WCML rewiring 2026 to 2036
74A
27 Aug 2015
Haven't seen anything about this. Over the next ten years network rail are replacing the catenary as its over 50 years old.
Rolling programme of 2 week closures for each section. Going to be a big job.
I thought they had done this when the WCML was upgraded for the pendolino but obviously not.
Also we're they expecting HS2 to be open before they had to do this. Would have made sense.
takno
Verified Rep - Traksy
where are you seeing it now?
You want it done before HS2 opens surely, especially as its meant to be the north end. West Coast Route Mod was a southern end job. It was never going up that far.
DJH1971
10 Jun 2012
St Helens, Merseyside
It will certainly put pressure on LNER as more people travelling from London to Scotland will end up going via the ECML. Likewise with Chiltern Trains as more people travelling from the West Midlands to London will end up going via the Chilterns
Peter0124
20 Nov 2016
So does that mean the WCML is closed for 10 years? Or will there be breaks in between each rewiring project?
It will be ten years of short term closures in specific areas. They're not going to close the WCML for ten years :lol:
It’s the north end of the WCML between Warrington and Carlisle according to a paywalled article in the Times, there’s no reason for Chiltern to be affected at all.
Peter0124
20 Nov 2016
I thought the Warrington - Carlisle section was wired later in 1974?
So trains to Liverpool, Manchester, North Wales and West Midlands are basically unaffected?
A couple of paragraphs from the Times:
Industry insiders have been told engineers will take possession of the line — shutting it to trains — for three blocks of two weeks each in 2026, 2027 and 2028.
Similar blockades which will affect services between Crewe in Cheshire and Gretna in Dumfriesshire, are anticipated for up to ten years but are not yet scheduled. The stations which will be affected include Warrington Bank Quay, Wigan, Preston, Lancaster, Oxenholme, Penrith and Carlisle.
The work starting in 2026 is designed to “renew” rather than simply enhance the west coast main line. The full programme of works is understood to include the replacement of 155 miles of overhead wires installed in 1974, when the line was electrified, as well as the renewal of 140 miles of track and replacement of 2,000 signalling units.
So it’s not just the overhead. The stories do seem to get exaggerated, but AFAICT whether or not HS2 phase 1 is opened will be irrelevant.
I've never quite understood the scope of WCRM rewiring, but I think it was fast lines only, Euston-Crewe-Manchester (maybe just to Cheadle Hulme).
Crewe-Weaver Jn-Liverpool/Edge Hill was also done I think, and the extremities of the Birmingham loop, and maybe some via Stoke.
The TV4 4-track section would be new OHLE I think.
That still leaves the slow lines (1960-ish) and Weaver Jn-Glasgow/Carstairs (1973-ish).
The rewiring also probably puts paid to ideas of new sections of the WCML to bypass congested areas (which was a post-HS2 ambition).
Verulamius
30 Jul 2014
Could there be regular diversions via Settle whilst the section north of Preston is renewed?
I don't see why, it just means its new and won't fail if its left alone expecting something that isn't even planned.
There are other bets I would probably rather take first.
GRALISTAIR
11 Apr 2012
Preston Lancs
Most of the wiring was complete in 1973. In fact, electric to diesel locomotive changes happened in Preston during that year. I saw the wiring complete (mainly) north of Preston in 1973 as the house where I grew up in, backed on to the WCML 4 miles north of Preston.
Through electric services from Euston to Glasgow Central started in May 1974.
Correct.
Renewing a 50 year old asset.
Correct 1973/4 ish TO 2025/6/7/8 is 50 years ish.
takno
Its pictures with about 10 lines of story :lol:
Not much danger I'll be trying to read it if it's in the Mail anyway :D. I was just unsure whether I should be looking for a Network Rail announcement, an industry publication or normal newspapers
GRALISTAIR
11 Apr 2012
Preston Lancs
I am sure there will be a major write up in the next few months in RAIL or Modern Railways or both.
Russel
30 Jun 2022
Lichfield
Could they wire the Windermere branch while they are in the area?
Or is that asking too much?
thecrofter
16 Dec 2011
Renewal (of existing wiring) and an Enhancement (electrifying the Windermere Branch) would be two entirely different things - so yes that would be asking too much.
So they probably wont be doing it then!!
Siting masts on the twisty Windermere branch would be quite a design challenge, and I'm sure is out of scope.
The WCML rewiring will probably use high-output equipment as they did for WCRM.
The challenge there will be to rewire the maximum length in (weekend?) possessions to avoid weekday disruption on the line.
I expect it follows on from similar life-expired rewiring on the GEML, which was considerably more complex (mostly 4-track with many crossings).
At least they won't have to deal with LNER-era hardware.
Class 170101
1 Mar 2014
One would hope they will be rewiring near Penrith (South of M6 Junction 40) during the M6 Bridge Renewal next January.
