Halifaxlad
Hi all I am looking for clarification, specifically whenever drivers can leave their cabs to deal with an emergency involving passengers?
I left the cab earlier for a quick loo break. Arrived a couple of minutes early into a station so secured the cab and popped back. We’re hardly ‘trapped’.
Just put the brake handle to fully on, no need to put in emergency but otherwise yes, just as you say.What would you do to secure the cab ? Emergency brake, DRA, Master Switch to OFF and Master Key removed, is that it/the right order ?
NOTHING has prompted this, its just a query.
I do remember reading something about drivers not being allowed to leave their cabs for some reason or another.
Depends on the driving policy of the company who operates the train. Some require the train to be left in emergencyJust put the brake handle to fully on, no need to put in emergency but otherwise yes, just as you say.
I didn't realise they didn't do that anymore!Until a few years ago it was common for the driver to leave the cab to call the signaller on the SPT.
Except when the bloody thing fails. Worse, I think is the removal of SPTs We now have a rather large area where they no longer exist. The lunacy is that the number provided to call cannot be called using the GSMR. Whoops !
Would drivers in diesel only areas/traction have training for isolation of power lines?Do I need lines blocked ? Isolation ? What equipment to grab etc ?
Anyway what does everyone think of Regulation 4 of The Railway Safety (Miscellaneous Provisions) Regulations 1997.
"Regulation 4 places a duty on operators of vehicles being used for the carriage of fare paying passengers to provide and maintain means of communication between passengers and a person who in an emergency is in a position to take appropriate action.
http://www.legislation.gov.uk/uksi/1997/553/note/made
It would seem that this would apply to drivers when trains are ran without a guard.
Isn't that referring to the passcom?
Of course. All Driver's need to be able to take the correct action in an emergency.
On 15x traction (and presumably 14x), there's no specific indication that a passcom has been pulled - only that you'll lose the brake and there'll be a hazard light lit on the affected vehicle (which could be caused by some other things). It's usually easier for the Guard to investigate further, especially if it's at their end of the train.If a Guard is roaming the train and a Passcom is activated then they would (on our units) have no idea that one has been pulled. The alarm sounds in the cab. It would need someone to confirm how the Passcom is operated on each specific unit where Guards are provided and how they would be notified a Passcom has been activated. But I suspect that it is purely for the Driver in all cases. Happy to be corrected.
Not required if you key out. Key out automatically puts brake in emergency. Emergency if you leave the cab without keying out.Depends on the driving policy of the company who operates the train. Some require the train to be left in emergency
