 1 opened. Unless I'm reading the HS1 (Section 1) Register of Infrastructure wrong, it appears that high speed trains stopping at Ashford also have to cross over to the BR signalling systems rather than remain on the high-speed TVM system as they do on Section 2.
FlippyFF
5 Jan 2014
Ashford, Kent
There are signs at the HS1 / NR boundaries that have "CTRL" with or without a diagonal line through them which I've always taken to mean either the signalling or maintenance boundaries. (Happy to be corrected). I can't, at the moment, recall if there are 'NR' signs too?
Simon
Antman
3 May 2013
If HS1 is closed is it possible to run Javelins via Tonbridge and London Bridge to St Pancras Thameslink station if those lines are not affected by engineering work?
LowLevel
26 Oct 2013
I think the approved diversion is to Victoria?
starrymarkb
4 Aug 2009
Exeter
Yes and not sure. I wouldn't be surprised if ECTS isn't overlaid at some point (IIRC HS1 is going to be fitted with ECTS in the not to distant future so it may be easier to put ECTS level 1 - level one is just repeaters of the existing signals.)
455driver
10 May 2010
WHAT, no trains on Christmas day! <D
How dare those lazy traincrew have a day off, it is disgusting, dont they realize there are thousands of people who want to go to Paris shopping on Christmas day, they should be made to work!
Just thought I would start this years moanfest off a bit early!;) :lol:
Clip
28 Jun 2010
You get earlier every year ;)
FOH
17 Oct 2013
A ha, this explains why yesterday I was on a train from Paris where the screens said only London yet the train manager announced Ashford as well. Needless to say we swept through Ashford at high speed but then crawled from Ebbsfleet (presumably we were early and caught up with a Javelin).
FlippyFF
5 Jan 2014
Ashford, Kent
Are they (Southeastern HS) running again on Boxing Day this year?
Don't think Javelins have ECTS anyway - only TVM for HS1 and AWS/TPWS for the classic network.
I doubt Javelins are permitted through the Thameslink core and I don't know why anyone would want to do this as there won't be the capacity to take diverted services. Also Javelin 25kV mode is presumably optimised for the constant height overhead of HS1 so could cause all sorts of trouble on the up-and-down overheads of Thameslink.
Class377/5
19 Jun 2010
No way is a Javelin allowed through the Core. Only the 319s, 377/2, 377/5, 387/1 and 376 (as far as Smithfield Sidings but not to Farringdon) currently permitted north of Blackfriars platforms. In four years everything bar the 700s will be banned from entering in service.
Think we might let the odd 377/5 through if someone asks nicely.
AM9
13 May 2014
St Albans
Aren't the 395s a bit long for some of the bends as well?
cossie4i
2 Jun 2014
Somerset
395s also have KVB which is the signalling system used between St Pancras and LT1.
395s can be used on domestic AC but restricted to 100mph. The units have 3 power modes, CTRL, DC and AC hidden under a protective cover.
