West Malling train fire (02/02/2023)
The time taken for the fire to be detected, the driver to react, contact the signaller to decide what to do, arrange for routes to be possibly set back to danger, wait for any approach controls to time out, then set the route into the bay instead, probably just wasn't available. Surely you just bring the train to a stop in whatever the first suitable place is and deal with the consequences later.
Indeed, I suspect, as you can see the driver on the phone, presumably to the signaller, in the video, this may be a very recently developed event, and the driver simply focussed on stopping the train at a suitable place, making announcements, and pressing the red GSM-R button, with follow up calls re what was happening and summoning the fire brigade being done after the doors were open to let the people off.
That's a fair point. It's a short distance from West Malling to Maidstone.
One would think you have an alert for criticism of our most holy Third Rail! :D
I have an alert for hysterical anti third rail BS :)
Nicholas Lewis
9 Aug 2019
I wonder if the very real dangers of this are taken into account by those who claim that the 3rd rail is not more dangerous than the OHLE.
Electrical fires can occur anywhere on the traction system there is lot of energy available whatever the voltage and of course lots of arcing makes them very videogenic. Designers, and historical hard learning, go to great lengths to manage the consequences should they arise and here this was demonstrated as the train moved under its own power later. Below is DB ICE train where a electrical fire destroyed part of the train oh and thats a 15kV overhead system.
dgl
5 Oct 2014
and naturally the current required to move a train (for example a 444's traction power alone can draw up to ~2,000A @ 750V) is probably close to what an electrical fault that is not a direct short would be, especially when you think that the over current protection for a section will generally be sized for more than one train drawing power, you've basically got a fire that is being constantly fed with fuel.
the sniper
4 Sep 2007
I'd be more worried standing on a platform as a passing train drags down the OHLE. Mind the flying pantograph...
Northampton
If it there was debris on the track, wouldn’t the front of the train be more affected than the rear?
Depends what and where it was, it might have been to the side of the track and kicked up in the displaced air as the train passed.
ComUtoR
13 Dec 2013
Or something that was level with the shoe gear and not the rest of the train...
Nicholas Lewis
9 Aug 2019
This is a high current route for class 92's so breakers set for at least 8000 Amps and given their is a substation here they would have delivered that current for a few 100ms before tripping but its also possible for an arcing fault, rather than a hard short circuit, to not always trip which looks the case from the video until an emergency isolation was called for.
JammyJames08
7 Apr 2009
I drove the first train up from Ashford after the fire was out and the line reopened (around 1930)
Signaller at Maidstone appreciated it was dark but wanted the lines London end of West Malling examined, arriving there NR and Fire Brigade were still on site examining the platform and 4ft. The 6 car had just left the site and passed my train at East Malling.
With the conductor in the back looking also, we didn’t find anything untoward.
Having seen the videos I’m glad no one was hurt, at what must have a been frightening event.
It was a shame (although not overly surprising) to read the usual negative comments/abuse on twitter afterwards, some of which was quite nasty and unnecessary (and political)
Let’s hope fleet can find out what happened but it doesn’t look like an infrastructure problem.
Surely it's the same as with any train carriage that catches fire - moving to another carriage is the best advice until alighting is possible.
Certainly no cause for anti-third rail hysteria.
True, but in this case it was the third rail system that triggered the fire. Not a common event, but happens often enough. Meanwhile I’m not aware of any train fire triggered by an OLE event, at least not in this country in the recent past.
Rich1974
20 May 2022
Somewhere
Had something like this a few years back at Redhill with a Class 165, a possible foil crisp wrapper decided to get wedged between the third rail and the sander hose on one of the bogies and the rubber hose caught fire.
I've seen various cases where engines have burst into flame, some on the 180's. I don't recall you exclaiming how dangerous they were.
I wasn’t claiming that the third rail was dangerous either. I was simply pointing out that fires caused by the third rail system are more common than fires caused by the OLE system. And both are less common than fires caused by the coal system ;)
dgl
5 Oct 2014
Quite, if the fault is not drawing enough current or not showing an "expected" fault to trip the breakers then the power will stay on until it's manually shut off.
I feel very cheerful and safe on all UK trains, however if there were to be an issue, I hope that I would be alighting calmly like the gent with his shopping :)
Evolution
29 Jun 2016
Manchester
Could have been a lot worse, thankfully it wasn't. Props to the driver for dealing with what would have been a very stressful event, especially on DOO.
stuving
26 Jan 2017
Should that be restricted to 25kV AC OLE? Overcurrent protection of 1500V DC supplied by OLE is even more difficult than for 750V third rail. Fire may not always be the main result, but (in the RAIB's words) "the inability of the DC traction power supply protection to prevent a sustained fault current from melting the contact wire" can be even more scary for those on a platform. There are three recent examples, even in the one small area of 1500V DC in this country: Monkseaton (2010), South Gosforth (2013), and Walkergate (2014).
theageofthetra
27 May 2012
Beckenham
Shoe gear burn up. A relatively common occurrence in 3rd rail land, impact damage/shorting from track debris or could be a build up of dirt on the shoe gear and beam which shorts across the shoe beam to vehicle body and sets fire to the beam and cables.
Many of these units haven't been washed in months.
