WCML rewiring 2026 to 2036
Siting masts on the twisty Windermere branch would be quite a design challenge, and I'm sure is out of scope.
The WCML rewiring will probably use high-output equipment as they did for WCRM.
The challenge there will be to rewire the maximum length in (weekend?) possessions to avoid weekday disruption on the line.
I expect it follows on from similar life-expired rewiring on the GEML, which was considerably more complex (mostly 4-track with many crossings).
At least they won't have to deal with LNER-era hardware.
The big blocks will be so weekends are hardly used.
One would hope they will be rewiring near Penrith (South of M6 Junction 40) during the M6 Bridge Renewal next January.
They will. Its effectively a free block for them.
Class 317
7 Jul 2020
Cotswolds
What would make sense is ensuring sufficient power to allow BEMU'S to charge allowing them to operate on it and also on other connecting routes
thecrofter
16 Dec 2011
So they probably wont be doing it then!!
Correct - another little known fact (albeit slightly off topic) is that Oxenholme Feeder Station, being originally destined for another location on West Coast where planning permission was refused, doesn't have the spare physical capacity to accommodate an extra Circuit Breaker necessary to feed the Windermere Branch.
Russel
30 Jun 2022
Lichfield
All good points, but if the Windermere line is to every be wired, wouldn't it be the most cost effective way of doing it, to combine it the main WCML rewire?
Elecman
31 Dec 2013
Lancashire
Would you really need another Circuit Breaker for a short single line ? If you really did then either the Ordsall method of an additional small seperate Track Sectioning cabin fed off the main busbars in the feeder station or even just a post mounted ITSL would suffice. Would have thought that a plain sectioning switch would be sufficient though
ABB125
23 Jul 2016
University of Birmingham
Is (passive) provision for power supply upgrades being included in the work (eg: masts suitable for autotransformer wires)? If not, it would definitely come quite high up the list of wasted opportunities
Its only the wire being replaced I think, not the masts.
McRhu
14 Oct 2015
Lanark
Is it just the contact wire? If so I would imagine that would make the job a bit easier.
If that is the case then fair enough, although it still strikes me as the perfect time to change the masts as well if required for ATF
Only if there is money for that, and if its only the wires are funded then it isn't happening.
there might be a few new masts, but most of them will remain. They’re good for a century at least. And you dont need new masts for ATF. Plenty of places on two track railways with ATF on ’heritage’ masts, including the WCML.
thealexweb
5 Jan 2014
Well thats TPE North West unable to run during this lol. Wish they kept the Liverpool-Man Vic-Edinburgh…
59CosG95
18 Aug 2013
Beeston (Notts)
If it's only the wire, why would they need blockades lasting three two weeks at a time? Couldn't they do a wire length in an overnight possession?
Also depends on the type of wire. Contact wires are replaced more frequently on the whole, and are typically easier to replace than catenary wires, which is what I assume these fairly opaque articles are alluding to.
Both catenary wire and droppers would have to be replaced; my bet is that the old AWAC (Alumoweld aluminium composite) catenary, cheaper than copper but prone to galvanic corrosion, will be going, as will the stainless steel droppers (which aren't flexible).
Bronze II catenary and Bronze II droppers (which are flexible) will likely replace them. If I remember correctly, there have been a few sporadic upgrades of WCML catenary to "Mark IIID" standards in the same way previously on the route, albeit not at the proposed scale. You'd also have to slack off the OLE at the balance weights (or Tensorexes as the case may be; unlikely but possible for the WCML!) to replace either catenary or contact wires.
Depends on how.long a wire section is. I don't believe they are that long. I expect @Elecman may know. The amount of wire runs is going to be massive over that distance. You get economies of scale in a blockade in that you arent getting the equipment there, setting up, isolating and handing back multiple times. It applies to any substantial project. As @Falcon1200 has said, trains run overnight, so you would be diverting the sleeper and freight to the extent no one could do work on the ECML etc
What confuses me about the WCRM catenary upgrade was that the cross-section and tensioning were changed in order to support 125mph (previously 110mph).
The catenary alignment was also changed to support tilt operation.
As Pendolinos run at 125mph throughout the northern sections of the WCML, I though that those changes must already have been done.
Evidently not.
Northampton
The rewiring also probably puts paid to ideas of new sections of the WCML to bypass congested areas (which was a post-HS2 ambition).
Re-wiring shouldn't make any difference to the capacity, so if new sections are needed they'll still be needed. It's also (presumably) funded out of a renewals budget, so a completely different pot any enhancement would be funded from.
Phillipimo
5 Jan 2013
Portsmouth
Apologies if already mentioned, but isn't this the TriLink project?
Now, 50 years later, TriLink is the name of the programme to ‘intelligently’ renew the route and to provide a more reliable timetable for passengers and freight services.
A cross industry partnership to completely renew and slightly enhance the north WCML. The Rail Engineer article mentions track, overhead wire and signalling renewals, as well as increasing the speed trains can enter and exit loops, and extending some loops too.
Elecman
31 Dec 2013
Lancashire
Correct yes this is part of the Trilink project
