West Yorkshire Daysave
hornbeampark
27 Dec 2023
Harrogate
Hi There,
Probably a daft question.
Does the West Yorkshire Day Save peak time restriction mean you cannot start a journey between those times or does it mean you cannot be found on a train between those times.
Cheers!
Adam0984
18 Feb 2014
It the departure time of where you board so you're fine for boarding a train at Leeds at 15:58 but if you were to board the same train at the next station at 16:06 it wouldn't be allowed, of course the peak restrictions are only Monday to Friday
Barnsley
20 Feb 2010
Barnsley
As long as you start before 1600 you are fine, but you can't change trains any where once past 1600 until 1830
Mcr Warrior
8 Jan 2009
Just to clarify on this point, if using a West Yorkshire DaySaver ticket midweek, can you still board a late running train that was originally timed to depart at 1558, but doesn't arrive until 1602?
Barnsley
20 Feb 2010
Barnsley
Yes, it goes on the booked time, you can't however board a late-running 1827 departure!
Harpers Tate
10 May 2013
"Valid by any train timed to depart between the following times:
  • Mondays-Fridays 09:30-00:30
  • Saturdays, Sundays and Public Holidays 05:00-00:30"
Barnsley
20 Feb 2010
Barnsley
This is also underneath
Tickets are not valid on services Monday to Friday between 16:01 and 18:29.
toffeedanish
13 Dec 2010
The hypothetical late-running 18:27 discussed fulfils both of these criteria, so I would be happy to travel on it. The train is timed to depart after 09:30, and the actual time is after 18:29.
hornbeampark
27 Dec 2023
Harrogate
This wording was why I asked the question.
I genuinely wasn’t sure if the ticket just suddenly stopped being valid at 16:01 as the ‘timed to’ is only applied, in the wording, to the other restrictions.
