What are considered high value passes and low value passes on the TFL network?
Denim78
24 Mar 2026
Greater London
Hey,
Ive been watching a load of those fare dodger programmes and they mention high value passes a lot but when I try and do some research, there’s not a clear document online stating what TFL considers a high value pass and low value passes?
MrJeeves
28 Aug 2015
Burgess Hill
Typically anything with a discount (or free) travel.
That might include Freedom Passes, Staff and Nominee Passes, 60+ Oysters, Zip Cards, Apprentice/Student Oysters, Priv/PTAC-discounted Oysters etc.
I also keep thinking that I see a yellow light illuminate for my Railcard-discounted Oyster, but I'm never entirely sure!
1 Nov 2010
Here there and everywhere
Mine has at some stations, usually overground served ones I've found
Both you and @MrJeeves are not seeing things. Those yellow lights are for the benefit of revenue protection staff and basically flag up when a particular ticket type is used (programmed in the barrier's control unit). A lot of the time it's forgotten about and left programmed in from the last revenue blockade.
Denim78
24 Mar 2026
Greater London
Thank you very much for letting me know
Fawkes Cat
8 May 2017
Hey,
I would speculate that it's a convenient way to select travellers to challenge: anything that gives an open-ended discount is at risk of many, many free journeys being made on it, whether legitimate or otherwise. Compare that to (e.g.) a travelcard on an Oyster which realistically is time-limited to how much evasion can take place - and which has been paid for in the first place, which also limits the amount of money that TfL are losing.
But this is nothing more than convenience for TfL. I don't see any reason why TfL might not choose to look at a wider range of tickets being used for fare dodging. TfL are probably as aware as everyone else of the risk of fishing out the pond: at some point they'll find it's easier to tackle fare dodging by pursuing other risks. So no one can afford to assume that fare dodging with something other than a high value pass will go undetected.
ChilliSauce
28 Oct 2025
Hey,
To try and answer your initial question:
The highest value of 'high value pass' could very well be the Active Staff (light blue) and Retired Staff (dark red) Oyster Cards ..
These are available for use 24/7 and on underground / overground / red buses.
Joshua_Harman
2 Feb 2021
And Bus drivers, Purple oyster
